Question about Kenmore 24 in. 16049 Built-in Dishwasher
My kenmore 665.13719k600,wont clean the dishes
I tore it apart and cleaned a ton of calcium and lime build up from around the pumps, is there an easier way to keep this from happening?
  • lovingharmon Jun 19, 2009
    thanks guys i appreciate it, yes we do have way hard water & it's city water not well water. I will try these solutions. Where would i find Dishwasher Magic& Ace Hardware, they looked at me like I was nuts asking for a dishwasher cleaner. I used CLR but not nuts about using that aroun my dishes.
  • Payton
    Payton Apr 29, 2018
    We at Citi Clean are well aware of the requirements for inventory checks and our extensive end of tenancy cleaning checklist reflects the cleanliness standards required by major London letting agents. We have carried out thousands of end of tenancy cleaning jobs in London for more than 7 years. End of Tenancy Cleaning
    Problem Solver:
  • 8 Answers
Pour cup vinegar in and wash,i am guessing u r on well water. do this once every 6 months. may check water at county services if lot of lime/calcium you may want to filter too.
Posted on Jun 19, 2009
  • 6,784 Answers
Try cleaning your dishwasher using a dishwasher cleaner. this will clean out the build up. There is one that i recommend and it is called Dishwasher Magic.
You can prevent this from occurring in the future by, installing a Water softener in you home. this will heel the build up.
  • Michael Masters
    Michael Masters Jun 19, 2009
    There is usually two, sometimes three spray arms in a dishwasher.
    Make sure there is no debris blocking the holes inside each spray
    arm as well.
    One more thing, make sur ethe water temp is at 120 degrees
    Fahrenheit when entering the dishwasher.
  • Michael Masters
    OK, i can direct you to the purchase page so that you may order a couple of bottles online. this is good stuff. it works.
    CLICK HERE
Tip
Hard water Calcium white powder build up in dishwasher
Calcium and magnesium is present in a great number of homes today regardless of hardness or softness of the water. Water containing dissolved carbonates of calcium and magnesium can lower the effectiveness of the detergents you use and leave deposits on the dishware and tub of the dishwasher. When these deposits dry they become what some call lime scale.
To remove these deposits there are a number of cleaners on the market today. I will list them in the order of my preference. You can find them near the dishwasher detergents. If you use them read the instructions on the label, but basically you can run a cycle with no dishes and the cleaner. Some of the cleaners like Lemi-Shine can be used with a full load of dishware after you clean the tub. This helps keep the tub clean and deposits off the dishes. If you want a home remedy that seems to work pretty good, put a cereal size bowl upright in the lower rack (no other dishes in the dishwasher) fill the bowl with vinegar and run a normal cycle. The vinegar will wash out and clean some of the deposits away. If residue is still around run a second cycle of the vinegar wash.
- Lemi-Shine
- Finish Dishwasher Cleaner
- Glisten
- Glass Magic
Here are some links to other dishwasher tips I have put together.
Blinking Clean Light
Poor washing on the top rack or noisy
General Dishwasher Cleaning
on Apr 30, 2010 | Dishwashers
I have a kitchenaid dishwasher that doesn't dissolve even liquid soap. At the end of the cycle there is hard compacted soap residue that ends up blocking the holes where the water shoots out and there are...
Try getting some calcium, lime and rust remover. Follow the instructions on the bottle and run the dishwasher empty using only the CLR. Check your incoming water lines for calcium or lime build up.
Sep 17, 2013 | Dishwashers
Door does not open to dispense soap
Often times the latch needs cleaning from the accumulated calcium and soap caked around the latch. Use an old toothbrush or sometimes something a little stiffer to scrub around the latch, the dispenser cups and in the general area. If there is still accumulation a small amount of CLR [calcium-lime-rust] remover will break down the accumulation. We had a Kenmore running in very hard water situation that wouldn't open and we just left it open and didn't worry about the dispenser door releasing. We did this because we always scraped off all the food in the sink before putting dishes in the dishwasher and then ran on the water miser setting which requires only one of the soap dispenser wells to be filled.
Nov 04, 2010 | Kenmore 15954 Built-in Dishwasher
Calcium/Lime Build-up on Dishwasher Heating Element
You can clean the calcium/lime build up with CLR and a scotch brite pad.
Apr 27, 2010 | Frigidaire Dishwashers
I have a kenmore elite ultra wash he (model 665.1315) dishwasher - one year old. No problems until recently. It just started leaving a substantial film on the dishes, cutlery and racks in the past 10...
there is calcium in water and it builds up around the pump and the flow you typically have to take it all apart to clean it or there is crud in your drain inside the dishwasher, basically you are swishing around the dirty old water and food particles, Ralph this is from not rinsing dishes first and using special dishwasher soaps to prevent the build up thus clogging pump and exit lines. pull the pump apart if you dont find clogged filters.
Nov 24, 2017 | Kenmore Dishwashers
LIMESCALE BUILD UP
To prevent lime build-up, use distilled water instead of tap water. I buy bottles of distilled water for use in my irons and steamers and have never gotten calcium or lime build-ups.
You can buy a product by the name of CLR (stands for Calcium, Lime & Rust) which can be found at stores such as Target, Walgreens, CVS, Walmart, etc.) to wipe the build-up from your iron. You can also run this solution through your iron to clean the build-up from the inside.
May 12, 2009 | Irons
Preventive maintenance?
You should buy some c.l.r. (calcium,lime,rust) remover.It's packaged in a grey bottle at any supermarket,drug store,ect.Pour a cup in and run a cycle once a month.This will prevent any lime build up from scaling the dishwasher due to hard water.
Mar 19, 2009 | Dishwashers
Inside of dishwasher not clean after running.
its a lime build up from the quality of your water.goto home depot/lowes or a supermarket and buy clr (calcium lime rust) remover.pour a cup in the dishwasher and run a full cycle.this should do the trick.
Jan 16, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore Side-by-side Ice Maker
The only cleaning that can be done is at the inlet valve. If it is anything else you will need to replace it.
Dec 09, 2007 | Kenmore 44109 / 44102 Side by Side...
Kenmore 24 in. 16049 Built-in Dishwasher Logo
346 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
