Question about Whirlpool Ovens
Fans wont turn off
Whirlpool Double Oven Both cooling fans are running. They never turn off. The rest of the oven is fine
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 27 Answers
It could have a faulty wire in it.
Posted on Apr 17, 2014
barkencoa
  • 3463 Answers
SOURCE: oven not heating
You need to replace the fan oven element.
access to it is by removing the rear panel in the oven, there you will see the element.
Plz rate my solution.
Thanks.
Posted on Dec 18, 2008
barkencoa
  • 3463 Answers
SOURCE: noise from fan when electric oven is first turned on
The fans are not normally repairable, but there is no problem obtaining replacements.
On a double oven, there are usually 2 fans fitted.
There is an external cooling fan usually fitted on the top of the oven, you would have to remove the top cover of oven to access it, and possibly the rear panel as well.
Then there is the fan fitted in the main oven compartment.
If you open the oven door as it is working, you should be able to determine if it is the fan oven or the external cooling fan that is the cause of the problem.
If you determine it is the fan in the oven that is noisy, then to undo the fan blade assy, you have unscrew the nut clockwise to remove it. as opposed to the normal way of undoing a nut.
Please rate my fixya solution.
Thanks.
Posted on Feb 09, 2009
SOURCE: No heat from oven but fan and light works
Timer might be blocked on auto, you need to get it back to a manual setting.
Posted on Oct 18, 2009
barkencoa
  • 3463 Answers
SOURCE: Whirlpool double oven has a loud fan when baking
There will be some noise from the fan, but it should not be excessive, if it is really loud, then this is an indication that the fan is failing, and should be replaced ASAP.
Posted on Mar 12, 2010
heatman101
  • 43501 Answers
SOURCE: My whirlpool oven will not heat up, the fan comes
If your electric oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on May 05, 2010
C302U Double Oven cooling fans shut off immediately after finishing bake cycle. Replaced control board, still does the same. What controls the cooling fans to protect the circuitry?
Newer versions of the control board software will run the cooling fans for a bit after the cycle ends, but many older models work like yours does
Aug 30, 2016 | Thermador C302U Electric Double Oven
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
Thermador oven runs but no heat
check the relay board for a bad solder connection on the underside below one of the relays. repair or replace as needed.
Sep 28, 2014 | Thermador SMW272 Electric Double Oven
Have a stoves 720 es main oven fan does not stay on to cool oven after switch off> also the oven will not trun back on when it is still hot or warm ? will
First things first. There are two fans. One in the bottom oven and one to provide background cooling. The background cooling fan turns on when anything is turned on. (Fan oven/top oven/grill). Just operate the top oven for a moment and this should cause the cooling fan to operate. There is a printed circuit board that controls the cooling fan and for how long the fan should stay on once everything has been turned off. (About 7 mins). If this fan is not running then the fan/motor could be faulty, or the circuit board or the resistor on the fan terminal block. The reason the oven will not turn back on is that the residual heat in the oven unit as a whole against the fan oven, is probably too high which causes the overheat device to operate.
You will have to take the oven out of the kitchen carcass, take the top and rear panels off and get an electrician to test and found out which item is not working/failed. Try espares for parts.
Jan 24, 2011 | Stoves 720EF Electric Double Oven
The oven works fine as in it heats up but when turned off the cooling fan keeps going...used it last night and this morning the fan is still on...turned oven on and it is heating up but as I said the fan...
most ovens use a cut in limpet themostat(sometimes called button stat) typically normally open and closed at 40deg c. it will be this that will be not resetting to the open position at room temp. on rarer models the timer controls the cooling fan. some models of aeg and electrolux have a thermal delaying device located in abulb in the wiring loom. hope this helps
Aug 02, 2010 | Ovens
Fan won't shut off after oven cools down
Most fan ovens have a control sensor which allows tthe fan to operate even after you have turned the oven off to prevent overheating.
It sounds as if this sensor has stuck in the closed position thus leaving the fan running .
You will need to replace the fan control unit at the back of the oven.
Dec 31, 2009 | Whirlpool RBD305PD Electric Double Oven
The fans arn't working, have checked the element both visually and with a meter it's ok - any ideas? The cooker is approx 17 yers old, no identifable model on front, single oven
if the elements work but the fans dont are you talking about circotherm main oven fan or cooling fans ? there are 2 if its a double oven ,the age of your oven suggests they are gummed up with carbon after years of use and will have seized up.
hope this helps
Jul 04, 2009 | Neff B1421 Electric Single Oven
Noise from fan when electric oven is first turned on
Thanks.
Feb 09, 2009 | Whirlpool RBD305PD Electric Double Oven
Oven
oven has two fans. the second fan is out of sight and cools the casing. it is operated by a seperate stat. not unusual for it to run for up tohalf hour after switching off. if it runs for an excessive time may be a fault nwith fan stat
Mar 20, 2007 | Bosch HBL 5056 Electric Double Oven
Ovens Logo
63 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
