Question about Panasonic Lumix DMC-FZ28 Digital Camera
My Panasonic Lumix DMC-FZ28 will not power on, although the battery has been charged.
    Sergeant:
  • 231 Answers
Previously posted and asked question. Does unit do anything?
Remove and replace battery.
Posted on Dec 24, 2014
SOURCE: Looking for viewfinder is blurry (Panasonic Lumix DMC FZ28)
There's a small dial on the left side of the viewfinder (next to the flash button) that allows you to focus the viewfinder. I only found it because I had the same problem - must have knocked it out of focus by accident!
Posted on Dec 31, 2009
SOURCE: Lumix dmc-ts1 will not turn on after taking underwater pictures
I had the same problem, half way through snorkelling the screen just went black and the camera wouldnt turn back on, HELP PLEASE!!!
Posted on Mar 07, 2010
rajdeepdutta
  • 2517 Answers
SOURCE: when i turn on my panasonic lumix dmc fz28 it shows system error
HI there the camera lens guide pin is damages and thats why not zoom the image properly . You got the system error message. So you need to replaced or repair the lens guide pin. Thanks.
Posted on Apr 01, 2010
  • 1705 Answers
SOURCE: windows 7 compatible driver for panasonic lumix camera dmc-ls70
You need to go to the lumix website and follow links to support and/or downloads for drivers.
Posted on May 02, 2010
ZJLimited
  • 17970 Answers
SOURCE: Panasonic Lumix DMC-FH20 shows "SYSTEM ERROR
Sounds like the Focus and Optical Image Stabilization drive motors are bound or broken. To fix this wrong will need disasemble the lens unit, focousing unit to do service; if needs, replace the damaged parts and assemble to run normally. Don't do this if your camera is under warranty.
Or, unless there are no marks on the case and they wouldn't think that it had been dropped or gotten wet, well you know, Panasonic will normaly repair or replace it as long as it is due to manufacture defect.
Hope this helps.
Posted on Jun 22, 2011
More than one possibility can cause this. Your battery can be on the end of life. Only when the battery works in another camera, of the same model, you can check the capacity. Or with a multimeter, but you must have some electronic skills. Then the contacts on both the battery and in the camera can be dirty or oxidised. Sometimes users manage to put in a battery the wrong way around. This should be virtually impossible with your camera. Try cleaning the contacts in the camera and on the battery, using some cotton swabs. Never use anything sharp.
Then again try charging the battery. Look if the charger light starts green. And is it stops after some time. If you already charged the battery, it could be the light goes out after a few minutes.
If the charger light starts flashing, you know something is wrong with the battery to the connectors. Don't forget to close the battery cover correct. There is a switch, and if the door is not locked correct this switch still indicates open battery door and the camera won't switch on. Check your manual page 17 and 18.
Apr 17, 2014 | Panasonic Lumix DMC-FZ28 Digital Camera
Where do I load 2 batteries in the digipower rapid charger
Panasonic DMW-BCG10, DMW-BCG10E, DMW-BCG10PP Battery, Technical Specification: Battery Type: Li-ion, Voltage: 3.60V, Capacity: 895mAh. Dimension: 41.60 x 30.40 x 9.40 mm, Product Type: Replacement Battery (Brand New). Compatible with: Panasonic Lumix DMC-TZ10 Series, Panasonic Lumix DMC-TZ18 Series, Panasonic Lumix DMC-TZ20 Series, Panasonic Lumix DMC-ZR1 Series, Panasonic Lumix DMC-ZR3 Series, Panasonic Lumix DMC-ZS1 Series , Panasonic Lumix DMC-ZS10 Series, Panasonic Lumix DMC-ZS3 Series, Panasonic Lumix DMC-ZS8 Series, Panasonic Lumix DMC-ZX1 Series, Panasonic Lumix DMC-ZX3 Series. Panasonic Lumix DMC-TZ22, Panasonic Lumix DMC-TZ6, DMC-TZ8 and Panasonic Lumix DMC-ZS5, DMC-ZS7.
Panasonic DMW-BCG10 Battery
Jun 04, 2012 | Digipower Battery Charger
Using instructions required
You can download the Panasonic Lumix DMC-FZ8 Manual ( Operating Instructions) here:
Panasonic Lumix DMC-FZ8 digital camera Operating Instrutions (10.7MB)
Have fun :)
Apr 18, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
INSTRUCTION
Download Instruction Manual of DMC-FZ28 from Panasonic Support.
Jan 02, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Panasonic Lumix DMC-FZ28 Digital Camera Logo
126 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
