The nokia c1 01 i brought from uk is not working in pakistan when i put the pakistani sim it says sim restrection
Your Nokia C1-01 brought in UK has been restricted to some network. It needs to be unlocked from network restriction and not jailbreak. To remove the network restriction, You need to enter it's unique unlock code. You can get the unique unlock code for a Nokia C1-01 from
TheUnlockArena.Com at affordable cost with easy unlocking guide. Good luck.
SOURCE: unlocke code on nokia 6120 classic 3
Your phone is equipped with one or more codes to protect it against
unauthorized use. Please note that the security code, which protects
the phone itself, differs from the PIN code, which protects the SIM
card.
If your phone is prompting you for a security code and you have not activated one, please try the following
If your phone still requests a security code, please bring it to the nearest Nokia Care point for inspection.
SOURCE: nokia 6120 clasicc 3 country code
Dear Customer,
same problem having in india also ,
so you have to go to nokia branded service center than tell them to unlock your fone for using in pakistan you can tell him/her that you ahd got this molile from gifted so they will do for you with some documents they needed so,
you can do this,& having funn with your new 6120 ..
THNX
SOURCE: How to use other Sim in Tessco Mobile (Nokia 6300)? How to Unlock it??
actually it wont work bcos it has tobe cracked it has to be done in only big nokia authorised shop and they will give the restriction code and then u can use it
SOURCE: i bought nokia n97 from uk but this cell is not
it may be due to network lock, contact service provider , else you can get unlock codes here http://www.onlinegsmunlock.com/nokia-n97/rs7wp9/
you need to specify network provider
