Question about Acer AL1511 15" LCD Monitor
Los back ligth - Acer AL1511 15" LCD Monitor
  • Acer Master
  • 3,320 Answers
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Posted on Apr 25, 2014
How do I fix the brake ligths?
Did you check to see if there is a fuse on the brake lights circuit?
If you changed the lamps and the brake switch it is obvious that they are not being energized.
Aug 31, 2015 | Cars & Trucks
DL 160 red ligth alarm hard disc
You could try re-seating the hard drive to see if comes back. Note most configurations on this is set to RAID 1 or 5. Double check before removing drive.
The drive will need to be replaced if the red light comes back (after a few days).
Jan 31, 2013 | HP Computers & Internet
The oven will not heat
sound like the poilt ligth is out.open the bottom you will see the poilt at the back to the top it will be shing try to ligth it from there
Oct 18, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I just recently bought a house with a Tappan Gas Stove model TGF657 and I am having problems lighting the oven. I have never used or seen a gas stove before.
will be very careful went lighting the poilt ligth.ok make sure the gas it on and the knob on the sotve is off raise the hood you should see the poilt ligth between the burners ligth it with a matche in each one go to the bottom open the door there a poitl ligth at the back to the top ligth it
Oct 17, 2010 | Tappan TGF657 Gas Kitchen Range
I change the turn signal lever I took apart unplunged everything carefully put everyhing back together carefully but as I was workig on it I heard my horn honk twice I look no bear wires anywhere finish...
your security system is activated. try turning the key on let set for 10 minutes turn it off then start. on some models it has to be done 3 times on off on off on off start. 10 minutes each time
Jun 22, 2010 | 2000 Chevrolet Tahoe
Do not work-windows, radio,ligths in the rear,ligths in the dash.
Sounds like a fuse.
Should be able to check the fuses visually. Look for one that has the small metallic connecter (center of fuse) burned or broken. You can buy a small package of replacements from a part store. Ensuer the package has the correct fuse (there will be a color to the fuse, as well as an amperage printed on the top (i.e., 4A). Here is an image of what they typically look like: http://www.electronics123.net/amazon/pictures/afu.jpg.
Apr 18, 2010 | 2001 Ford Escape
My reae left tail ligth won'r turn on? the rigth
Check the fuse in the fusebox inside for a blown fuse,the brake lights are working so check the plug going onto the back of the lamp for tightness,could be a loose connection.
Jul 10, 2009 | 2004 Hyundai Tiburon
Status ligth... no ligth at all
to restore to default, use a paperclip and push into the reset hole and hold it there for 20 seconds. everything should be back to default after that.
Apr 05, 2009 | D-Link DSL-G604T Wireless Router
Tengo un carro de estos es el primer aurora que
Que tal!!!! posiblemente es un problema de comprecion y 1995 yo diria que el convertidor catalitico tiene que estar tapado si el sensor de oxigeno esta antes que este tal vez por eso no tienes codigos o check engine ligth on
Mar 04, 2009 | 1995 Oldsmobile Aurora
I don´t see the ligth of the car in the nigth
Have hadlights aimed. Sounds like they are aimed too low. This happens as the sprnigs sag in the front more that in the back due to the increased load on the front.
Aug 09, 2008 | 1988 Toyota Tercel 2 Door
Acer AL1511 15" LCD Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
