Question about Philips MX5100VR System
Stuck in Mono
So for some reason, my Philips MX5100VR Unit is stuck in mono. More annoyingly, only the audio for the left speaker is coming through. So I've got my left side audio coming through both speakers. I don't have it set up for surround sound or anything. Just stereo. In the menu I found an option called "mono" and it's set to On. I can't turn it off. So I figured maybe a factory reset would fix the problem. Over 2 hours google searching and nothing. Not even the manual tells you how to do a factory reset. So I guess my questions are 1. How do I get it off Mono 2. How do I do a factory reset
  • 66 Answers
Try and press the mono again it might go to stereo
Posted on Apr 20, 2014
ThaMp3Doctor
  • 8596 Answers
SOURCE: only 2 of my 5 speakers are working
Press the SURR button until you get sound on all five speakers. If you don't get sound on all 5, there are a few possibilities:
1) the program you are watching only gets stereo sound or lower (only two or one speaker will play in this case)
2) you need to get a digital audio cable instead of using the red/white AV cable
3) a setting on the TV, cable, or satellite box needs to be changed to allow surround sound in full
Posted on Feb 19, 2008
SOURCE: speakers playing low
open the disc tray and press setup and the speaker volume option will activate and also turn off the night mode for louder sound
Posted on Apr 22, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: i have the philips hts3440/37 none of the speakers work.
Doubtful that it is as serious as a fuse, unless it was working before and now it's not.
Are you getting no sound when watching DVD's? Try adjusting the volume on the home theater system - press the SURR button until it says "Dolby" or something like that.
Make sure it is connected like this:
Posted on Feb 21, 2009
SOURCE: Philips DFR 1500 Service Manual or where to find parts!
how do i turn up the two rear surround speakers on my philips dfr 1500
Posted on Oct 18, 2009
SOURCE: Philips HTS3555 custom settings reset to factory on its own
this happens when the electricity is fully discharged
Posted on Oct 06, 2010
Stereo only playbacks in mono. it used to play stereo
Stereo is actually two identical amplifiers which when the left and right of a stereo signal is fed into the respective inputs will reproduce the stereo sound through the left and right speakers.
Mostly there is a mono/stereo switch so if only a mono signal is available it is reproduced through both speakers.
You don't make it clear whether the playback is in mono or half a stereo?
If playback is in mono it will emerge from both speakers but the directional element will be absent. If the playback is in half a stereo the sound will emerge from one speaker only or mostly one speaker.
Most common problem is the failure of one of the amplifiers which could be electronic or the failure of any of the various switching usually used in such things.
The amplifiers can be tested by injecting a signal into each amplifier input and will be found satisfactory if the sound emerges from each speaker in turn at a similar volume.
Sep 01, 2017 | Audio Players & Recorders
Sound very poor
there could be a few issues. It could be the speakers themselves. I believe this tv has an audio out. I would hook it up to a stereo and see if it that improves it. It could also be something internal like the amplifier. You have a couple options but I would just use a stereo for sound. If you still need more assistance let me know. Please take a moment to accept and rate my solution accordingly.
Thanks,
Lee
Oct 18, 2008 | Philips 42MF130A 42 in. Plasma EDTV
Very little sound coming from the speakers
follow this steps and fix it. God bless you
One of the speaker inputs is not connected. Connect the speaker wiring securely. The BALANCE setting is all the way in one direction. Adjust the BALANCE control. Unit is in MONO mode. Turn off MONO mode.
Oct 11, 2013 | Kenwood Audio Players & Recorders
I am only hearing audio out of my left headphone speaker when plugged into the Tascam US-122. how can I play back my tracks and have the audio fill both speakers?
you might be using a mono output jack or input jack.....check the jack end...1 ring = mono / 2 rings = stereo
make sure your sending a stereo signal in, then check the L/R balance.
Jul 06, 2011 | Tascam US122 Audio/MIDI Interface with...
There are many different "listening modes" integrated on my Kenwood VR-7070 6.1 channel receiver. But i only get both front speakers to work when in "mono" mode. Is there an easy fix?
There is not a "fix" for this selection, MONO is basically a single channel output so there is no seperation for various speakers like left or right which is a stereo effect, mono is like a single speaker sound so you are fortunate to have the sound from 2 speakers but they deliver the same sound.
Jun 10, 2010 | Kenwood VR-7070 Receiver
My tv stuck on mono how to get off mono
On the original TV remote press the "AUDIO" button until it gets to the option "MAIN" and this should get the stereo sound back.
Good luck...
Jan 08, 2010 | iLO IWT3206 TV
Left speaker works in all modes except the tv mode
It sounds like there must be a bad connection on that input. Try switching the left and right input cables for the TV and see if you get the left cahannel working. If so, investigate a possible bad cable or output issue from the TV.
Dec 26, 2009 | Bose 3 2 1 GSX System
I have a theater logic home cinema subwoofer
i do not have this system however i did look up a picture and i can see rows of red and white Mono speaker inputs this is where you would plug in your Mono speakers it does not look like stereo speakers will work plug one mono speaker in a red the other in white i cannot see a port to use it for a computer but if there is look for a round 3.5mm stero jack and if u find one you must have a 3.5mm auido to 3.5mm audio cable put one side in the system and the other in the headphone jack of your computer
Aug 22, 2009 | Philips FR975 Receiver
One speaker only works in Mono mode
I would be checking the set up mode , you might have it set to left or right channel only , but in mono mode both speakers will come on through one channel
May 25, 2009 | Onkyo TX-SR875 Receiver
Sharp Aquos LC-32D44U stuck in ""Mono"
I dont know if this will work for you, but its worth a try. I had the same problem.
1. I changed to a station that was having the problem (an analog station with MONO displayed on the screen).
2. I unplugged the TV for about 15-20 minutes. (I was thinking maybe something needed to refresh, so thats why i unplugged the tv.)
3. I plugged the tv back in and voila. The station showed up as MONO then immediately swtiched to STEREO.
After that, i was able to use the AUDIO feature on the remote to actually change from MONO to SAP, etc.
Ive had my Sharp for about 5 months now, and thats the first time its happend to me. Luckily, i solved the problem...this time.
Hope it helps.
Feb 12, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Philips MX5100VR System Logo
213 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
