Question about Vehicle Parts & Accessories
1999 mercedes cl500 shakes violently when driving over 40 and it feels like the steering wheel is gonna come off in my hands. Also I just replaced the brake pads but they don't seem to be any better t
If you have any advice or possible solutions please share them. Thanks so much!!
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 189 Answers
Have the front end checked
Posted on Sep 06, 2014
5 Suggested Answers
  • 52 Answers
SOURCE: Dear Mercedes-Benz Experts I have mercedes
most likely one or more of your brake rotors were warped (bent) stepping on the brake transfers this into a shake or vibration
Posted on Jul 26, 2011
sxygaman
  • 95 Answers
SOURCE: Passenger front tire continues to turn in when the steering wheel stops
check rack and pionon for wear also check tie rod ends
Posted on Aug 30, 2012
perkins48
  • 14378 Answers
SOURCE: binding front brakes
Calibers needing replacing,always replace both.
Posted on Nov 06, 2012
  • 62 Answers
SOURCE: right rear brake rotor gets hot and smokes after wheel vibration over 65 mph,
Sounds like rear wheels bearings are failing, allowing the rotor to make contact with the brake pads. Remove the brake pads and caliper, and check for wheel bearing play. The caliper and pads can mask a bearing problem, by keeping the play down to a minimum. until higher speeds are reached. It is a dangerous situation, with a potential for a serious auto accident.
Posted on Apr 06, 2014
How do i fix the violent shimmy shaking of veichli and steering wheel between 40-50 mph
iginition time is set too late, ********, readjust.2) spark plugs are fouled or incorrect gapped. 3) distributors contct poits are dirty or pitted.
God bless you
Jun 17, 2012 | 1994 Jeep Grand Cherokee
While driving dwn the road i hve a bad shake in my steering wheel i have a 1999 gmc yukon
it sounds like the front tires need balancing.if you drive the truck slowly(creeping down the road at about 5mph)and lightly holding the steering wheel do you feel the steering wheel moving back and forth.this could indicate a bad belt in a tire where as a wheel imbalance won`t show up at this low of a speed,but a bad belt will.also have the front end checked for worn front end components and wheel bearings,this can cause a bad shake too.
Apr 20, 2011 | 1999 GMC Yukon
My 99 jeep cherokee shakes in front end around 60mph
You didn't supply a lot of info but generally a consistent shake at a particular speed is caused by wheel balance being off. Before having the balance checked look at the wheels inside and outside. Many times you can get either mud or ice packed in that will disturb the balance.
If balance is good, then you need to have the front end components checked for wear. If the shaking is very violent, it may be what's known as "death wobble" which can stem from excessive wear of components, usually either ball joints or track bar but everything's suspect. If you have that you can't mistake it as the steering wheel feels like it is trying to rip right out of your hands!!!.
Feb 13, 2011 | 1999 Jeep Cherokee
1999 Jeep-violent shaking of steering wheel when braking at 55 mph and then stops when speed lowers to say 40 mph. Only on highway, not streets. When first happened, installed new rotors and brakes, but...
1. out of balance tire because it sounds speed spacific.
2. worst of all! Loose lug nuts or possibly loose spindle nut. (you will need to lift the wheel off the ground to tell)
3. worn linkages i.e. ball joints, steering linkage, anything that would allow play in the front wheels.
Nov 08, 2010 | 1999 Jeep Grand Cherokee
I have a problem with the steering wheel shaking violently "sometimes" when I brake. I've had numberous trips to my dealer and they say they cannot replicate the problem. It is unsafe to drive, and I...
it happen in slow speed or high speed, do brake padel vibrate at same time when you feel steering shaking. if you tell me clear then only i can answer you, if steering shakes in slove speed it is problem with tyre ( fr both tyre need to replace) and if it happen with high speed it could be problem with wheel balancing, get wheel balancing done for fr both tyre, if problem not solved , please let me kmnow. thanks.
Aug 17, 2010 | 2007 Chevrolet HHR Special Edition
When driving the car shakes violently...when turn
It could be tires need balanced, but more likely it's one of your cv joints. That is basically a "drive shaft" on front wheel drive vehicles.
Feb 17, 2010 | 1999 Volkswagen Passat
Shake in steering wheel
I believe you need your disk brake rotors turned to be true again or have them replaced. Whe you use your brakes a lot and kit puddles of cold water then it will warp the rotors which will cause the violent shaking. You may not feel it in the brake pedal even if it is warped rotors. If you don't think you have warped rotors then you should be very careful driving it because it will probably be in the steering sector arm or the idler arm on the steering shaft.
Dale
Jan 04, 2009 | 2006 Nissan Xterra
Sounds like your brake rotors.You dont have to feel it in the pedal to get a shake in the wheel.
Nov 26, 2008 | 2004 GMC Savana
Vehicle Parts & Accessories Logo
41 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
