Question about Husqvarna Garden
Howto install new safety handle
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Husqvarna Master
  • 1,917 Answers
Squeeze the safty bar in till it pop out istall new one squeeze it put one side in then the other
Posted on Jun 06, 2014
I have a craftsman 725 series Briggs and Stratton engine power propelled electric start 22" multi-cut model # 917.370930 that will not move when I pull the handle
ive gotten this one brought into me a few times for this exact problem , seems the problem allways stems from the safety handle cable , stretching and not providing the relief of the safety blade stop break , I just install a new cable on the handle and the trip arm and it works again
Jul 07, 2015 | Craftsman Garden
Why wont rear doors on my mercedes ml420
This is a common problem on the 98 - 2000 models and cannot be repaired. A new door latch will need to be installed.
Jun 26, 2014 | 1998 Mercedes-Benz M-Class
How to get the starter cable to pull out of a brand new lawn mower?
you need to install the cable and safety handle first hold down the handle then it will pull out
Jun 28, 2012 | Troy Bilt 5.5hp Self Propelled Mower
Why won't my Jack La lanne's come on and it's new never been on
If there is not a flaw in the product itself it could be a problem with assembly or that the locking bar is not locked in place properly. The juicer will not operate if the locking bar does not click in to place in to the grooves on both sides of the lid.
Jack LaLanne has several HowTo videos posted that would be worth reviewing:
http://www.powerjuicer.com/power-juicer-how-to-videos.php
You are also able to download a manual which includes illustrated assembly and disassembly instructions:
http://www.powerjuicer.com/power-juicer-manuals.php
If you are unable to lock the locking bar in place it suggests that some other component has not been installed in the correct position. Review the assembly instructions to make sure all pieces are properly positioned.
Thank you for using FixYa!
Oct 15, 2011 | Jack Lalanne Power Juicer 250 Watts
R120 Valve I have good pressure with the cold water but no pressure with hot water
I imagine you have the installation instructions since you just installed it. Your new shower handle has a hot limit safety stop. You can set this with a flat blade screwdriver. The safety stop is the red ring in the handle and all you need to do is pry the ring forward with the screw driver and rotate it clockwise to increase your hot water.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Apr 12, 2011 | American Standard R120 Pressure-Balance...
Hansgrohe 06358620 shower not hot enough
Remove the handle by loosening the screw near the bottom. You should see a plastic ring, probably green, that is the hot water safety. Adjust it so that the handle will turn further for more hot water. It most likely pulls out, then turn it left, reinsert and reattach the handle.
Apr 26, 2010 | Hansgrohe 06358620 Pressure Balance Valve...
How can my computer recognize my new ram i insert?
If it is the correct RAM the System should recognize it automatically. Window on the other hand sometimes get it wrong, To see how much RAM you really have is check as it boots up, that will give you the correct amount. OR again check in BIOS.
Jan 30, 2010 | HP Compaq Presario S5100NX (DM172A#ABA) PC...
Transmission line leak howto change lines
You can easily change these by disconnecting one end from the radiator attach point and the other from the transmission attach point, install the new line, check your transmission fluid level (because you will lose a little when you remove the old line) and your done. Fairly simple procedure. Good luck.
Nov 03, 2009 | 1998 Dodge Grand Caravan
Single handle shower valve.. can't get any hot
factory set is usally cold for safety. remove handle, then remove cover. you will see the mechanism, bunch of plastic teeth, set it up in the middle, then try it, repeat process till you get desired temp
Aug 01, 2009 | Home
Garden Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
