Question about Indesit Washing Machines
User manual for indesit condenser washer dryer 921
priyabrat
  • 123 Answers
SOURCE: Get dryer to work, no instruction manual for Indesit Washer WDG 1195 W
What to check when your dryer won't start-
The wall outlet 240 volts:
The first thing to check when your Whirlpool dryer is not starting is the wall outlet to make sure that the dryer is getting the proper voltages. On an electric dryer there should be 240 and 120 volts present at the terminal block.
A blown fuse or tripped circuit breaker are one of the major causes why the dryer won't start. To check the voltage on an electric dryer you will need to use a multimeter.
The wall outlet 120 volts:
A gas dryer connects to a 120 volts wall outlet, and it is very easy to check the outlet. Disconnect the dryer and connect a hair blower or any other small appliance on the outlet.
If they work, then the problem must be on the dryer. If the don't work, check for a blown fuse or tripped circuit breaker. If the problem is bigger than that, have a license electrician check the house wiring. A bad wall outlet could be the reason why your Whirlpool dryer is not starting.
The thermal fuse:
The thermal fuse is use on an electric dryer as a safety devise to open the motor circuit if the operating thermostat fails to open at the preset temperature or if the motor draws too much amperage.
A blown thermal fuse could be the reason why your Whirlpool dryer is not starting. It is located behind the back panel on the dryer.
The door switch:
The door switch is another safety device use on the dryer. It is connected on the neutral line of the motor circuit. A door that is not closing properly or a bad door switch could be the reason why your Whirlpool dryer is not starting.
The push to start switch:
The push to start switch is use to start the motor. There are two types of switches. The older type switch is a solenoid operated door switch and the other one is a simple push to start switch.
A bad solenoid operated or regular push to start switch could be the cause why your Whirlpool dryer is not starting.
The timer:
The timer is the distribution center or the brain of the dryer. Inside of the timer is that the electricity gets routed to the different electrical parts in the dryer.
The timer has contact points, and the contact points wear or burn out depending on the amount of use. Contacts burnt inside of the timer, could prevent the dryer motor from starting..
The motor:
Also, the motor could be burnt bad. A motor that smells like rubber burning, makes growling noises, runs for a wile, the won't start until is cool down or a motor that runs fine, but the centrifugal switch is not making the right connections is a bad motor and must be replace.
So...as you could see, there are many parts that could be the reason why your Whirlpool dryer is not starting.
Posted on Feb 16, 2008
  • 16 Answers
SOURCE: On-line User Manual "Kenmore 3.8 cu. ft. HE3t Washer
I have the Service Technician Diagnostic Guide...it was located behind the lower front panel on the right hand side. It's not really a user manual, but wasn't sure what info you needed that you hoped might be in the user manual, as opposed to a Diagnostic Guide.
Posted on Feb 28, 2008
SOURCE: indesit washer-dryer wd125 manual
I've been looking for these instructions and have just stumbled across them . Just inside the door there should be a barcode. On the top right check the model no. mine is WD 12S, despite the model no on the outside being WD125.
If so, look here http://imagebank.indesitcompany.co.uk/brochures_online/pdf/indesit/Laundry/WD12S.pdf
ATB
The Mighty Lev
Posted on May 24, 2009
SOURCE: I am looking for an online manual for an Indesit
Right. Go to the Indesit website. Find the model. There is an option on this screen to download the manual.
Posted on Mar 01, 2011
SOURCE: User manual needed for Hoover washer/dryer
I think you connect wires wrongly and after that it is not working in a proper way so here you need to change the wire position for working in a write way.
Washing Machine Warranty service
Posted on Aug 31, 2012
The message flashing says 'door' what do I do?
You have a problem with the door switch interlock.
Indesit WIDE 146 (DE) Washing Machine Spares ' eSpares
www.espares.co.uk > Home > Washers & Dryers > Washing Machines > Indesit
  1. Cached
Items 1 - 10 of 60 - Universal stacking kit suitable for most washers and dryers measuring 60cm across More information. In Stock. Stock Number ES187394.
Get Indesit Washing Machine Spare Parts ' eSpares
  1. Cached
  2. Similar
Genuine Indesit washing machine spares including Drum lifters, Indesit ... Start your Indesit parts search by selecting your washing machine model number from ...
Indesit Washing Machine WIDE 146 (DE) Spares - indesitspares
www.indesitspares.co.uk/washing-machine/wide-146-de.../catalogue.pl?path...
  1. Cached
Indesit WIDE 146 (DE) Washing Machine Spares ... Fits models with serial number from 30127.0001 Please Note the above serial number changes does not ...
Indesit Washing Machine IWDE 146 UK Spares - indesitspares
www.indesitspares.co.uk/washing-machine/iwde-146-uk-f084074/catalogue.pl?...
  1. Cached
Indesit IWDE 146 UK Washing Machine Spares ... This part fits the following models: WIL133UK, WIL133UKCO, WIXE127UKV & Does Not Fit Mod. .... If you have just replaced the door seal on your appliance then you may need this retainer ...
Indesit Ecotime IWDE 146 Built-in Washer Dryer - White
www.indesit.co.uk/appliances_i/Washer_Dryer_IWDE_146/pid_F084074UK/42.do
  1. Cached
  2. Similar
Rating: 8.5/10 - ‎19 votes Indesit Ecotime IWDE 146 Built-in Washer Dryer - White, ... News & Offers; Service & Spares. Service · Spare Parts ... IWDE 146 reviews · Ask-an-owner ...
Washer dryer no wide 146 Google Search
Mar 24, 2017 | Washing Machines
My indesit condenser tumble dryerwont start
try door interlock......................cheers
Oct 07, 2016 | Indesit Dryers
I'm looking for a user's manual for the Indesit washer/dryer combo WIDL 106 model. Can you help? Thanks.
Unfortunately FixYa cannot provide manuals direct - members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Oct 08, 2011 | Indesit W 123 Front Load Washer
Should the Indesit IWDC 6105 washer dryer give off a burning type odour when running the drying cycle. (it is brand new and condenser)
I have seen some new dryers give off a smell for the first few seconds that they are run for the first time.
If it's any longer then that is not normal.
Aug 02, 2011 | Dryers
How do you remove the water pump on an indesit idc75 condenser drier?
This easy to use white Indemnity condenser dryer will make a welcome addition to any kitchen. The 10 minute cool tumble and reverse tumble option will help keep creases in your fabric to a minimum. Energy efficiency ratings & performance: Energy efficiency rating: C. Maximum drying capacity 7kg. Condenser dryer features: 160 minute timer. Including 10 minute cool tumble. 2 dryness levels. Manual control. Reverse tumble option. Reservoir full indicator. Fluff filter. Size H85, W59.5, D58.5cm. Drying programmes Freshen up cycle. Manufacturer's 5 year parts and 1 year labour guarantee. Technical specifications: Energy consumption: 4.48kWh per cycle based on dry cotton cycle. Energy consumption: 336kWh per year based on dry cotton cycle.
please comment on my post or vote for the solution.
Dec 21, 2010 | Indesit Dryers
User manual
www.theusermanualsite.com/ex/mfg/.../indesit/.../manual_request
Apr 22, 2009 | Indesit W 123 Front Load Washer
MANUAL FOR INDESIT 1600 WIL163
I have the solution for your query.
In your browser bar, type in ----
indesit user manuals
Click on---
manuals- user guides- handbooks- indesit service
In the search box enter your model and down load the relavent instructions.
Please leave a fixya rating if you consider my solution appropiate to your problem.
Thankyou.
Jan 29, 2009 | Indesit W 123 Front Load Washer
Cannot work out how to use dryer only
In your browser bar, type in --- indesit user manual
Then in the drop down list click on manuals- user guides- hanbooks
In the search box type in your model number, and you will be able to down load the instructions.
Plz rate my solution.
Thanks.
Jan 24, 2009 | Washing Machines
1s70c indesit condenser dryer still blowing cold after elements replaced
This is most probably due to the thermostats at the rear of the heater failing. There are 2 and must be replaced as a pair.
Jun 17, 2008 | Indesit WA 125 Front Load Washer
Indesit widl126s
Suggestion: Possible your outlet filter is blocked; this needs periodic cleaning, depending on your usage. Clean this out and re-fit. Refer to your users' manual re. where the filter is....
Jun 15, 2007 | Indesit WA 125 Front Load Washer
Washing Machines Logo
29 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
