Question about Black & Decker Coffee Makers & Espresso Machines
My black and decker coffee maker does not brew and the plate does not heat up. All lights are on
SOURCE: Black & Decker TCM700 Coffee Maker problem
the concept still applies. the heating element is usually dual functional. heating the water then keeping the plate warm.
Posted on Mar 11, 2007
SOURCE: black and decker spacesaver coffee maker
There are two heat stages in the Spacesaver. One is the carafe heater you can see while the other is an assembly within the main housing. This assembly contains a heater, thermostat, and a section of metal tubing with high temperature silicon connectors at each end. when the water storage tank is inserted it fills the heated section of the tube and when activated the water boils as it passes through the one way valve and forces the water into the coffee container. This steam driven surge repeats until all water has been moved to carafe. There are several failure modes associated with this assembly an I have two. 1. is the heater opening which I have and 2. is the thermostat degrading causing incomplete transfer and ultimately no transfer because it brings the temp down prematurely. Another is crud on the check valve so many problems - no solutions
Posted on Jun 01, 2009
  • 9 Answers
SOURCE: Coffee maker won't start brewing process
brew light is off
Posted on Feb 08, 2010
  • 4 Answers
SOURCE: I have a Bunn coffee
The manual for this coffee maker can be found at this link:
http://manualheaven.com/assets/bunn-nhbx-b-contemporary-coffee-maker-manual.pdf
While the manual does not contain repair instructions, it does have some troubleshooting tips to follow if your coffee is not staying hot.
Posted on May 04, 2011
freetek
  • 5568 Answers
SOURCE: my black and decker coffee maker will not turn on to brew coffee
All coffee-makers are provided with a thermal fuse located near the heating element and in series with the element itself.
This device is bullet-shaped with one lead connected to the case, the other insulated from it.
If there was no protection of this kind, it could lead to a fire if the heating element fails to get turned off when reaching its design temperature and nearly impossible to buy as a replacement part.
These are not user replaceable and both the thermal fuse and the bimetal switch that controls the current for the heating element have become increasingly less reliable as they are made in China and since we have little alternative, we have to either keep track of our warranty or just throw it away when it fails.
The fuses can fail at any time and I have brought back three coffee-makers in a five day period, all with the same failure, before giving up and getting a refund.
Another type of failure, namely of the bimetal switch occurs over time and reveals itself by the ever-longer brew time that is unaffected by dissolving the lime in the system.
The heat sensitive metal switch part becomes gradually less responsive causing the machine to just cough instead of pump as when new.
The last one I tossed had reached 40+ minutes per pot.
Posted on Nov 27, 2011
Where can I buy a replacement brew basket for my Black & Decker SDC850? Thank you, Michelle
Black and Decker offers parts through their Spectrum Home Appliances site.
The following link will take you to the site specific to your model. The black brew basket with stainless steel accent for your model runs $8.95 plus shipping. SDC850 SPACEMAKER COFFEE MAKER BLACK
Jan 06, 2015 | Coffee Makers & Espresso Machines
My BLACK & DECKER COFFEE MAKER, PURCHASED 2/17/14, THE PALTE IS PEELING OFF. WHAT IS THE NEXT STEP, WARRENTY?
Afraid you may lose this battle. Peeling means you let liquid drip onto the heating element surface without wiping it up. It then boils or burns on the heating element. Enough times and the high acidity of what you may be brewing and the surface cover is gone. If it's under warranty you contact their 1-800 number and see what they say. If you bought it at Walmart, just take it back for replacement or credit.
Oct 13, 2014 | Black & Decker 12-Cup Programmable...
My black & decker coffee machine stop brewing coffee, sound like is going to keep working but is not .
Does the display work? Does the platter heat up when it is turned on to brew? If yes to both, this string might address the problem. Email me at the posted address if you need the part.
Jan 10, 2011 | Black & Decker Spacemaker 10-Cup Coffee...
I put the coffee on to brew and it stops after a few cups
If the display works and the platter heats up when it is turned on to brew, this might be the problem and solution. Please read both (scroll).
May 30, 2010 | Black & Decker Spacemaker 10-Cup Coffee...
On but won't brew
The heating element may have failed or a connection has worked loose. Chances are slim you'd find anyone even willing to look at one of these. It would cost more to repair than replace.
Apr 10, 2010 | Black & Decker DLX900 12-Cup Coffee Maker
Black and decker coffee maker
what type of coffee maker? does it have a model number?
Dec 11, 2007 | Coffee Makers & Espresso Machines
Coffee does not brew
the heater eleiment is bad or the thermal fuses conncting the elements are blown
Apr 25, 2006 | Black & Decker Cafe Noir DCM1400 Coffee...
All coffe makers have a thermal cutoff fuse located on the bottom heating plate. It is usually in series with one of the leads to the actual heater. This should read "short" with an ohm meter. If it is "open" it needs replacement. They are rated in Degrees celsius, and are sometimes difficult to find. Black and Decker may be able to send you one.
Mar 11, 2006 | Black & Decker TCM700 Coffee Maker
Coffee Makers & Espresso Machines Logo
51 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
iandunn_tms
Henry  Thomas
Henry Thomas
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
