Question about Aurora World Aurora AS610C Cross Cut Shredder Shredders
Blockage in forward
My shredder will not work forward I have a blockage tried reverse to clear it but no luck
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 27 Answers
Unplug it from the power then try to push out the blockage useing a scuwer
Posted on Apr 17, 2014
How do you clear a paper jam
Typically the best way to clear a paper jam in a paper shredder is to run it in reverse then forward repeating this as many times as necessary to remove the jam (sort of the same as rocking a car back & forward to get it out of a mud or snow rut). If that doesn't work then the only option is to take the shredder apart and clear it that way!
Good Luck!
Rich Lilja
Mar 16, 2015 | Office Equipment & Supplies
Paper stuck in feed slot
Try running in reverse. If that doesn't help try clearing as much as you can using tweezers. Last option soak the stuck paper with excessive amount of lubricant, it will loosen and soften the blockage and should clear out
Aug 09, 2013 | Epson EPS1200X Shredder
Omnitech only runs in reverse
In the middle of feed opening there is a sensor which in your case will be stuck. Try clear it using tweezers. Failing that soak the blockage up excessively with WD-40 as it will loosen and soften stuck paper leave it for 10-15 minutes, repeat 2-3 times. Then power on the unit and it should be good as new! Good luck
Jul 19, 2013 | Omnitech 10-Sheet Micro-Cut Shredder
My shredex Brute 340 will reverse but will not shred. Can you help?
Hi, try this;
Move the power switch to AUTO (l) position and depress the manual forward button for five seconds to clear paper blockage.
Make sure the paper is engaging the sensor located in the center of the shredder opening.
Regards.
Apr 21, 2011 | Office Equipment & Supplies
Our Olympia paper shredder forward switch does not work but the reverse does.
Move the power switch to AUTO (l) position and depress the manual forward button for five seconds to clear paper blockage. Make sure the paper is engaging sensor located in the center of the shredder opening.
Good luck..
Apr 15, 2011 | Olympia Office Equipment & Supplies
Works in reverse but not forward
Good luck.
Apr 11, 2011 | Cross Infoguard Shredder SX102M
Hi, my Aurora AS1002MSB is jammed and it will only go in reverse. Is there any way to fix it?
Good luck....
Apr 08, 2011 | Aurora Electronics AS1015CD Cross-Cut...
Royal 15MX shredder does not run at all in auto mode. Runs fine in reverse.
There is most likely something blocking your shred gears preventing it from running in forward motion. If you press the feed button will it engage the motor? If not, you will need to have it serviced if you cannot visibly see any blockage. Be sure to unplug this unit before attempting to clear the pathway.
Mar 13, 2011 | Royal 15MX Shredder
Shredder will only go in reverse. Waste bin full warning coming on. Waste bin is empty.
or you can
switch the BLACK and WHITE wires with each other going to the shredder motor, thus when switched it to reverse, it would go foward and shred.
Aug 11, 2010 | Office Equipment & Supplies
Jam that I can't clear with reverse and forward. Just a whine.
Try soaking the blockage with soapy water..seriously!! Soap dissolves paper.
Sep 04, 2009 | Office Equipment & Supplies
Aurora World Aurora AS610C Cross Cut Shredder Shredders Logo
128 people viewed this question
Top Aurora World Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Aurora World Office Equipment and Supply Expert? Answer questions, earn points and help others
