Question about Sewing Machines
Need to change belt on Kenmore Model # 158.14100
Have a new, correct part belt. Can't figure out how to get the old one off and the new one on. How can I change this belt?
How to replace kenmore model 158 13400 belt
Good morning
If you have got the belt, I would remove the old one and put the new one on as the old one disappears. I used to change belts that way when I had a machine.
Enjoy your coffee
Kolbrun
Jul 05, 2012 | Sewing Machines
Hello! I need to replace the motor on a Kenmore Series 16 machine. Model 158.162. The Sears website states the motor 5168, is not available anymore and no substitute is recommended by the manufacturer. ...
I realy dont think that you will find a new motor for a old kenmore, you may be able to find one on craigslist/ebay. How do you know it is the motor? Could just need new brushes or a new foot control. I have never had a bad motor on a old kenmore. replaced brushes and many foot cotrols.
Not that it could not happen but it would be rare.
hope this helps
Mar 25, 2011 | Kenmore Sewing Machines
How can I loosen the belt on an old Kenmore model # 117.841?
There are 2 hex head bolts ( 7/16 ) in the back, under the motor. You just have to loosen the screws and lift up on the motor, this will loosen the belt.
Sep 03, 2010 | Kenmore Sewing Machines
My Kenmore model number is 385.16120200. Ever
Make sure the needle is installed correctly - usually with the flat side facing the back of the machine.....check the manual.
When you thread the machine always do so with the presser foot up.
Feb 23, 2010 | Kenmore Sewing Machines
Need manual: Kenmore sewing machine 158.9
Those books are long since out of print. Try contacting sewing machine stores who stock old instruction books. Many shops do this. Or try eBay.
http://shop.ebay.com/i.html?_nkw=instruction+book+kenmore+sewing&_sacat=0&_trksid=p3286.m270.l1313&_odkw=instruction+book+sears+kenmore+sewing&_osacat=0
Jan 24, 2010 | Sewing Machines
Kenmore sewing machine mod 1703 motor runs but
By 'The wheel the belt is on' you mean the motor pully? If that is so obviously some oil has some how made way on the pully and the belt. Try to remove the belt and clean both wheels and the belt free of oil. This shd slove the problem.
If it doest then please send a photo of the arrangement showing pully and belt. U didnt mention if the machine is old or new. Did u oil it recently before trouble developed?
Oct 17, 2009 | Kenmore Sewing Machines
I need to replace the motor belt on a Kenmore sewing machine
You can find the belt you need here:
http://www.sew4less.com/QuickSearch.php
if not in stock try here for the part you need:
http://www.a1sewingmachine.com/belts.html
Jul 07, 2009 | Kenmore Sewing Machines
Broken belt
If you are having problems finding the correct belt, sometimes the stretch belts work great for these situations. You can find many of them on ebay.
Nov 14, 2008 | Kenmore 15516 Mechanical Sewing Machine
1968 kenmore sewing machine
belts and oil it in any point that has metal to metal
Oct 02, 2017 | Sewing Machines
Old kenmore sewing machine model # 1237 ( not found in search) - prob. purch.'d in 198o's
Check the handwheel. If it is pulled out, the clutch is not engaged. Try pushing it in! (It would be really nice if the solution is this easy!)
Sep 08, 2008 | Kenmore 15516 Mechanical Sewing Machine
Sewing Machines Logo
19 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
