Question about Garden
Huqsvarna 370BFS tries to stall out when throttle is fully opened up
  • Garden Master
  • 2,478 Answers
Check your fuel system. Like fuel filter, vent in fuel cap. FUEL
Posted on Apr 18, 2014
Ryobi s430 will idle but will stall out when throttle opens. This carburetor has one idle adjustment screw and one fuel mixture screw.
Those carbs are a pain. Try arousing the idle screw, turun it to the right, then try to see if it will idle. You will have to tinker with the adjustment screw and the idle screw. Eventually you're gonna need a new carburetor. You can rebuild it, BUT , chances are those cheap carburetors never are the same.
Sep 13, 2015 | Ryobi Garden
I'd like to get step to step instructions on how to clean the throttle body in my 2010 Jeep Patriot
  1. Purchase "02 Sensor Safe" throttle body cleaner spray;
  2. Drive the vehicle a few miles, bringing it to full operating temperature, then park it in your driveway with the engine still running;
  3. Gain access to the throttle body, and hold your thumb on the butterfly linkage so that you can open the throttle butterfly when the engine begins to load;
  4. Begin by spraying throttle body cleaner spray on all linkages around the throttle body. If the engine begins to bog because it is aspirating throttle body cleaner, quickly open the throttle butterfly to keep the engine running.
  5. Once you have cleaned all around the throttle body, spray cleaner DIRECTLY INTO THE THROTTLE BODY, opening the throttle sufficiently to keep the engine running. It will run rough during this process but try not to let the engine stall.
  6. If the engine stalls, restart it, and continue cleaning the throttle throat until you see clean metal.
  7. Pour some fuel system cleaner into the gas tank and drive the car a little more before parking it. Try to find an excuse to accelerate hard, WIDE OPEN THROTTLE momentarily if safely possible (as when accelerating to merge into traffic on a highway).
  8. Drive back home.
  9. Done.
Jul 19, 2014 | Jeep Patriot Cars & Trucks
Hi I have a 2002 Corolla with an apexi, when driving it can start to splutter a bit and I have to put my accelerator down fully just to maintain the revs, then as the car slows I have to change down a gear...
Most common problem is the IAC(Idle Air Control) valve.But if you say some times work I will suspect the throttle is clogged. Remove the Air hose,apply full throttle and hold, spray carburetor cleaner on clot using thin long nose player clean inside wall and throttle. don't spray directly inside because the carb cleaner is to aggressive for some of the gasket.
Good Luck
Apr 03, 2014 | Toyota Corolla Cars & Trucks
Loses power in high gears
run fault codes and look for accelerator position sensor fault . Check for MAP/MAF sensors as well
Feb 18, 2014 | Cars & Trucks
Replaced the battery in my 05 hayabusa now im not getting any power it won't start
Try to clean the throttle body air intake and rev it up a little there may be a blockage that the ECM may have been compensating for when you disconnected the battery the ECM will assume the throttle body is clean and closing fully but dirty carbon may keep throttle open slightly saucing rough running or stalling. Hope this helps
Apr 01, 2012 | Cars & Trucks
My MTD Yard Machine Y2500 starts fine and works with the choke partly closed. It also idles fine with the choke fully closed but stalls when I press on the throttle when the choke is fully closed.
when the choke is fully closed your choking the fuel out,, thats why when you give i t gas it dies , its not supposed to run with the choke on and getting fuel , use the choke only until the motor warms up to operating temp,, then open it,, and you should be fine,
Jun 01, 2011 | Mtd Garden
Saab 9-5 estate: Vehicle starts OK but stalls as soon as "drive" selected. Have to rev in Park then select drive to move off' Stalls again as car slows down to enter roundabout or approach unction....
Looks like a classic idle air control IAC problem. The ECU should normally enrich (prolong the injection cycle) if load is put on the engine such as engaging drive or putting input to the power steering. It can only do this if it knows that the throttle is fully closed according to signals from the throttle position sensor on the throttle shaft end (see the outside of the throttle body at opposite end to the rotary accelerator linkage). The ECU then allows air passed the closed throttle plate> This is doen by two possible ways 1) a motor in the TPS eases the throttle plate open just a fraction or 2) a port on the side wall in front of the throttle plate is connected via an opened IAC valve to an exit port. If it is the valve type, just ensure that everything is clean by using carb. choke spray or WD40 and cloth/brush to remove oily carbon build up. Ensure the valve can open and close freely. If the TPS motor type ensure that everything is very clean and that any micro switch associated with sending 'throttle closed' signal to the ECU is also clean and able to click freely. AS a final measure check all the vacuum lines to the inlet manifold for any leaks, ingress of un-metered air needs to be ruled out as another potential problem source.
Aug 24, 2010 | 1999 Saab 9-5
Cars stalls when A/C on only, radio went dead...
There is a lot of reasons for stalling but start with trying to find any vaccum leaks. Then cleen the throttle plates and if you know what the idle speed control is cleen that too. Also if it has a mass air flow sensor cleen that but be careful don't brake any of the fine wires. Thats a good starting point that the only thing it cost is a can of carb cleen or throttle plates cleener.
Jun 25, 2010 | 1993 Mazda Protege
2006 Envoy stalling when idels and won't stay running
Clean your Throttle body and pay attention to the Idle Air Control (IAC) valve passageway to try to clean the IAC. A dirty or faulty IAC will cause your engine to stall at idle, the job of the IAC is to open the passage way through the throttle body to regulate the amount of air to enter the engine to keep it from stalling when the Envoy is at idle.
Start with the simple and clean the throttle body and inspect any loose or damaged wire leads to the throttle body. Replace or repair any signs of damage.
Thank you for using Fixya and good luck.
Apr 10, 2010 | 2006 GMC Envoy Xl
Honda 750 stalls if throttle is opened unless choke is on.
Hmm , sounds like a vacuum leak, check all the hoses, and the rubber intake manifolds and clamps
Jun 18, 2009 | 1992 Honda CB 750 Nighthawk
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
