Question about Chayes/Virginia La siesta Chair Base Motor
Descending chair the chair will be raised to a certain level and then will start to slowly descend. What will cause this? how to repair and cost?
Can i drive in other gears on the highway besides being in drive...I have a 99 Lincoln continental? ?
you should use the highest gear possible to allow over drive to kick in, other gears will slow and limit the speed you can drive ,and stress the tranny
May 06, 2015 | 1999 Lincoln Continental
2x^3-3x (a) state whether the polynomial is a monomial,binomial, trinomial, or none of these. (b) state whether it is in descending or ascending order. provide a reasons for your answer
a) It is a 3rd degree binomial because there are only 2 terms.
b) It is in descending order because the degree of each term goes down as you read the expression from left to right
May 23, 2014 | Office Equipment & Supplies
I have a Pacemaster Gold treadmill that will not hold elevation. I have no error codes. It will go to the proper elevation and then immediately start descending. If I change the elevation setting it will...
Run the utility software calibration for easy diagnostic, and fix it.
Go to HOOD open the cover motor and follow the steps indicated. or your owner manual.
God bless you
Sep 30, 2013 | PaceMaster Gold Elite Treadmill Upper...
Should I pick a fixed length or an adjustable pole?
Fixed-length poles are popular due to their light weight, but you need to be certain of the length you need before buying. Adjustable poles are slightly heavier and have the advantage of a choice of pole lengths while ascending or descending steep outdoor terrain.
Sep 04, 2012 | Coleman Camping, Backpacking & Hiking
While coming calls the ring tone is not properly working...the is raising and slowing down.please help me
Go to the settings option and then select your profile and then personalize,then in the ringtone option it would be set as descending,set it as ringing and your problem is gone..:)
Dec 11, 2010 | Nokia E63 Cell Phone
Sound in my laptop keep descending
Sometimes Flash player interferes with the sound volume. (ascending and descending back and forth)
Uninstall flash player> reinstall
Apr 27, 2010 | HP Compaq Presario V3000T Notebook
Needle skips
A needle is a precision part. Look to see if the needle has a conical point descending from the cartridge needle carrier. If not, replace the needle.
*Always protect the needle while you adjust things!
Pressure is essential for the needle to track. Turn the weight down until the needle just floats above the record. Zero the weight by turning just the weight indicator, not the weight. Now turn the weight to add 1.2 to 1.5 grams. (Always use the manufacturer's recommended weight if different!)
A level surface is important. Make sure the turntable is level.
Test the arm bearings:
Adjust the weight until the arm floats. With a feather, gently push the arm towards the center. Now gently push it back. The arm should move smoothly with no hesitation and easily. Reset the weight to 1.5 grams or less.
If your cabinet is moving when you walk around, the records will skip. Find a different place for the turntable or don't walk around. In severe cases, raise the weight to 1.75 to 2 grams, but this wears the needle fast an can cause distortion.
Mar 22, 2010 | ION Audio Vinyl Recording Turntable
Volume keeps descending to zero. it plays for a
It sound like a faulty volume switch, it could be the one on the radio or the one on the steering wheel.
Nov 27, 2009 | Car Audio & Video
Microsoft FSX - Aircraft flies "Nose-up"
This is a calibration issue for the controller you are using. Recalibrate it. It is receiving and elevator down instruction.
Mar 27, 2009 | Microsoft Flight Simulator X for Windows
Chayes/Virginia La siesta Chair Base Motor Logo
97 people viewed this question
Top Chayes/Virginia Medical Experts
Andrew Taylor
Andrew Taylor
Are you a Chayes/Virginia Medical Expert? Answer questions, earn points and help others
