Question about Kipor Electrical Supplies
Would like to adjust the voltage parameters. Generator switches on and off randomly.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
Check oil sensor
Posted on May 09, 2014
How to adjust output voltage on Honda 3000 generator
Hal, you may be able to adjust some what by changing engine RPM(throttle *****) and playing with the governor if need be with no load and with load.
Portable generator voltage regulator
Onan generator adjustment run speed voltage
https://mtspowerproducts.com/admin/data_sheet/SS321Manual%20II.pdf
Mar 27, 2016 | Powerboss 020309 3000 psi 2.5...
Automobile headlamp bulb often burned
Filaments often burn out, the reasons are: voltage regulator has fault, the voltage is too high; bad contact battery wire, causing the generator no-load voltage is too high; the generator armature and field coil short circuit. If you open the light switch, the bulb burned out immediately, you should check the charging circuit has no circuit. If often burned out light bulbs, check voltage generator voltage regulator is adjusted too high. we also support wholesale bump at online store
Dec 20, 2013 | Cars & Trucks
High voltage rpm power generator output
Not sure what you mean "high voltage rpm power generator out", however many people have asked how to adjust the engine for proper voltage output. On generators with~out a voltage regulator, I adjust the engine RPM by using a digital voltage meter that has a Hz setting. Adjust the governor untill the meter displays 60 Hz. With the geneator producing 60 cycles, I know that the engine is turning 3600 rpm (the engine produces max hp when it is turning 3600 rpm). At this point, read the voltage output to verify that the range is between 115 ~ 120. On generators with a voltage regulator, verify/adjust that generator is producing 60 cycles then adjust voltage by turning screw at the regulator (some regulators are sealed with potting compound and can not be adjusted). If your power demands are not that great and you appliance can operate at 50 cycles, adjust governor as needed. Lowering to 50 cycles will also reduce output voltage. Good luck
Oct 10, 2011 | Coleman Powermate Powermate 5000W...
7 hp brigs engine on my generator runs two fast producing 127 volts. how do I slow it down?
Hi and welcome to FixYa. I am Kelly. Since you did not mention the make or model number of your generator I will respond in generic terms. If your generator is at 127 volts with NO load it is adjust at the very top end of the manufacturers limits. There is a 10% tolerance so 120 VAC + 12 is 127 VAC. Under an electrical load above 500 watts the generator should drop the output voltage slightly so your generator would still be within factory limits. Personally on any generator as a repair person; I set the output voltage at 126 VAC no load so that when the user puts the generator to work the output voltage is good. If your generator is running at 127 VAC under load then you can adjust the governor screw on the governor plate CCW about 1/2 turn to drop the voltage. Without a generator model number or engine number I can not tell you exactly where the governor plate is on your engine / generator. The screw will have a lock nut that you must loosen 1/4 turn then turn the adjustment screw CCW to drop the voltage. Just make sure to re-tighten the lock nut when the adjustments are complete. Mind you by decreasing the output voltage you also drop the output freqency at the same time you decrease the output voltage. It is better to have 125 -127 VAC under a no load condition as the more electrical load you add the more voltage drop you will notice. It is best to adjust the generator to 122.5 -123 VAC under a medium load. (50% of output capacity) A bread toaster is 1400 - 1600 watts and is a good load for a 3000 watt generator. Also a good hand held hair dryer will use around 1600 watts. If you use this type of load and the voltage output is 122.5 to 123 VAC I would not adjust anything. I have been working on generators since 1970 so this is nothing new for me. I hope that you understand everything I posted. If not, feel free to ask as many questions as you wish in any future response.
Thanks for choosing FixYa,
Kelly
Jan 08, 2011 | Craftsman Electrical Supplies
Code UU
Here is the code explained direct from Kohler's manual. I'd disconnect the generator load first.
UU Undervoltage Shutdown occurs if the voltage falls below 80% of the nominal system voltage for more than seconds. Check wiring and connections.
Reduce the load and restart the generator set. —
Check wiring and Check controller configuration, system voltage
and frequency (parameter UU).
Check AC voltage and adjust, if necessary. 5.7
Replace the SCR module and test voltage again. 4.9
Separately excite unit. 5.2
Check stator continuity
See web site for manual :http://www.kohlerpower.com/onlinecatalog/pdf/tp6196.pdf
Jul 11, 2010 | Kohler 12 kW Emergency Power System -...
When I run my generator - a Yamaha EF2400S to my Zantrex Model MS2000, it will not accept the power to charge my batteries. The generator's voltage and frequency, when checked, are within acceptable...
the power coming from your generator is probably "dirty", full of spikes and surges from the generator. If it accepts shore power and not gen power, then the generator is the most likely cause. If the generator in unregulated, you are stuck, but it could have a failing voltage regulator board, or Yamaha may have a solution.
Jan 09, 2010 | Xantrex Technology Heart Freedom 25...
Low voltage
Most generators use a flyball type governor within the engine to control rpm; also there is a voltage regulator that tries to maintain voltage at about 115v. The voltage regulator varies the voltage to the armature increasing /adjusting magnetic force. Use a meter with htz or freq setting to adjust engine governor to 60 cycles. When the generator is producing 60 cycles, the engine should be turning 3600 rpm, max power range. At 3600 rpm the voltage should be 115 to 120 volts. Loading the generator will cause governor to try to maintain 3600 rpm. Check engine manual for proper adjustment of gonvernor and linkage. The governor mech should last the life of the engine, however governor system does wear out. Expensive repair. enjoy
Nov 26, 2008 | Yamaha Electrical Supplies
MAF Enhancer
as in any electronic circuit there has to be a path to and from a componant. the ecm sends a signal along the red wire it will have a certain voltage parameter. the ecm is expecting a return signal of the same voltage if it doesn't get it it will either throw a code if there is no return voltage value or if there is but it is outside the parameters then it will adjust to compensate. there is no need for such an extender ring. the resister should be on the red(imput signal). please rate the solution.. thanks
Sep 21, 2008 | 2004 Volkswagen Jetta
Galaxy 88hl stuck on 24.178
Hello radiogeek,
it sounds like you have a bad voltage regulator since you are indicating that the voltage adjusted by L17 is random. Check all of your voltages from the power supply (regulator side), and make sure they are stable. You will find that you may have a bad voltage regulation circuit or a bad capacitor in the unit power supply.
Thank you,
Shuttle83
Nov 26, 2007 | Galaxy Radios DX- 88HL Base CB Radio
Function switch doesn't work
This is due to switch malfunction problem. Dust and corrosions shows these type of problem. Make one general service by technical person. Or if you have keypad lock system in your menu options lock your keypad control. The TV will work.
Aug 28, 2007 | Toshiba 32A33 32" TV
Electrical Supplies Logo
56 people viewed this question
Top Kipor Electrical Supplies Experts
jhnolson
Jay Finke
Jay Finke
Chuck Graybill
Are you a Kipor Electrical Supply Expert? Answer questions, earn points and help others
