Question about Olivetti Lettera 35 L Typewriter
What is carriage release?
Definition of carriage
  • 328 Answers
The lever that you depress on the right side to allow you to move the carriage to the left.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Jun 22, 2009
How do you reset the margin on SC-XE6000 when right margin is stuck mid-page width?
Press and hold margin release key while sliding carriage to the left using the carriage release on the end of the carriage, behind the platen (roller) knob, there is one at each end. Put the carriage where you want it and press margin set to reset margin position.
Nov 20, 2014 | Office Equipment & Supplies
Where is the lever that releases the carriage on the olivetti 32
There is a chrome lever on the right side of the carriage on top that should manually release the carriage by pushing down on it. If this works but there is no spring tension pulling the carriage to the left, then the drawband is probably broken. If pushing the lever down doesn't work then eithor the mechanism is broken or locked up or there is a carriage lock that need to be released. If there is a carriage lock it would be located under the carriage on the left or right side. It would be a small chrome lever sticking out the side.
Apr 15, 2013 | Office Equipment & Supplies
Why doesn't my HP OfficeJet 7500A carriage move? It is jammed
Try to turn it off, open cover and move carriage a little bit by hand; don't push too hard. For some time it'll get back to life.
Feb 02, 2013 | HP OfficeJet Office Equipment & Supplies
Hi there, I have a Brother KH950i knitting machine and the carriage has jammed. The carriage release button is also jammed. Do you know if there is another way to release the carriage from the tracks? ...
There is no other way: try to loosen needle by needle. Perhaps you may damage one.
When you have releases the carriage oil the release button. ITry if the button goes smoothly.
Sep 18, 2011 | Crafts & Hobbies
We were trying to locate problem wih sticking carraige when the document feeder was lifted to far and the left side hing sprung so that the cover would not close fully. Is this repairable. I am sure the...
When carriage mechanism fails it need to be repair by a technician.Most carriages systems fail due to bad internal parts,most common the belt that move the carriage.
Mar 01, 2011 | HP OfficeJet 5505 InkJet Printer
How do I replace the carriage belt?
From the service manual:
1. Remove the Left Hand Cover
2. Remove the Right Rear Cover
3. Remove the Right Hand Cover
4. Remove the Tensioner Assembly
5. Pull out Printhead Cleaner Carriage
6. Slide Carriage Assembly to position shown.
7. Lift up the Carriage Cover and remove ALL the Printheads and close the Carriage Cover.
8. Slide the Carriage along the Printer to the position shown.
9. Push in the 2 retaining clips either side of the Printhead Tube Connector.
10. Pull the Printhead Tube Connector towards you.
11. Push the button to release the Printhead Tubes in the Carriage.
12. Release the retaining clip by pulling it away from the holding brackets.
13. Pull the Printhead Tube Connector up between the two Tube Guides.
14. Slide the Carriage to the left side of the Printer.
15. Unclip and remove the Carriage Cover to access the Trailing Cable in the Carriage.
16. Carefully disconnect the Trailing Cable from the connectors in the Carriage PCA. NOTE Remove Trailing Cable
Ferrites if they fall into the Carriage.
17. Remove the Trailing Cables from the Trailing Cable Holder.
TIP Press the Trailing Cables firmly in the center to release.
18. Slide the Trailing Cable Guide out of the Carriage.
19. Slide the Carriage (including the Belt) to the left and out of the Printer.
20. Remove the Belt from the Carriage by releasing it from the retaining clips underneath the Carriage.
As you can see it looks to be a long process. I have the reinstallation instructions as well. If you still want to carry through with this, let me know and I'll send you the service manual....it will be easier than posting the text and the pictures that go along with each step.
Thanks and please take a moment to rate this solution as fixya.
Mar 16, 2009 | HP Designjet 5500 (42 in.) InkJet Printer
Resetting the margins on a manual typewriter.
I can't be for sure if these are auto set margins, but it sounds like they might be. If they are, first move the carriage as far to the right as you can. Hold the Left Margin Set (not Margin Release) lever as you move the carriage all the way to the left. Release the Margin Set Button or Lever. Now hold the Right Margin Set Button or Lever (not the Margin Release), and move the carriage all the way to the right while holding the Margin Set. Once the carriage is all the way to the right, release the Margin Set. Move the carriage to the place you want to set your left margin. Hit the Left Margin Set and then release. Move the carriage to where you want to set the right margin. Hit the Right Margin Set and release it. It gets confusing, but Margin Release does not set margins. Its sole purpose is only to bypass the margins. Hope this helps.
Feb 19, 2009 | Royal MS 25 Typewriter
Carriage return problem
If it returns with the express key the latching mech. on the rt. side is probably gummy. Take off the case, get some WD40 and spray the mechinism that latches the ret on the rt. side below the platen.
DickyO
Dec 08, 2008 | Office Equipment & Supplies
Can't move cassette carriage.
hello savvychris
If you can not get to the carriage motor, can you get to the one of the gears attached to the motor or the carriage gear itself. either of these should allow you to release the carriage.
Can you post some pictures of the carriage, this includes front, top, and side shots? what I am looking for is a way to advance the main motor forwards and thus release the carriage locking system.
If possible, if you have the technical documentation, send me a copy of it, I might be able to figure out what is going on for them.
Thank you,
Shuttle83
Jul 05, 2008 | Televison & Video
Try pressing the margin release key then backspace and reset the left margin.
Jan 14, 2008 | Brother EM-530 Typewriter
Olivetti Lettera 35 L Typewriter Logo
145 people viewed this question
Top Olivetti Office Equipment & Supplies Experts
James Cagle
James Cagle
Marvin
Marvin
Alun Cox
Are you an Olivetti Office Equipment and Supply Expert? Answer questions, earn points and help others
