Question about HP P3015 Laser Printer
HP 3015 tray 3 open
Has legal size paper in it but when trying to print from it it says that it's open...
  • HP Master
  • 1,121 Answers
Ckh cassette present switch as shown in fig.. switch broken, bent, misplaced as well as cassette switch trigger broken or bent..
HP 3015 tray 3 open - dma8p8d+0vrbcgllecaaaaasuvork5cyii=
Posted on Apr 17, 2014
checkitright
  • 1362 Answers
SOURCE: How do I copy a legal size document?
You need to change it in the menu, it's stopping because once it reaches the letter size the sensor detects that there is still paper there and jams.
Posted on Oct 23, 2007
SOURCE: tray output
You should configure TRAY 1 as Legal only.
and Tray 2 as plain letter.
Specially when you specify from what tray/paper type to print.
This can be easily configured from the Printer Properties within the Printers and Faxes section of the Control Panel.
Posted on Jan 26, 2008
Nextgen
  • 13 Answers
SOURCE: Changing Paper Size
If the blue guide in the back of the tray (called the length plate adjuster) is broken or dislodged, the machine may not recognize what size paper is installed. When the guide is moved, three arms on the right side of the paper tray change configuration. Those arms push against sensors in the machine to tell the printer what size paper is in the tray. You can temporarily resolve this by taping the guide in the A4 position, however you should consider replacing the tray or replacing the guide soon to avoid tape getting into the printer.
Hope this helps!
Posted on May 15, 2008
  • 48 Answers
SOURCE: cannot print to legal size paper format
There could be a few issues causing this problem.
1. Your document size on the actual document you are attempting to print believes it is letter (which is the default).
To change this setting, you must tell the computer you wish to print on legal paper.
To do this in MS. OUTLOOK:
Put the curser at the top of the page
then...under 'File-Print-Preferences-Layout-Advanced-Paper size-change to legal (from Letter'
-slightly tedious...but follow along and this should help
2. The printer needs to be adjusted to hold the legal paper.
Open up the legal tray to adjust the paper holder to hold the paper snuggly...it slides roughly.
Hope this helps..if you need more assistance please ask...also please rate my solution.
PLEASE note that anything other than a FIX-YA is actually a negative rank...and will lower my success...I didn't make the system...but that is the way it is in FIX-YA.
thanks
bearb
Posted on Nov 10, 2008
SOURCE: Re: HP 1320 won't take the tray designation for 2 and 3 Help
Hello classygirl,
I had this exact same problem and resolved it by downloading the HP LaserJet 1160/LaserJet 1320 North American and Western European Full Printing Solution which can be downloaded from support.hp.com.
Because the 1320 does not have a built-in interface, installing the basic drivers will not work. You must download and install the full 400+mb package.
Hope this helps!
Posted on Jan 06, 2009
Printing custom sizes on hp deskjet 3015
In MS Word, go to page setup then modify the paper size of the document.
Next, Press CTRL P to open the print dialog box, then select properties. Modify the paper size of the printer.
Hope this helps.
Apr 25, 2014 | HP LaserJet 3015 All-In-One Printer
How do I get my hp 1320 printer to automatically print legal or letter size documents?
From my experience of commercial Dell and Ricoh office printers you have to specify what paper is in what tray and which one is the Default to print if no other instruction is given. When you want Legal, you have to change it just before you print.
Easy link to your manual
http://images10.newegg.com/User-Manual/User_Manual_28-414-324.pdf
HP Support page on the printer
HP LaserJet 1320 Printer User Guides
Jan 01, 2018 | HP Office Equipment & Supplies
Hello, I have a question about the HP 1312 all in one printer. Does it print on legal size paper and where do I load the legal size?
Yes, it can print on legal size paper. Do the following:
Lower the paper tray, and if necessary, slide the paper-width guide to the outermost position.
Fold out the paper-tray extender to catch paper as it exits the device.
Tip: For best results when loading legal-size paper, fold in the paper-tray extender before loading the paper to avoid a paper jam.
May 13, 2011 | HP Office Equipment & Supplies
Legal size no print of hp Laser Jet 2420n printer
Hii It could be wrong on this but there should be a setting on the printer for paper size and type for tray 1. Use it to set tray 1 as legal size and then use your program to send to the printer. Another way would be to have no paper on tray 1 and send the job. The display on the printer should say to load legal on tray 1 and hit the button to continue. When you do the printer will now know it has legal paper in tray 1. The last method is only good for that job and will have to be done the same way for another job. Specifying tray 1 as legal paper will allow you to have legal paper in the tray when the job is sent and not have to press the button.
All the Best.....
Dec 11, 2010 | HP LaserJet 2420 Printer
How to print with the legal paper?
follw the given step and check-
1-Before printing your document, be sure the page size is set to legal paper. Go to "File> Page Setup" and then click on the "Paper Size" tab. Select "Legal" from the drop-down menu.
2-Go to the printer and take out the paper tray. Remove the letter size paper.
3-Insert about one half of the package of legal size paper into the tray, depending on the depth of your tray. Larger printers can accept an entire package, while smaller ones cannot.
4-Make sure that the paper goes underneath the metal clips located at both the front and back of the tray.
5-For printers that don't have a tray, you'll have to manually feed the legal size paper. Locate the paper feed either on the front or rear of the printer.
6-Put a few sheets of legal size paper into the paper feed. The paper should be placed as close to the rubber spindles as possible. These spindles will draw the paper into the machine and feed it through the printer.
7-Print a test page.
Thanks,
Dec 03, 2009 | Brother HL-2040 Laser Printer
My hp laserjet 2420 printer won't print out my bottom text of my legal size document. when i preview my print it cuts off all text at 9.5'' . what's wrong? my margin's are all set to 1'' and i customized...
Do NOT use customized paper. Set your paper tray to LEGAL paper. Set the tray as LEGAL in the printers setup-menu. Make sure you choose LEGAL in the printout-dialog-properties. Then it should work. Good Luck.
Aug 14, 2009 | HP Hewlett Packard LaserJet 2420 Printer
HP Laserjet 4 plus printer
use the m/p tray.configure printer to print any size.
Jun 25, 2009 | HP LaserJet 4 plus Printer
I HAVE LASERJET 4 PLUS. WHEN I GIVE JOB FOR PRINTING THE PRINTER DISPLAYS A MESSAGE AS PC LOAD LEGAL. PLS HELP ME IN SOLVING THE PROBLEM
The document you're trying to print is formatted for legal size paper, and the tray contains only letter size. if it's a legal size, put legal paper into the MP tray, or override the setting and manually select "letter size" in the printer dialog box.
Apr 04, 2009 | HP LaserJet 4 plus Printer
Cannot print to legal size paper format
thanks
bearb
Nov 10, 2008 | HP LaserJet 2605DTN Color Printer
Tray output
Jan 26, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
HP P3015 Laser Printer Logo
199 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
