Question about Which Way Is Down Productions Android Apps
I HAVE A PROBLEM WITH THE 2001 E320 MBZ , THIS CAR IS EVERYTHING PERFECT BUT WHEN THE IGN SWICH IS TURNED ON THE CHECK ENGINE LIGHT DOES NOT ON , WHAT CAN I DO, THE FUESES IS GOOD , THE PULB LAMPS IS GOOD
  • 32 Answers
SOURCE: engine light 1999 mercedes e320
Most likely a gas cap or emissions issue, if you are sure the car is running fine. But you will have to have it scanned to know for sure.
Posted on Nov 14, 2008
SOURCE: 99 mercedes e320.check engine light on.po341
that appears to be a camshaft position sensor performance code. you can start by checking to see if the sensor is working properly, re-check and make sure that the harness is ok by checking the resistance through the harness if all looks well there make sure the computer has the latest software on it by having it scanned at your local dealer. also you can check the reluctor wheel on the camshaft for damage or debris in the way of the sensor.
hope this helps!
Posted on Feb 17, 2009
  • 396 Answers
SOURCE: 2001 Isuzu Rodeo Check Engine Light flashes when accelerating.
I would change the trans flter, trans fluid, and have the linkage on the trans adjusted.
Posted on Jul 21, 2009
wracefans24
  • 1985 Answers
SOURCE: 2001 Ford Taurus - Check engine light sporadic
what is the battery voltage with no headlights on and car running with a multimeter and your light on the dash on?
what is the voltage at battery with car running and headlights on with a multimeter?
It sounds like it is overcharging,
Posted on Jan 11, 2010
ghost45
  • 1280 Answers
SOURCE: the check engine light came
The check engine light is still on because the code hasen't been cleared/erased (or, an insufficient number of 'key' cycles hasn't occurred yet. Let me know the code, & I'll get back to you.
Posted on Feb 08, 2011
Chlaster lights come on when ign switch turned on .light switch off .replaced light swich the same .
This car has a CAN-bus electronic system. Suggest you invest in a cheap OBD fault code reader from Amazon or eBay. This will help you pinpoint the problem.
May 23, 2016 | 2008 Opel Corsa 1.4
Car was running fine turned it off then tried to turn it on again and there was no power or anything. Checked battery and has a full charg
CAR NO START PROBLEMS:-----
It can be the issue with weak battery or faulty battery or if battery is ok,then its faulty starter causing the issue.
From start to end troubleshooting these problem i suggest you to click the link below and follow its procedure:-----
What to Do When Car Turns Over But Won't Start?
http://technoanswers.blogspot.com/2012/11/what-to-do-when-car-turns-over-but-wont.html
Car starting issues?
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
Car Starting Problems
http://whoisbyme.blogspot.in/2012/06/car-starting-problems.html
1991 Toyota Trecel: Engine Starts fine but dies when gets Warm?
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
1994 Toyota Pickup: Starts fine but dies in few seconds?
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
1999 Chrysler Cirrus: 8 IGN Fuel Starter Fuse Blows?
http://whatisbyme.blogspot.in/2012/06/1999-chrysler-cirrus-8-ign-fuel-starter.html
2001 Toyota Camry: No start After replacing Battery?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-camry-no-start-after.html
1989 Toyota Pickup Truck: Turns over but not start?
http://whatisbyme.blogspot.in/2012/05/1989-toyota-pickup-truck-turns-over-but.html
Car dead and will not Start?
http://whatisbyme.blogspot.in/2012/05/car-dead-and-will-not-start.html
1995 Lexus LS400: Running Hot?
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
2001 Toyota Prius will not start?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-prius-will-not-start.html
1996 Jeep Grand Cherokee: Engine will not start?
http://repairhelpcenter.blogspot.in/2012/06/1996-jeep-grand-cherokee-engine-will.html
Mitsubishi will not start
http://www.howtorepairguide.com
These will help.
Thanks.
Nov 28, 2012 | 2010 Ford Edge
1999 M-B E320 drives great for about 5 or 600 miles then as i'm driving the check engine light comes on and the car looses power and idles rough like it wants to stall.It does not stall though.We
When the check engine light is turned on by the powertrain control module (computer) a fault code is stored to record what it is that caused the fault, in order to begin the process of diagnosis of this problem you have you must have the control module scanned for the stored codes.
Feb 07, 2012 | 1999 Mercedes-Benz E-Class
Car occassionally ran really rough-rpm went lo after a few mins. returned to normal.. Replaced the ign wires and 3 ign coils. Had a check engine light for years and have had an idndication that the mass...
Your problem was (most likely) the mass air-flow sensor. Try disconnecting the sensor, the car should run at default values. This will turn on your check engine light on again but it will indicate that the sensor should be replaced. You can clear the light with a scanner or disconnect the battery again.
Sep 01, 2011 | 1997 Mercedes-Benz C-Class
The cruise control on my 2001 Mitsubishi Montero Sport XS is not working after I took my car in for a complete interior / exterior detailing. What do you suggest I check? It has worked beautifully since...
well the first thing is to check all your fuses, then i would take a look under the hood for any broken or disconnected vacuum lines,this is what i would check first, hope this is helpful.
May 13, 2010 | 2001 Mitsubishi Montero Sport 4WD
CHANGING THE HEADLIGHT ON AN E320 MBZ
It pretty straight forward of you open the hood and look at the back of the headlamp. You see a metal clip right where the wiring harness plugs into the back of the lamp. Just take a common screw driver and pop the clip out (be careful you don't pop the clip down into oblivion as it does tend to spring out with a bit of force.) The clip is held in place by two star headed screws. You do not need to mess with these, just pop the clip out from under the screw head. I assume it will say something to this effect when you buy the new bulb but be sure not to touch it directly with your skin as the oils in your skin will shorten the bulb's life considerably.
Oct 01, 2009 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
1995 e320 mbz
ihave a diesel e320 won't start
Jul 28, 2008 | Mercedes-Benz E320 Cars & Trucks
Android Apps Logo
46 people viewed this question
Top Which Way Is Down Productions Apps Experts
Are you a Which Way Is Down Productions App Expert? Answer questions, earn points and help others
