Question about Lofra MXGC96GGI/CV Dual Fuel (Electric and Gas) Kitchen Range
LOFRA mx76GG1/C HOW DO I DISMANTLE /REASSEMBLE OVEN DOOR TO CLEAN INSIDE THE GLASS? Thanks, Simon.
SOURCE: Hi, We have a Lofra oven. The door no longer
Sorry,
you are screwed I am in the same position. Tonight I am going to the store where I bought it with a baseball bat and intend to smash the owners legs.
Posted on Nov 17, 2009
  • 4 Answers
SOURCE: Hi, I have a Lofra Model 51440401 MG 96 GG/Cn.
Have the hinges and springs definitely gone? I only ask because Lofra oven doors have a reasonably awkward fitting method. If you don't get the anti rotation hooks sorted out correctly. There is a manual online that may help. http://www.lofra.it/manuali/manualeITA_ING.pdf you would need to check page 44 of this pdf file to just see what I mean. Other than that I have not seen these as spares anywhere, So I apologise if I have wasted your time.
Posted on Nov 18, 2009
SOURCE: lofra five burner gas cooker, oven door not closing properly,
I had the same problem and took the door apart. The hinge has a spring inside which is held in place by a long rivet. The metal of the rivet is too soft and it bends and snaps. You cannot get a replacement hinge anywhere. I even tried Italy and France. Lofra won't speak to you by e-mail or phone. The next thing that happened was the element disintegrated in the ovan. These are the worst cookers on the market.
Posted on Dec 12, 2009
SOURCE: Hi I have LOFRA
There's one being auctioned (ends Fri 14th) that might be ideal for spares http://tinyurl.com/2drkcg5
Hope this helps
Posted on Jan 10, 2011
SOURCE: Hi I have a Lofra
Hi Gemma, this is Carlos from Lofra of Brazil. I would recommend you to contact our headquarters in Italy to help you locate the needed part for your range.
Please write to consumerservice@lofra.it or call +39 049 9904811.
Kind regards,
Carlos Fleischfresser
Lofra Sud America
Posted on Jan 19, 2011
How do i clean the inside the glass on my oven door
The door usually has about 4 to 8 screws on the inside. Remove the door first by opening it to 45' and lift it off its hinges. Sit it on top of the stove carefully after putting an old towel and a garbage bag on top of it. Remove the screws in the door and the inside will lift off the outside skin. Clean the glass with oven cleaner and reassemble. Ours needs doing too!
Feb 11, 2016 | Ovens
How do i clean between glass doors on bottom oven of fagor fb1982x4 ?
disassemble door , clean glass , reassemble. door.
Jul 27, 2014 | Fagor Ovens
How dismantle oven door to clean between glass panels?
The glass is a supposedly sealed unit that should not be removed for maintenance. This is a common failing of ovens with glass panels.
Mar 03, 2013 | Jenn-Air JGS8860BDP Stainless Steel Gas...
Spill between glass panes on oven door
The only way to clean this is to dismantle the door. Most brands you can remove the door and set it on a counter to dismantle. This can be very complicated, depending on the brand and model. Leaving the gravy inside the door won't hurt the range, and self cleaning usually will not clean this completely. It usually just bakes it on harder. Good Luck Appliance Specialists
Dec 31, 2009 | Kitchen Ranges
The glass on the inside of the oven door has fell away while i was cleaning it,can not see any way of putting it back on,is it glued on?
that is your heat safety glass if the outer pane is still there,you will need to dismantle the oven door and reseat it in its frame in the oven door,the screws are on top of door and on inside when door is down,im sure you'll find it..and dont run self clean w/o safety glass in place,outer glass wont take the extreme heat of self clean feature
Jul 24, 2009 | Ovens
How do I clean the glass inside the oven door. Have tried to get to glass with no sucess? I have runs on the inside that will not disapear? Thanks
Open the door to the first notch. Lift it straight up off the hinges. Next, you'll have to dismantle the door. Remove all the screws around it and the glass will be held in by another frame. Unscrew the frame, clean the window and reverse for reassembly.
Apr 22, 2009 | Kenmore 30169 Electric Single Oven
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Aug 19, 2008 | LG MV-1444Y Microwave Oven
Siemens microwave oven HB86k.70b
I have the same problem, have you found out the cause?
Regards
May 04, 2008 | Ovens
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Lofra MXGC96GGI/CV Dual Fuel (Electric and Gas) Kitchen Range Logo
55 people viewed this question
Top Lofra Kitchen Ranges Experts
paulcarew
ray gallant
David Ellis Rhea
Are you a Lofra Kitchen Range Expert? Answer questions, earn points and help others
