Question about Superstar Radio Communications
I have an HR 2510 that shows no dead key watts on AM ????
Modulates fine on AM just not showing any deadkey watts and sideband works good showing watts with a deadkey and when modulating all other functions working fine.
  • peppeard Jun 19, 2009
    How's it going, thanks for your reply. I don't see a modulation kit installed, and knobs are correct. I was wondering if someone might have turned something down. I'm getting around 12 W on AM when modulating, and nothing with a dead key. And sideband working fine with about 25 close to 30 w. Thanks again as this is a fairy new hobby for me and learning on my own.
  • 36 Answers
This sounds exactly backwards, you should have a carrier on AM with some forward swing, on SSB (sideband) there should be no carrier & all modulation (forward swing). Could you have the settings mixed up or has somebody put a modulation kit in your radio & messed something up or maybe one of the knobs has been removed & not replaced correctly ? Just a couple of things you might look into.
Posted on Jun 19, 2009
  • Mojorisin65 Jun 19, 2009
    If you are getting good radio reports I would not change a thing, it sounds like your radio has been set up to drive the heck out of a tube amp. I used to set radio's up just like this to drive a linear, but I don't have a schematic for this radio & could not walk you thru it, if you are sounding bad try turning the mic gain down & or the volume on your power mic (if it is equipped with one). You have a great radio there that is capable of outstanding performance. Here's a link http://incolor.inebraska.com/jshorney/25... If this doesn't help looks like she's gonna have to go to the shop.
    Unit 563
    Mr. Mojorisin
What watt dead key and swing on CONNEX 3300 HP
A standard 3300 hp I seen get up to 40 watts peak,
normally I would turn the audio pot up all the way never snip anything and deadkey down to 2 watts. Than adjust for forward swing, I also never run a pwr mic. Good luck
Apr 20, 2015 | Connex Radio Communications
What is Dead Key on a CB Radio?
Deadkey is slang it is CW or Carrier wave which is RF power produced before modulation/audio is mixed in which stimulates PEP wattage slang being SWING WATTS. A Watt Meter is used to measure it which is often a combination device Wattage/SWR/Modulation meter.
May 08, 2013 | Galaxy Radios DX-949 CB Mob ssb Swr...
I HAVE A GRANT LT WORKS FINE ON AM NEEDLE NEVER MOVES WHEN YOU KEY UP ON SIDEBAND
Beware that there is no carrier or deadkey on sideband. So there will be no meter movement until you add audio.
Nov 28, 2011 | Uniden GRANTLT 40-Channels Base CB Radio
Need to know where to set low power set up for amp thanks
There is no specific dead key setting for an ampifier. Each amplifier requires different dead key to operate at it peak effeciency AND to sound the best it can. If I knew what type of amp it was I could give you a better idea. Just for a reference point I will give you these numbers. For your basic amplifier ( 2 pill - 4 pill non high-drive) you could safely set the carrier at 1 - 3 watts. This is why the majic number for most people is a 2 watt dead key. For a High-Drive amplifier you really have a broad range of settings for deadkey. Generally anywhere between 2 - 8 watts. Some can even handle 10 watts. This DOES NOT mean that they need a HIGH dead key to operate properly. Just FYI, what you run into with improper dead key is either a really choppy, splattery, overmodulated sound with a deadkey that is to low, OR, a really pinched up, tight sound with a dead key that is to high. Also, a HIGH dead key can cause an amplifier to over heat, causing the transistors (pills) to fail prematurely.
To set your dead key "properly" you really should have a technician "match up" the radio with the amplifier. This means, he will hook up the radio and amp that you plan to use with one another in line and tune (set dead key) the radio to "match" the amp. This will give you the optimal audio and performance without overdriving the amp.
Hope this helped. Lost Jeep, Athens GA, 10-7 !!
Feb 17, 2011 | Connex 3300 240-Channels Base CB Radio
Can a 19 ultra power be turned down to 1 watt? If so where?
Yes it can, but it requires the addition of some components. It isn't really a straight forward install. It needs some reworking. In my opinion, not worth the trouble.
Sounds like you want to run a linear amplifier. If you really want to run an amp, get a better radio to do it. There really is no other reason to lower the dead key that low. Also, 1 watt might be too low. May not drive the amp well.
If you just want to make the radio swing, 1 watt is way way too low. You will have barely any carrier and the radio will sound like ****. That radio stock dead keys 2.5 watts. That's perfect for swing. Now you just need to have more modulation. Find DM1 and unsolder 1 leg and pull it out of the board. Now you will have full modulation. You will deadkey 2.5 and swing to about 15 watts.
If you want to run an amp, get a good radio. If you like cobra, get a cobra 29. They are fairly cheap, and sound amazing. As well it is real easy to lower the dead key in that radio.
Nov 12, 2010 | Cobra 19 Ultra II CB Radio
Cobra 2000 with a d 104 mic and a palomor tx100 bi linear amp...how can if possible make the amp key up with less than one watt on the ssb side..Radio has a 4 watt dead key on am and i have ajusted the...
Hi, my name is John. Adjust the radio to key 1 watt, then switch to SSB on radio,then switch to SSB on amp, key down and adjust to 1 watt on amp. enjoy !!!!!! ...hope this was very helpful....
Aug 31, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
Hp 2510 printer will reset, i have the hr glass showing
Can not find permanent fix, but with my 2510 if I unplug it for about 1/2 - 1 hour it starts properly.
Until the next power shortage of course, than I have to repeat the process
Jun 29, 2009 | HP PSC 2510 All-In-One InkJet Printer
ONLY 2 WATTS DEAD KEY AFTER BEING PEEKED/TUNED AND MOD KIT.
it sound that a can has been set of balance, or the output  transister has crashed. did you up grade the output before ajusting for more output.
May 20, 2009 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Kl 203 rm italy linear amp transmitt
You just have to lower your RF power so that the radio is putting out about a 2 watt dead key. Any higher and you will over drive the finals and burn out the final
Apr 24, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Radio Communications Logo
276 people viewed this question
Top Superstar Radio Communications Experts
Andrew Taylor
Andrew Taylor
Mike carichael
Level 1 Expert
Brian Franklin
Brian Franklin
Level 1 Expert
Are you a Superstar Radio Communication Expert? Answer questions, earn points and help others
