Question about Hotpoint Dryers
Condenser dryer getting too hot
First it did not dry and then I reset the red trip switch. It started heating but got too hot and I could see a red glow inside the drum at the back. So unplugged it
    New Friend:
  • 6 Answers
It looks like from what you are saying that the heat sensing thermostat has stuck in the on position and is not switching off when up to temperature!
I would obviously advise you not to use it because There is a serious risk of fire!
The thermostat is most likely mounted on the rear or top of the drum inside it is not an hard job to replace it, but I would advise you replace with exactly the same part and get a competent person to do the repair for you.
If you decide to repair it yourself first make sure it is disconnected from the mains supply and cannot be plugged in while you work on it!
You can perhaps find the part number in the user manual , but failing that remove the part and take to an appliance repair shop for advice
The following link may be of help in identifying the part and may also stock your part?
http://www.ebay.co.uk/itm/THERMOSTAT-CUT-OUT-HOTPOINT-CREDA-INDESIT-TUMBLE-DRYER-KIT-RED-SPOT-/161012863189?pt=UK_Irons_Presses&hash=item257d1d50d5
I hope this was of some help?
Regards
Posted on Apr 17, 2014
  • 351 Answers
SOURCE: tumble dryer wont dry
hi do you have any blockages in the vent system (lint) can you hear the fan running and are the filters clean.did you put it back together correctly.hope this helps.
Posted on Mar 05, 2008
SOURCE: Intermitten Heat up
I would like to thank the ones who responded to giving me a 'hand' in repairing my dryer. I did like you said & changed out the coils & now the dryer is working like it should.
Posted on Apr 12, 2008
MNTECH
  • 1543 Answers
SOURCE: Dryer Heats - Drum Turns - Clothes Don't Dry - Dryer Seems To Over Heat
Before ripping into the dryer, with the dryer running, check the vent outside. There should be a rather strong air flow. I'll bet you have little or maybe no air flow. Check behind the dryer to make sure you don't have squished flex duct. If you have flex pipe, try running the dryer for a few minutes with the dryer pulled out into the room to stretch the vent out, and check outside airflow again. Try to eliminate all or as much of the flex stuff as you can, replacing it with aluminum dryer vent pipe. (tape joints with foil duct tape) Clean out remaining dryer vent. (there are special brushes you can buy to clean out vents, but they really only work on ridgid pipe.)
Posted on Sep 27, 2008
futureloginn
  • 734 Answers
SOURCE: maytag compact dryer low heat doesnot dry. works for hrs clothes still damp.
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
SOURCE: Maytag Neptune MDG 5500 AWQ heats sporatically
GAS DRYER WORK FOR MINUTES AND THAN STOPS!
Posted on Apr 19, 2009
Does Not Shut Off
1st go the the house breaker (dbl breaker) for the dryer and shut it off and turn it back on, your dryer runs on 220 volts of power but if the breaker is partially tripped it may be only running on 110 volts which is only enough power to turn the lights on and to turn the drum the element needs 220 volts to turn on. If it still doesn't heat after resetting the breaker then you may need a heating element or thermostat. The dryer isn't shutting off because it isn't detecting the clothes are getting dry so once you fix your heating problem the dryer should start shutting off on its own again.
Apr 21, 2012 | Roper Dryers
No heat....cleaned filter, vacuum etc....read about a 'reset' buttom, took off back panel, but do no see one......Is there a 'red' reset buttom? thanks
Hello, Welcome to FixYa.
There is indeed a reset or hi-limit as it is sometimes referred to on the element/heater box at the back and it should have a red button in the center you can physically push with Bosch...at least the "nexxt" series.
To start...
**Unplug the dryer before attempting any repair tips suggested here please...safety first**
If you`ve already taken the back of the dryer off to gain access you should have no problem. If you never have, it`ll take some time.
For resetting the hi-limit cut out, you can see through the back vent opening when the vent is removed and then by pushing the red button in...shown below
i.e.
Keep me posted how you make out or if anything is not clear.
Thanks for choosing FixYa and good luck. Please take a moment to rate the assistance provided here for you and a brief testimony on your experience here at FixYa is appreciated as well.
Regards,
Macmarkus :)
Jun 11, 2011 | Bosch Nexxt 500 Dryer
Dried a load fine, next load tumbles wont dry. still cant get heat
Make sure front of dryer is not blocked, air flow is needed to dry.Check that the lint filter and exhaust duct is clean.
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, If one is blown, the dryer may still operate but not heat. Alternatively, the dryer may heat, but it may not heat up as hot as it should. Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jul 02, 2010 | Kenmore 63942 Dryer
Condensing tumble dryer tripping main power switch , power getting to power switch on the machine and buzzing when pushed then tripping at mains. any ideas?
found that moisture is getting to the timer control and causing mains trip!!!!!! need to dry out timer control then all should be well , aided drying with hairdryer, design flaw will cause this on most is70c i think.
Dec 23, 2009 | Dryers
Dryer not heating hot enough to dry
Check for a clog in the piping, Make sure the squirrel fan you replaced not backwards, also visually check an see if the heating element is glowing completly red, if not it's probley getting only 120 volts, not getting 240 volts, if that be the case you'll need a new switch. There are about three switches that could cause that problem, the high temp switch, low temp switch or the timer switch.
Apr 11, 2009 | Crosley CDE6000 Electric Dryer
CDB115
should be a reset switch on the back of the machine usually just a red button or small hole if not there is over heating protection on the heating element or elements if it has 2 heat settings ,but these cannot be reset have to be renewed
Oct 05, 2008 | Candy CNW156 Front Load Washer / Dryer
Splendid washer and condensing dryer combo
Since the clothes ARE getting hot, it's not the tripped breaker(s) mentioned in Solution #2, because these would cut off power to the heating element(s).
Since it's a Condensing dryer, it can't be an obstructed exhaust hose, either (as there is no dryer exhaust).
Remove the lint filter(s). Holding it over a sink, see if water flows through it. The waxes in "dryer sheets" clog lint filters and, even though invisible to the eye, can totally obstruct the air flow and stop a dryer from drying. Wash it with soap and water.
Question: Does your dryer have a small drain hose leading out the back and going down a drain? If it's clogged, the dryer can't remove any more moisture. If there's no drain, then you have an internal "catch tank" to collect the water evaporated out of the clothes. It's supposed to be emptied after every load. Empty it.
If that's not the problem, I suspect your condenser is not working (removing moisture from the hot stream of air blowing through the wet clothes. This could be because: (1) It's clogged - Take out the boxy thing (technically called a heat exchanger) made of thin aluminum "fins" or tubes, and wash it off in the sink. or (2) The little fan that cools the condenser isn't running. In this case you'll need to call a technician. Good luck
Dec 19, 2007 | Hotpoint NBXR463EBWW Electric Dryer
Bosch nexxt 500 series dryer
I just had the same problem, motor runs but no heat. I had a fun time figuring out how take the front panel off, hint the rubber seal comes off easily. It looks like mine tripped the resettable over heat sensor. So far so good.
Jul 30, 2007 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryers Logo
51 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
