Question about Gateway FPD2275W LCD Monitor
Problem with my monitor
I have had this computer for about 6 months one red dot appeared on the monitor and now a blue ones there aswell i contacted acer about it but they said as long as its not right in the middle of my screen i need not worry is that true
  • 328 Answers
There is no reason that a monitor only 6 months old should cause problems like this. Either Acer should fix your monitor or you have a video card problem. Bringing your monitor to a computer tech place may be a good start. They should be able to hook it up and see if it does the same thing on their computer and FOR FREE. If the problem clears up on their computer, your video card or driver is defective.
Posted on Nov 02, 2007
Red blue and green patterning on the monitor
You can try switching out the VGA cable (the one with the blue connectors on each end). If this does not work, try a factory reset on your monitor.
Oct 15, 2012 | Dell Dimension E521 AMD Athlon 64 X2...
What does it mean by dead cells?
I assume this is related to your LCD monitor.
I think you mean dead pixels. The LCD monitor has tiny pixel elements, one for each red, blue, green color and each one of these colored pixels are turnes on by a transistor. When a transistor fails then the colored pixel it controls does not light up. This is a dead pixel and it shows up as a tiny black dot.
If the screen displays a blue screen, a dead blue pixel will appear as a tiny black dot in the blue screen.
You normally would not notice a few dead pixels unless they are grouped together.
Sep 20, 2010 | Hanns.G Corporation HW191D 19" LCD Monitor
I hav buyed a new acer v173 lcd monitor,and used upto 10 months till now.Lastday when i switch on my lcd,it showed the Acer logo , and suddenly the color of the screen changed,now the lcd works but i could...
Sounds like a problem with the video board of the monitor. I would contact Acer, since it less than 3 yrs old, tell them the problem that you are having get an RMA number and they will fix it for free. You only have to pay for shipping it back. Hope this helps.
Jul 29, 2010 | Acer V173 b Monitor
My monitor has gone from a beautiful, sharp screen to one that is faded and blurry. It is only about 6 months old. Is there an adjustment that can be made?
Hello Katherine ann, hi, the faded and blurry picture is usually caused by poor LCD panel connections, due to loose contacts and screws. This is usually poor ventilation, or factory defects. Since you mention its only 6 months old, it is still cover for warranty, call your dealer for service.
Mar 24, 2010 | Acer 22" X223w LCD Monitor
I have an old acer monitor model 7134T, the problem is its 15-pin connector (that plugs into cpu) is broken and i want to repair it. Can anyone tell which color wire goes to which pin #?
A female DE15 socket (videocard side). Pin 1 RED Red video Pin 2 GREEN Green video Pin 3 BLUE Blue video Pin 4 ID2/RES formerly Monitor ID bit 2, reserved since E-DDC Pin 5 GND Ground (HSync) Pin 6 RED_RTN Red return Pin 7 GREEN_RTN Green return Pin 8 BLUE_RTN Blue return Pin 9 KEY/PWR formerly key, now +5V DC Pin 10 GND Ground (VSync, DDC) Pin 11 ID0/RES formerly Monitor ID bit 0, reserved since E-DDC Pin 12 ID1/SDA formerly Monitor ID bit 1, I²Cdata since DDC2 Pin 13 HSync Horizontal sync Pin 14 VSync Vertical sync Pin 15 ID3/SCL formerly Monitor ID bit 3, I²Cclock since DDC2
Feb 16, 2010 | Acer Computers & Internet
Magenta vertical stripe sets plus grid dots problem
Try using a diffrent computer on this and see if its not the video card doing it or if not its the controller board inside that connect to the video card that would need to be replaced at this time, if there are no dead or stuck pixels it might be worth replacing rather then buying a new one.
May 14, 2009 | Acer P191WBD LCD Monitor
Scheme for the VGA Cable of Acer AL1511eb
You will have to buy a 13 Pin Din Male Connector cord. Use the break-down below to help with reconfiguring.
Pin 1 RED Red video Pin 2 GREEN Green video Pin 3 BLUE Blue video Pin 4 N/C Not connected Pin 5 GND Ground (HSync) Pin 6 RED_RTN Red return Pin 7 GREEN_RTN Green return Pin 8 BLUE_RTN Blue return Pin 9 +5 V +5 V DC Pin 10 GND Ground (VSync, DDC) Pin 11 N/C Not connected Pin 12 SDA I²C data Pin 13 HSync Horizontal sync Pin 14 VSync Vertical sync Pin 15 SCL I²C clock
Nov 24, 2008 | Computers & Internet
Hi, About 6 months ago my screen developed a vertical dotted line down the screen. It has since developed two more - another blue and a red one. I'm not sure if this is a major issue or warning of...
hi if its an LCD monitor then its a fault of the screen itself if its under warranty then return it. If not You could try updating video drivers but i believe this is not the problem...proberly new monitor needed im afraid
Nov 01, 2008 | Computers & Internet
Gateway FPD2275W LCD Monitor Logo
63 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
