Question about Samsung 1.5 Ton Rotary Compressor 18k Btu R-410 208/230 V. 1 Phase 60 Hz new
Please give wiring diagram to wire compressor model UG5A240JUBEM
The compressor is new it hasnt got a cap please assist about wiring
    New Friend:
    Problem Solver:
  • 5 Answers
Your compressor is going to probably require at least a run capacitor wired between the start and run windings. You need to contact the manufactuer to determin the correct size
Posted on Apr 27, 2014
New Brunswick Model G-33 variable speed Gryrotory Shaker Wiring Diagram.
Can you provide the make, model and year information. Without that information, it is impossible to give you the assistance you need.
Sep 07, 2015 | Cars & Trucks
COLEMAN A/C mod. 2436-901 compressor motor hummes but doesn't start. need wiring diagram or info. on starting capactor value inforfation in cover has deteriorated.
I cannot find your model, and wiring diagrams for Coleman are not easy to get. I think best solution is contacting Coleman and asking a copy of the service manual
Jun 22, 2008 | Coleman Heating & Cooling
HVAC fan is on, but the compressor attempts but will not start
Sounds like you have a condensing unit that has a lock up condition; commonly known as "Locked Rotor'.
A simple step would be to be sure the compressor is cool.
Start the unit, and as it try's to start, bump the compressor on the shell sideways to jar it , with a rubber mallet.
If the compressor starts... it may or may not start again at one point.
You can try adding a start assist, or commonly known as a Hard Start Kit. It's simple and the two wires go on the Run Capacitor In parallel with the wires with the compressor wires.
Usually the capacitor has a C common ..F fan.... and M motor terminals . The start assist wires piggyback on Common C and M motor. NOT THE FAN side of the run cap.
http://www.grainger.com/product/SUPCO-Hard-Start-Kit-4E240
Apr 30, 2014 | Heating & Cooling
97 nissan pickup p0605
Code 605 is for a problem with the engine computer.
You could have a problem with one of the injectors or one of the plug wires may not be firing at the right time.
Mar 04, 2013 | Cars & Trucks
1994 ford tempo runs rough at ldel
try giving it a tune up, new spark plugs, wires, cap, rotor, and a new air filter, also the fuel filter if it hasnt been replaced in a while
Mar 26, 2012 | 1994 Ford Tempo
Need capacitor wiring diagram
No model number gotta shoot from the hip on this one:
The cap has 3 sections: Herm for compressor, F for fan, and C for common.
The common section of the cap gets a hot wire off the power cord, a wire from compressor marked C on compressor and a white common wire from the fan gets connected to C on that cap. These wires are almost always white in color on American OEM. The fan has a small brown wire that connects to F on tha cap. The compressor has a wire marked S on it make a note of that color wire and connect it to the section on the cap called HERM. Herm stands for hermedtically sealed compressor. So both your commons and a hot wire go to C. You need one small brown wire which goes to F from the fan. One wire marked S on the compressor goes to Herm for compressor starting. S stands for start winding.
Lets look at typical American fan motor wires: The fan has a black wire for high speed a blue wire for medium and a red wire for low. It has white wire for common, and a brown wire for capacitor. Connect your common fan wire to common and the brown wire to F.
With that cap properly connected basically all you would need to do to make it run is connect a fan speed, the compressor wire marked R for RUN, and and the other power wire.
Jul 20, 2011 | Fedders AEY08F2FCOM Wall/Window Air...
This is a question for anyone who will know the answer. http://www.fixya.com/support/t2331151-old_capassitor_3_prongs_new_capassitor_2 our problem is the same however there are only 3 wires on the new...
3 wire capacitors are usually supply ( Power in), start winding and run winding. If the wiring is mixed up, the compressor wont start. On some machines, the capacitor is a multi feed cap, which supplies power to the fan as well as the start winding of the compressor. I suggest you contact someone who can read a wiring diagram to determine which one you have. All Makes usually have a wiring diagram behind or near the cover plate where the electrical terminations are.
Jul 03, 2011 | Heating & Cooling
I've made some additional checks in the air conditioner. After checking the capacitor, it appears to be okay. The compressor input winding measures 2.6 ohms. The starter assist unit when measured...
Never ohmed a capacitor. But, your compressor should not need the start cap. Take it off completely and run machine. Not sure of your problem either but to ohm a compressor, common to start + common to run should = start to run. To test a capacitor without the capabilities of mfd on your meter measure the amps on the herm wire × 2650 = ?? Divide that by the volts across common and herm. This will give you the mfd rating. Same with fan amps × 2650 =?? ÷ volts = mfds. Remember, not the amps off the contactor...the amp reading on the cap wire. Good luck!!
Jun 12, 2017 | Fedders A6Q10F2B Q Chassis Room Air...
Require wiring diagram to fit new compressor
give me model and serial number of refrigerator and model number of compressor and i will put one together and send it to you. Let me know if I can help.
Feb 21, 2011 | Maytag MSD2756G Side by Side Refrigerator
Need the wiring diagram for capacitors on a IR model 2475N7.5
Hi my name is Luke and I bought a Ingersoll-Rand 7.5 compressor and won’t start. I noticed it has a wire not connected on the capacitors it’s a blue wire that reads t5 v3 there’s a capacitor with open prong before two start caps and another capacitor after the two start caps , at least that’s what it reads on caps unless they have been wired wrong , being that I would think the start up caps should be wired first from powers supply box , want to know where it went Before I went trying to change capacitors and there’s 5 here’s a pic
Jan 01, 2011 | Ingersoll Rand - Rand - Ir 2545K10FP Type...
Samsung 1.5 Ton Rotary Compressor 18k Btu R-410 208/230 V. 1 Phase 60 Hz new Logo
114 people viewed this question
Top Samsung Heating & Cooling Experts
Nyte_Ryder
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
