Question about Cameras
Flash nikonos sb 103
Is it possible to use the Nikonos SB 103 in combination with and triggered by a slave-unit. I have an Olympus UW system camera with an Inox flash and want to use the Nikonos Flash SB 103 as a second flash that should be triggered via an slave-unit by the Inon flash. Is there any slave-unit that exists and fits on the Nikonos and that will give its light together with the Inon flash?
  • Paul Dokter
    Paul Dokter Apr 19, 2014
    The Nikonos SB 103 has, as far as I know, no build-in slave function. So I wonder does a slave-unit excist for use in conjunction with the flash SB 103 and build for use underwater. The flash is already nearly 20 years old but still functioning as where it new, but firing it with a slave-unit underwater is something I'vve never done. And I don't seem to be able to find an apparatus that can do the job.
4 Suggested Answers
mastertech48
  • 149 Answers
SOURCE: nikonos v with Nikon 15mm f/2.8N UW-Nikkor IC... > for sale
Good lord! That's a NICE underwater system you've got. What type of help are you asking for? Just from your equipment list, if everything is in good condition, you've got at least 1500.00 worth of stuff! A new 15mm sells for $2,240, the camera, new, $750.00, eiklite flash system is up there, the extra close up gear ain't cheap either! And a pelican case--well, if yer gonna go snorkeling or scuba, you're all set! The 28mm can be used for land lubbing or underwater. To properly prepare the camera, the most important thing is to check the condition of the o-ring around the film door. If any doubt, replace it!! The same applies with any other o-ring seal. *Properly* greased, an O-ring in good condition simply looks wet. Use a good quality, pure, silicone grease all over the ring and don't blob it on--It can be purchased just about anywhere. Check the o-rings on all the other equipment--same rule applies. Salt water damage is u-g-l-y. Before opening up the camera after being in salt water, rinse all equipment in fresh water and dry completely. Don't detach any cords or lenses until all are rinsed and dry! (When cameras and salt water come together improperly, think horror movie acid bath results--and you won't be far off) I used 36-picture rolls of film so I wouldn't have to open the cam as much. Heh, in the excitement of photoing fish, yer gonna burn some film.Hope I assisted you!---Rick
Posted on Oct 02, 2009
Obertelli
  • 3006 Answers
SOURCE: can I use this unit with the Nikon SB-28 flash??
If it's a slave flash then it's fine as it has no physical connection to your camera. It simply fires when it senses the flash firing from your SB-28.
Posted on May 15, 2010
SOURCE: are the sb-900 and the sb-800 heads the same? I
No it is not the same. the SB 900 is 25% bigger.
I just got a Coco ring for my SB 800 (I bougth the one for the SB 900) and it is big. But I just filled the empty space with hard foam and works wonders. I can post a photo if you want.
By the way I have a D 700. It migth fit different in other cameras.
Posted on Feb 03, 2011
Which slave-unit to use for firing my Nikonos SB 103 underwater flash
Another SB103 they work together you have to set one to slave
The other in command mode
Apr 17, 2014 | Nikonos SB-105 UW TTL Speedlight Set 11202...
SB105 connector broken
Yes you are right when broken it does not work properly
Feb 10, 2014 | Nikon 2 Sets Of Nikonos Sb 105 Strobes
Ttl auto does not work
Digital Camera Fully Compatible, Newly Developed S-TTL System "S-TTL" enables TTL auto shooting by an external strobe for a digital SLR camera as well as for a point & shoot digital camera.
INON S-TTL auto strobe supports any manufactures' model providing highly accurate exposure control.
Film camera era without strobe selection problem TTL stands for "Through The Lens" and TTL auto strobe system controls flash amount to provide correct exposure based on calculation by camera's internal sensor metering reflecting strobe light from a subject through the lens. This TTL system meters actual light amount reflecting from a subject providing accurate exposure.
When we start with the history of underwater TTL auto strobe, underwater camera?"NIKONOS V" released in 1984 was the first to provide automatic TTL flash control for underwater strobe SB-102, SB-103 succeeded by NIKONOS V compatible underwater strobes form other manufactures. The 5 pin electrical sync connector for NIKONOS V is most popular and widely adopted to connect an underwater strobe and underwater film camera (underwater camera/housing).
A film SLR camera has flexibility to select an underwater strobe. As far as housing has NIKONOS type electrical sync connector and properly wired, automatic TTL flash control is usable with any TTL auto strobe like Nikon SB-105, INON Z-220, Z-22 connected via electrical sync cable.
NIKONOS type 5 pin electrical sync connector and NIKONOS V with INON Z-22 strobe
Film camera compatible strobe is not usable for a digital camera!? Underwater TTL strobe circumstances have been drastically altered with the spread of digital camera among divers. Some underwater housing for digital SLR camera has NIKONOS type electrical 5 pin sync connector as same as film camera housing. Since the housing has same NIKONOS type sync connector, existing film camera compatible underwater strobe has been considered compatible with a digital SLR camera via 5 pin sync cable but happened to experience error message on the digital camera or blackout on an image even the strobe worked. Why this happened?
This is because automatic TTL strobe system difference between a film camera and a digital camera.
The film TTL auto system makes single flash while digital TTL auto system employs pre-flash type making two to three flashes. Film TTL auto strobe system starts firing at the same time the shutter opens and reflecting strobe light from a subject is recived at a film. The reflecting light on the film is metered by the sensor to determine when to cease firing for correct exposure. This process takes only about 1/1000 second.
In contrast, digital TTL auto strobe system can not calculate adequate exposure based on reflecting light from a subject since image sensor (CCD/CMOS) reflectivity is comparably low comparing to a film. So digital TTL strobe system gives preliminary flash for very short period of time (pre-flash) just before the shutter opens metering reflecting light from a subject by the sensor to calculate necessary amount of light for correct exposure and starts emitting main flash at the same time the shutter opens. Canon E-TTL and Nikon i-TTL employs this system.
When we connect conventional film camera compatible TTL strobe to pre-flash type digital SLR via sync cable, the strobe makes full dump by pre-flash signal then the shutter opens before the strobe has been fully charged resulting in quite under exposed image only with ambient light. Even two time flash compatible strobe like INON Z-220 strobe, does not fully support a digital TTL and force to use Manual flash mode.
Film SLR:
A strobe starts firing at the same time the shutter opens and quenches firing when correct exposure has been obtained.
A film compatible TTL strobe connected to a pre-flash type digital SLR via electrical cable flashes does not support TTL auto exposure resulting in synchronization only with first pre-flash or totally uncontrollable.
The birth of digital fully compatible S-TTL S-TTL auto compatible INON D-2000 strobe and Z-240 strobe works in TTL auto mode by simply setting their main dial to S-TTL position. A film camera seems to depend more on photographer's skill, experience and feel since the camera does not allow checking images on site. A digital camera allows us to check images right after shooting and enable to try to shoot again as much as we like. And high capacity memory card further allows to shoot hundreds of images. The digital camera makes entry level of underwater photography getting down and nowadays more people buy a digital SLR camera and underwater housing even they have just started underwater photography. However underwater photography gets more difficult because underwater strobe does not work in TTL auto.
INON is among the first to support digital TTL auto system with "S-TTL" auto mode equipped D-2000 strobe and Z-240 strobe.
The proper name of S-TTL is "Optical Synch TTL". S-TTL enables to perform in TTL auto exposure as same as genuine TTL strobe from camera manufacture, based on camera's built-in flash light to use as a signal to be transmitted to a strobe. S-TTL uses digital camera's built-in flash light not as a light source but as like a controller to trigger S-TTL strobe.
The built-in flash of a digital camera makes weak flash (pre-flash) before main-flash to calculate exposure. This pre-flash is transmitted to S-TTL strobe to control the strobe to make pre-flash to a subject. The reflecting light from the subject goes through the camera's master lens to an image sensor then a processor calculates main flash light amount for correct exposure.?Finally the built-in flash makes main-flash which is transmitted to the S-TTL strobe to cause main-flash of the S-TTL strobe.
Digital camera's built-in flash lights are transmitted via an optical fiber to the
S-TTL strobe to make pre-flash and main-flash instead of the built-in flash.
Apr 30, 2010 | Olympus FL-20 TTL Flash
The flash is not in sync with my nikon d40 anymore. It fires first. Pictures come out dark. The camera itself takes great flash pictures
It sounds like you're trying to use the SB-600 off camera, as a slave flash. While the SB-600 does indeed have slave capability, the D40 does not have the ability to function as a commander. Thus, the SB-600 is being triggered by the D40's pre-flash.
As stated above, the D40 does not function in commander mode. You can mount an SB-800 or SB-900 flash unit, which will function as a commander as well as a flash. Or you can mount an SU-800 commander unit.
Alternatively, you can switch the D40 to manual flash mode so as to eliminiate the preflash. However, you will then have to calculate the proper exposure yourself.
Dec 31, 2009 | Nikon Speedlight SB-600 TTL Flash
Sync Nikon SB-800 speedlight with studio lights
keep the Sb 800on the camera hot shoe and elichrome will trigger automati or use a slave unit
Oct 20, 2009 | Nikon Speedlight SB-800 TTL Flash
Nikonos v with Nikon 15mm f/2.8N UW-Nikkor IC... > for sale
Oct 02, 2009 | Nikon 15mm f/2.8N UW-Nikkor IC Lens
I HAVE NO IDEA WHAT I HAVE HERE... I
Hey LELAH,
This lens is intended for a Nikon underwater camera which are branded as Nikonos cameras. These cameras are underwater 35mm cameras and this lens is and extreme wide angle lens to capture underwater scenic’s. This lens is rather expensive and of very high quality. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 17, 2008 | Nikon 15mm f/2.8N UW-Nikkor IC Lens
Cameras Logo
42 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
