Question about True Freezers
Commercial fan on evaporator cuts off after starting
Evaporator fan cuts off after start up
  • 884 Answers
There is an overheat klixon on the evaporator that stops the fan running until the coil gets below -11c This can take some time after startup. if the freezer runs more than an hour before the fan starting, check the klixon isn't faulty, and you have power to the fan. Also check the condenser grille is nice and clean as it will slow down the freezing process.
Posted on Apr 26, 2014
Arctic air freezer
motor humming is from 2 things
start / run capacitor is failed
compressor is seized and the motor is not turning
call in an technician for a proper diagnosis and quote
Jul 08, 2016 | Artic Air Arctic Air F22CW12 Commercial...
Tip
Freezer not working, things to check
The unit needs two fans running and good airflow, one fan outside cools the condensor coil and the other inside the unit blowing across the evaporator coil, warming it. The compressor must start up. The defrost timer stops everything and switches on a heating element to defrost the evaporator for several minutes. Please verify these conditions. The condensor coil may get clogged with dirt and lint, the evaporator may get clogged with ice build up, or the fan may quit working due to bad bearings, need for lubrication, or burn out. The defrost timer has an internal motor and contacts which may quit working, some have a way to manualy turn it to switch its mode in case it quits working.
on Feb 11, 2015 | Freezers
GE bottom freezer stopped cooling
The unit needs two fans running and good airflow, one fan outside cools the condensor coil and the other inside the unit blowing across the evaporator. The compressor must start up. The defrost timer stops everything and switches on a heating element to defrost the evaporator for several minutes. Please verify these conditions.
Jan 24, 2015 | GE Profile PGCS1NFZSS 20.7 cu. ft....
What is a clixon
Clixon is an overload device designed to shut off current when too much juice is flowing within circuit. When it cools it resets itself but if condition is still present it will go out again.
Apr 17, 2014 | True 72 cu. ft. / 2039 liter Commercial...
My true freezer won't defrost?
Check the defrost timer (in the base, circular knob you can turn till it clicks) If it doesn't heat up rapidly in the evaporator, there is a safety overheat device (thermistor) that may be cutting power to the heater, or there may be a fault with the heater itself. Are you sure the fans are working, and the condenser grill is nice and clean?
May 14, 2012 | True 72 cu. ft. / 2039 liter Commercial...
I have TRUE freezer model number GDM-49F. the compressor start but the evaporator fan wont start what culd be the problem
Could be a number of things. It has a thermistor that sits on the evaporator to keep the fan off until it gets cold. It also has a switch above the door that switches the fan on when the door's closed. It could be a loose connection in the wiring, or, lastly, it could be a seized fan
May 04, 2012 | True 49 cu. ft. / 1388 liter Commercial...
Delay on evap. fan sistm.404a
Give the evaporator a chance to get cold, then check you've got power to the fan, via the evaporator thermistor and door switch
May 02, 2012 | True Freezers
My freezer has power, but the fans are not going on when the door shuts and the temperature is rising.
The defrost termination/ fan delay control is a temperature-activated, single pole-double throw switch. ).
The control is wired into the refrigeration circuit. The control is located high on the evaporator where the frost is likely to clear last. The function of this temperature-activated switch is to terminate defrost when the evaporator coil has been defrosted, and to delay the evaporator fans from coming on immediately after defrost.
The coil must reach a temperature of 25* F. for the fan delay to close allowing the fans to operate.bobicehouse_38.jpg
Jul 22, 2011 | True 49 cu. ft. / 1388 liter Commercial...
We have a True TS-49F freezer that the interior fan have stopped working. Holding the door switch does not activate them. Unit is out of warranty.
Most all commercial freezers like yours have, what is called, a fan delay. It is located in the evaporator case and is usually attached on or very close to the actual cooling coil. It may also be a combination switch known as a defrost terminator/ fan delay. It's purpose is to keep from circulating warm air. If the cooling coil does not reach a preset temp, the fans do not come one. Another thing is that the fan motor may just be bad. If you have more than one fan, then chances are that it's going to be the fan delay. I would start there to see that either the fan delay switch is bad or there is a reason that the coil is not getting cold enough to activate the switch.
Nov 09, 2010 | True 49 cu. ft. / 1388 liter Commercial...
Short defrost cycle so some ice still on the evap and start new cycle so after some time lots of ice on coil
The defrost cycle is a set time. I would suggest cleaning the evaporator so it has less chance to hang up in the trays.
Feb 08, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Freezers Logo
149 people viewed this question
Top True Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
christian nielsen
Are you a True Freezer Expert? Answer questions, earn points and help others
