Question about Electrolux Ovens
I purchased a dual chamber Sauter D880 oven (one phase) but I can't make both chamber work at the same time. When is on, the other won't operate.
I purchased a dual chamber Sauter D880 oven (one phase) but when I got it home I discovered that only one chamber works at a time. If the upper chamber is on, the lower chamber doesn't work and vice versa. This was not mentioned at the store or in the user manual. The store and the Sauter service department (Electra) claim this is how the oven is designed ("hil'hati") and they cannot fix it. Surely when sold in Europe both chambers work. According to specifications, the maximum power with both chambers on is about 4kw, which is in the range of the 1-phase power cord. Does anyone know how to over-ride this limitation, and operate both chambers at the same time?
SOURCE: Whirlpool Double Oven RBD305PDB7 - Upper Oven Won't Heat
I have the single oven of this style and I had to replace the thermocouple (part number 4450934) on the back of the oven three times (used the cleaning cycle three times). After using the cleaning cycle, the oven would not heat so each time I had to pull the oven out from the wall to access the back so I could change the part. Once a new part was put on the back of the oven, it worked fine. To pull the oven out, open the oven door and look down by the doors hinges. On each side you will see a screw that's holding the side molding on. Remove the screws and then the molding. That will give you access to the screws that hold the oven into the framing around the oven. Remove the screws and then you can pull the oven out to access the back to change the thermocouple. The oven is heavy so you may want some help to get out. It is not a one man job, maybe a one man and wife job. It is heavy. I hope this helps. Better late than never.
Posted on Nov 24, 2008
SOURCE: Whirlpool range gas model GS445LEMS
i have the same problem oven comes on but goes back off. help
Posted on Nov 27, 2008
  • 127 Answers
SOURCE: kenmore electric range - oven temp low and takes forever to heat
if lower element tests open with continuity meter then it for sure is bad. i would also check the wire ends that connect to the element and/or the control board, they could have loosened allowing a bad connection and low voltage to elementor burnt off.. most ovens do not use the broil element at all during the bake cycle, only during the broil cycle.. some however do utilize the broil element during baking, but at a lower wattage or something..
best of luck,
ttfn
Posted on Oct 25, 2009
  • 8 Answers
SOURCE: The upper oven works fine. The lower oven won't
Make sure you hit the reset switch first... on top of the lower over... behind the panel...they trip easy and "kill" the oven.
Posted on Dec 11, 2009
repairman45
  • 130 Answers
SOURCE: convection upper oven not heating.
I Have worked on quite a few of these in the last few weeks, i have found that about 50% of these problems are caused by the control board and the other 50% caused by the thermal fuse, you can check the fuse by removing the unit from the wall and checking for continuity at the thermal fuse. If the fuse is in fact ok then it is the board that is not sending the correct amount of power to the elements. So the Power Control Board is what will need to be replaced, you can purchase both of these parts at, http://www.reliableparts.com/ by using your model number.
Please rate my solution if it was helpful to you.
If you need more in depth information or pictures on how to remove and take this machine apart, feel free to ask.
Thanks, Repairman45
Posted on Dec 15, 2010
Won't start key symbol flashing
So do you need a manual for operating it ?
Oct 06, 2008 | Gaggenau EB290 Electric Single Oven
Proper Gaggenau EB294 Oven Terminal Block to Cable Harness wiring
If its brand new, most possibly the electrician did not bridge the mains connection.
It sounds like an installation fault.
There is usually a jumper between 1-2-3 on the L connection on the mains, and a jumper between 4-5 on the N connection.
Oshie
Apr 09, 2008 | Gaggenau EB294/295 Electric Double Oven
Electric Phases for Hobart Oven
you must understand this : your electric oven must be indicate if it is a single phase( use 3 wires for 230 2 hot wires + 1 Neutral see the diagram like dryer? you must sure about this. Normally any appliance for home are single phase NOT 3 phase.
2) If you electric oven, say 3 PHASES( use 4 WIRES, 3 hot wires+1 Neutral wires) this for industrial application +comercial 270266c5-a0ad-44dc-9f40-e963255d47f5.jpgNOT for home
However if you system is 3 phase you must need to install 3phase transformer.ba1c9d4d-85e3-4744-8ce5-2f25c6e34ad3.jpg
Jul 18, 2013 | Hobart HEC501-240V Electric Oven
Stove burners don't get hot enough and the oven takes a long time to preheat
sounds like its wired incorrectly .. the stove operates on two phases of 120 volts each .. together they form a 240 volt supply .. if its wired incorrectly you may be getting only 120 volts .. it will then take 4 times as long to heat .. have an electrician or someone skilled in that sort of thing, check the voltage at the plug .. and make sure the pig tail is attached correctly to the stove .. check the circuit breakers .. there is one for each phase .. but if one is tripped then some functions wont work at all unless there is a second problem (shorted phase) in which case it will work but have the 4 times as long to heat problem and it will trip the circuit breaker immediatly .. ..
Oct 01, 2009 | Frigidaire Ovens
We have a Vulcan Roast Oven VO008 and it is wired for 480 volt 3ph, can it be rewired to be 240 volt single phase?
It could be but, the expense of replacing all the 3 phase controls would cost more than what it would be worth. Sell it and use the proceeds to purchase a single phase unit or if you are wanting to use it in a commercial building, see if you can have 3 phase installed by your electric provider.
Jul 07, 2009 | Ovens
Ovens Logo
47 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
