Question about Singer CG500 Mechanical Sewing Machine
Singer CG500 Needle hits the needle plate. Needle was replaced. Verified needle in correctly. Tried hand wheel - still hits. Machine has yet to be used!!
Needle hits the needle plate. Needle was replaced. Verified needle in correctly. Tried hand wheel - still hits. Maybe an adjustment needed inside??
    Problem Solver:
  • 5 Answers
Unless you need all the bells and whistles to sew get you a pre-1930 treadle or handcrank. I have 2 electric Singers, 1947 model 66 and 1948 201-2 both with attachments. Also I have 1903 Singer handcrank made in Scotland. The plastic new one just don't have the ability to hang in there .... All my pre 1930 Singers sew... I love them!
Posted on Apr 17, 2014
  • 76 Answers
SOURCE: alignment of needle.
make sure the needle is positioned correctly and all the way up into the deedle slot. lower by hand and check again, if still doing so you can tilt the needly slightly befor tightning the screw. lower by hand again an see
Posted on Aug 27, 2009
  • 23 Answers
SOURCE: Needle hitting metal casing .. Singer Futura CE 200
It happend to me aswell , not getting the source of the problem!
Then I noticed that the bobbin casing was out of the original position, take the whole casing out and make sure that when you put it back that the small metal tension loop at the front side on the right is correct, this image you can see in your handbook, (placement of the bobbin casing)
Posted on Feb 27, 2009
Mimito7
  • 128 Answers
SOURCE: Singer Simple Shuttle Hook Catching Needle
Sounds to me that your machine is out of time. I recommend you take it to your local repair center.
Posted on May 12, 2009
  • 5 Answers
SOURCE: The needle constantly breaks while embroidering.
My foot does this with different thickness of fabrics, it will make the foot land in different, areas, sometimes making the needle hit the foot. Always check needle position before you start embroidering. once your hoop is ready, check the clearance. I often have to use a small roll of non slip material under the foot handle, the one used to bring the foot down. And I use this to adjust the needle postition so it will always land in the middle of the embroidery foot. There is also a way to adjust the height of the needle arm but that's too complicated to get into here and I've never personally tried it.
Posted on Oct 20, 2009
  • 1788 Answers
SOURCE: Singer Stylist 834
It needs a good cleaning of lint, thread etc. take your bobbin case out and make sure that there is nothing in there. DO NOT TURN YOUR HAND WHEEL BACKWARDS! It will mess up your timing. If you cannot free it up take it for service
Posted on Sep 08, 2010
My needle is hitting the metal plate on a singer cg590 sewing machine. Is there a way to adjust it back into its correct position?
Your needle plate may have been place incorrectly, and it's easy to do. Even the slightest variation can cause the needle to hit it. Try taking the metal plate off and then reseating it -- testing the needle position before you tighten the screws.
Dec 18, 2016 | Singer Sewing Machines
Singer 5532 needle hitting plate how do I fix this
Welcome to sewing. First guess is the needle is loose or got bent. Remove the needle and roll it on a flat surface to look for bends. Although, it would need quite a bend to hit. Jeans require a 110 or larger needle. If the motor strains when crossing the heavy folded areas turn the wheel by hand - you will then know why the motor was straining. Also, sometimes multiple layers require using a seam ripper tool to unsew and then cut out excess layers. It all takes time and patients. Keep at it it's worth it. Consider downloading the manual and carefully review to make sure the machine is threaded right - common beginner mistake.
Feb 10, 2015 | Singer 5532 32-Stitch Heavy Duty Sewing...
Needle breaking
Is the needle all the way up? Are you sure it's actually hitting the bobbin? It MAY--and quite possibly IS--inserted too low in the needle clamp. Make absolutely sure that it's all the way up. Another factor can be your foot--make sure that it's properly inserted and tight, because it's probably hitting the foot and breaking--not the bobbin. In addition, it could be hitting the needle plate. You can determine WHERE it's breaking by manually turning the hand wheel--ALWAYS towards you--several times to see the position of your needle relative to the foot and needle plate.
Aug 15, 2014 | Singer Confidence 7463 Computerized Sewing...
My Singer 6160's needle is hitting the bobbin plate.
first change the needle--flat side to the back of the machine, make sure the needle is inserted all the way up into the needle holder
make sure it's the correct needle for the machine
if the needle keeps hitting the bobbin plate then the machine may be out of time & would have to be take to a sewing machine shop for retiming.
May 03, 2012 | Singer Sewing Machines
I have a singer cxl electronic sewing machine and i have a problem with the needle either not moving or stopping when stitching the larger motifs or the zigzag stitch, somtimes the needle jut moves too...
The needle either not moving or stopping is a sign that the machine is jamming. Here's the answer for the question "My machine is jammed" from the FAQs on Singer's web site at http://www.singerco.com/support/faqs.html
A jammed machine is caused by thread being caught in the hook. Remove the upper thread and the bobbin case, turn the hand wheel towards you (counterclockwise) by hand and remove any thread in the bobbin case area. *Always turn the hand wheel towards you. Turning the hand wheel away from you (clockwise) can cause the machines timing to become unaligned and jam your machine. Also, always make sure the presser foot is in the down position before you start sewing. Sewing with the presser foot in the up position will jam your machine in the bobbin case.
Your description of the needle hitting the plate or foot is an indication that the machine's timing has become unaligned which can be caused as indicated above by turning the hand wheel away from you - the correct way is to *Always turn the hand wheel towards you.
Mar 03, 2011 | Singer Sewing Machines
I have a Singer 7426. The needle is hitting the hook area incorrectly, making a jerking motion with the needle along with a tapping noise. Any idea how to correct it?
the needle probable is bent-has to be replaced so it won't damage the needle bar
if the needle is hitting the needle plate then it needs to be check for burrs, small burrs can snag the fabric
Jul 29, 2010 | Singer 7426 Mechanical Sewing Machine
Alignment of needle.
Aug 27, 2009 | Singer 14SH654
Singer sewing machine Merrit. Needle is hitting something and not going into hole
turn the machine slowly by hand as the needle goes down check it does not hit the foot ,then the hole of the plate.
If it enters the hole and then stops aganst something it is possible the shuttle or bobbin is not in right take them out and replace them again.if the problem prisists take the needle plate off and warch as the needle goes down what it is hitting.
if the hook or shuttle is in the way the timming could be out.
Aug 01, 2008 | Singer 3116 Simple
Singer 7442 - Needle hitting bottom
FIRST DETERMIN NEEDLE BAR POSITION TURN STITCH REGULATOR TO LARGEST STITCH, THEN TURN HAND WHEEL TIL' NEEDLE IS ABOUT TO ENTER NEEDLE PLATE.
AT THIS POINT THE FEED DOGS SHOULD BE JUST AT OR JUST UNDER PLATE. IF SO NEEDLE BAR IS, IN CORRECT POSITION,AND TIMING WILL BE SET AT THE HOOK.
TO SET TIME REMOVE NEEDLE PLATE TURN HAND WHEEL SO NEEDLE IS IN LOWEST POSITION. USING A SMALL RULE RAISE NEEDLE BAR 3/32 OF AN INCH ( OR 3 MM FOR A METRIC RULE) .HOOK POINT SHOULD BE IN CENTER OF NEEDLES WIDTH. LOOSEN THE 2 SHAFT SCREWS
SLIGHTLY,TURN HOOK TIL CENTER OF NEEDLE. TIGHTEN SCREWS. IF NEEDLE BAR IS OUT OF TIME. BRING HOOK TO CENTER OF NEEDLE AND LOOSEN SCREW IN LEFT COVER. RAISE OR LOWER NEEDLE BAR TO SET 3/32OF AN INCH. THE 3/32 MUST BE VERY VERY CLOSE.
Nov 26, 2007 | Singer 7442 Mechanical Sewing Machine
Singer CG500 Mechanical Sewing Machine Logo
180 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
