Question about uk.com
How do i reset the date - uk.com
Time/date won't retain
The camera's internal date/time "backup" battery is supposed to maintain the date/time for about 3 weeks with the camera turned off. If the camera is not used for a longer period, the date/time will need to be reset. If you are having to reset sooner than that, it is likely that the internal battery (not user replacable on most models) has failed.
Aug 20, 2014 | Canon PowerShot Cameras
The Date and Time change back to installation date and programs no longer work
if you have a 4 button spa side remote unplug and see if it continues its called ghosting if so replace controller
Dec 10, 2012 | Jandy Aqualink RS8 Pool/Spa Combo Control...
How do i reset date after battery change? or where can i cet a pdf file a9no calliber number on case or movement but its a timex perpetual with indigo light approx 30 yers old
to reset the date manually, pull the stem out to the second position to reset TIME; manually continue setting time until the date is on the correct day/date.
I had to do this to get back to the proper date when my timex was off by a week. Nothing else worked. 14 times around (twice per 24 hour day) and each time I passed "midnight" the date advanced.
blessings!
Mar 12, 2011 | Timex Watches
How to reset date on optio 410
Please seeks the sub menu of date on camera and reset the date. Otherwise just remove the battery for quite long time to get the date reseted.
Regards
Dec 29, 2010 | Cameras
Reset Date and time
yes its possible. Please remove the internal battery once and then put it inside after few minutes. This will reset the date time. while you switch it on once again. it will prompt you to enter new date and time.
Regards
Sweet Rascal
Jan 28, 2010 | Fuji FinePix J10 Digital Camera
How do iturn the service light of on a sabb 93 2006
on the SID press customise then select system settings then service info and select reset service info. If the option to reset is not there you will need to change the date to a date beyond the 'Days to service', reset option will then appear. when reset, return date to correct setting. (to change date press and hold the info select button when the date is displayed.
Oct 14, 2009 | 2003 Saab 9-3
Unable to change today's date on new Samsung SHG-D980
To change the date select:
menu, settings, time and date.
Drag down the screen until you reach the Date box.
press once, press a second time.
enter the date and press OK
save and exit
hope this works, it worked for me and I had exactly the same problem.
Feb 24, 2009 | Samsung SGH-D980 Cell Phone
Date & time reset
try and enable automatic update of time and date in the settings..
Nov 02, 2008 | Nokia 6300 Cellular Phone
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Oct 22, 2007 | Emerson SmartSet CKS1850 Clock Radio
When the batteries die I have to reset the date and time again in order to take pics! Was there something that I missed or did wrong?!
The manual states that when you change the batteries, you will have to reset the date and time; this is normal operation for this camera (though it is a pain!!!)
Sep 13, 2005 | Epson PhotoPC 850Z Digital Camera
uk.com Logo
111 people viewed this question
Top uk.com Computers & Internet Experts
David Payne
David Payne
Are you an uk.com Computer and Internet Expert? Answer questions, earn points and help others
