Question about Tricity Bendix 24 in. DH102 Free-standing Dishwasher
My dishwasher is shortcircuiting when it is plugged in
No brake lights/tail lights. replaced light switch. if the brake switch knob is pulled out slightly, they work but i loose the main headlights. checked all the fuses they are good
Low battery voltage (headlamp relay cuts out).Start the car,measure charge,let charge.Wiring shortcircuit must track the problem/wires.Hint:the brake switch trigger only with the keys on.If it continue to cut the light even with the keys out ceck wiring .Worning:shortcircuit can put a car on fire.
Oct 26, 2013 | 1994 Ford Ranger Supercab
During an intensive cycle the washing machine 72730 caused a shortcircuit and the house differential switch jumped. After trying to switch it on again I discovered that the washing machine causes a...
Sorry but with such a fault it is virtually impossible for anybody on this FixYa forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB, water inlet control valves, door solenoid, main motor, drain motor etc.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 08, 2011 | AEG Lavamat 72640 Front Load Washer
Did a load of wash it shortcircuited are breaker box and now when you try to plug it in it sparks...won"t turn on
You may have a bad circuit breaker in that box, or a bad wire, or a bad connection in the outler or in the washer plug or a loose wire where the plug connects to the washing machine.
Turn off the power to that circuit and check each component until you find the loose wire, or the bad component. Joe
Feb 23, 2011 | Amana NTW5400TQ Top Load Washer
Sony home theater model no hcd-dz570 push power protect error on display what,s solution?
Check the speaker connection. One of them has a shortcircuit. Try to disconect all of them and power on the device. See what is happen. If starts corectly check the speaker cable. Conect one by one and power up the receiver after each connection. When you get the error again check the last conected cable. These receivers have a protection system against shortcircuits. That is puting your device in that error.
Jan 27, 2011 | Sony Audio Players & Recorders
My dishwasher is causing my power to trip any ideas why
It will do that if it's consuming far too much power due to a fault, or if there is leakage to earth.
Both indicate dangerous internal electrical faults with too many potential causes to diagnose remotely without the correct diagnostic tools.
Disconnect the machine and do not use it until it has been checked over by a qualified domestic appliance service engineer.
Feb 23, 2010 | Dishwashers
HP Printer Usb port in my Acer Laptop , shortcircuits my house
hello
Try using external USB HUB (POWERED) Adapter. It might fix this issue.
Use an other USB cable and see.
If the problem still exist do not plug in the printer again, you may damage your USB port or even burn your laptop motherboard.
hope this helped
TekSpotDotCoDotUK
Aug 26, 2009 | Acer Aspire 6930-6941 Notebook
Razer Deathadder crashes computer
I think that cable of your razer is broken and some cables are shortcircuited, don't plug it in computer, you could ruin your motherboard. If you want your mouse working and have some technical skills, buy some usb cable with same plug as mouse have and replace it
Jul 10, 2009 | Razer DeathAdder RZ01-00150100-R2M1
Have ibm2668 thinkpad has old pass code can't get in it.
I think this is bios pass? There are two ways - shortcircuiting bios pins or parallel method. Anyway you must disasemble your computer. Try to remove bios battery first (its under keyboard) for two hours. It's a very small chance this will help. When removing battery does nothing, you must search on google which bios pins to shortcircuit in your model. Problem is if you don't have manual/tech scheme for your machine. Try to download it from manufacturer website. You can use a parallel method, but it is harder. Shortcircuiting really works, one guy on fixya was fine with bios pass. Wish to help you more, but I cant, I have the same problem with Fujitsu Siemens, and so on, no solutions, no tech scheme :(
Finally you can use a universal and manufacturer password, search for these two, For universal, you must check what kind and version of bios you have. It usually shows when you just starting computer.
Mar 30, 2009 | IBM Thinkpad T43/p Notebook
Codegen 300 wt supply
You can do this doing shortcircuit between the green and a black wire in atx cable
May 16, 2008 | Codegen POWER SUPPLY CG|PS-350XA-12 RT...
Tricity Bendix 24 in. DH102 Free-standing Dishwasher Logo
24 people viewed this question
Top Tricity Bendix Dishwashers Experts
Are you a Tricity Bendix Dishwasher Expert? Answer questions, earn points and help others
