Question about Lexmark X Office Equipment & Supplies
Crunching paper Just reloaded paper and is now crunching paper on one side
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 27 Answers
There is most likely to be paper jammed in the side it is crunched.
Posted on Apr 17, 2014
Dell 1320c printer jam
Your paper is probably stuck in the fuser. Open the front, top of printer. There are two blue tabs on either side. You have to remove the fuser and gently pry the paper with your fingers. It's probably crunched up like an accordian. Don't use any implements and don't touch the fuser. GENTLY is the key here.
This probably happened because the paper was too thick or you were printer a full page of ink and the paper got sticky.
Jul 19, 2016 | Dell 1320c Laser Printer
Preprinted 4 part paper crunching up when being printed in epson lq680 printer
Mustafa:
The printer is not meant to use multi-copy carbon invoices. The cause of your problem is the double-feed prevention pad below the paper pickup roller. When the first form is fed, the double feed prevention pad will stop multiple paper feeds. With multi-page carbons, the paper feed roller is trying to feed the form, and is pulling the top page of the form into the feed rollers while the double-feed prevention pad is stopping the bottom form from feeding and the top and bottom pages are sliding because of the carbon paper between the sheets. The only solution that I know of is to buy a printer with a tractor feed and pre-printed fan-fold forms with tractor feed strips on the sides of the forms.
Oct 13, 2012 | Epson LQ 680 Matrix Printer
Paper crunches inside the printer
Check any paper particles jammed in side? open fuser assembly, check teflon sleeve,pressure roller & .. found any damage replace it if available or else replace the fuser assm. Note: Little bit technicality required to do the above said process..
Oct 01, 2011 | HP LaserJet 1100 Printer
My HP laser printer 1300 had a paper jam
When printing or copying, paper will not pick up or feed into the HP LaserJet 1000, 1200 or 1300 series product causing paper jams or wrinkled output. Symptoms are as follows:
  • The pickup roller will spin and try to pick paper.
  • The paper will partially feed into the product accompanied by a crackling, crunching noise then jamming.
  • The paper may feed all the way through the paper path accompanied by a crackling, crunching noise. The output will be skewed and wrinkled.
SOLUTION: Reposition the black Mylar light shields back into the proper position.
  1. Unplug the power cord from the product.
  2. Remove the paper and paper input tray.
  3. Slide hands, palms side up, into the paper input tray cavity (see Figure 1) until the fingertips reach the end of the cavity. Figure 1: Paper input tray cavityc00068598.jpg
  4. Bend fingers up to push the black Mylar light shields back into place. The proper position of the black Mylar light shield will be flat.
  5. Reconnect the power cord.
  6. Print a self-test/configuration page to verify product is functioning correctly.
Feb 24, 2011 | HP LaserJet 1300 Printer
My Pc745 has stopped pulling paper from the tray without crunching it up
try to run paper from the side bypass tray. if still no go, you may have something blocking the paper from feeding. if it feed from the side bypass but not the cassette, paper feed tire may not be feeding paper or the out of paper sensor maybe keeping paper from reaching paper feed tire
Apr 11, 2010 | Canon Office Equipment & Supplies
Paper feeds through crooked and comes out crunched
Make sure the blue slide device on the left side of the paper holder is tight against the paper. If not, the paper will feed corrked.
May 29, 2008 | Epson Stylus Color 740 InkJet Printer
Printer crunching paper
either it's a paper stuck under roller, or along that side of the raceway, or the roller on that side is dirty, and can't grab the paper well.
Feb 25, 2008 | HP LaserJet 1020 Printer
Feeder crunching up paper
I have the same printer. Have you cheked the paper path for the document feeder to make sure there is nothing in the way. Like a label, a torn piece of paper, etc. It really sounds like there is something in the paper path.
Jan 14, 2008 | Lexmark X6170 All-In-One InkJet Printer
Jaming on copier
there is the problem in the heater unit of your machine check it,open the front cover release the blue lock left side and take out the paper
Sep 11, 2007 | Toshiba 2060 Copier
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
