Washing machine won't drain
SOURCE: GE Spacemaker Extra-Large Capacity Portable Washer
i was using a defective extension cord, the machine should trip when start it . and beep with no other message on the screen
SOURCE: Water Won't Drain from Washing Machine
Hello phylislw61,
If you had an incident where a pillow broke and feathers where dispersed throughout the washer..then there is a good chance that teh drain fiilter screen, pump or hose feeding the pump is clogged. I would verify that the filter is free from anything that would limit water flow from getting to the pump.. then if the problem is still there.. examine the pump itself to make sure it isn't clogged...
If you or someone in your family is reasonably handy, here is a link to your washing machines exploded view and parts and this should provide sufficient information for how to access the pump and associated hoses etc that feed into and out of it for cleaning..
If you are having problems after you verify the lines are free of restriction, feel free to contact me and I will try to assist you in solving your problem.. Here is the link..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
SOURCE: what is the load capacity for the GE wpse4200aoww Washing Machine
not sure exzakley ive repaired thousands of washers though.just dont pack the clothes in it.God bless,tom
SOURCE: G.E. washing machine will not drain completely
It won't drain
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
good luck.....
SOURCE: GE washing machine not draining and spinning
please change the washer between the hose that leads to water exit and the machine. this must have gone loose or worn out.
Setting the Controls
Use the Suggested Fabric and Cycle Settings guide ~ Select Rinse Temperature.
to help you make the proper selections.
~ Select Wash Spin Speed.
~ Push Cycle Selector knob in and turn clockwise to
your selected wash setting. If you wish to change setting
~ Select Water Level. ~ Pull Cycle Selector knob + START out to start the washer.
SMALL: Washer is less than 1/3 full of clothes.
MEDIUM: Between 1/3 and 1/2 full.
LARGE: Between 1/2 and 2/3 full.
This washer will pretty much take anything you can throw at it. It was a competetor of the Maytag large capacity washers. As long as you follow the loading guide above you are not going to hurt it.
Thanks for choosing FixYa,
Kelly
