Question about Toshiba Satellite Pro L300 Notebook
Charging problem plugin charger thenrestart
    Master:
  • Toshiba Master
  • 496 Answers
Have you tried another charger? Try to take out the battery, then plug in the charger again. There may be something shorting out the computer whenever you connect your charger
Posted on Apr 17, 2014
Why did it charge only 13% all day plugged into an electrical outlet?
The cords go bad, check a different cord and plugin.
Mar 11, 2015 | Tablets & eReaders
My ASUS K52 battery is at 58% and not charging why ?
Is this an ASUS charger and battery? Some ASUS laptops will not charge after a certain charge is reached, but it's usually in the 95-100% range to prevent overcharging.
If you bought an aftermarket charger, it may very well not have the amperage to charge while running the laptop.
Feb 13, 2015 | ASUS 156 K52 Notebook (AAC4001K52DRA1)
LAPTOP NOT CHARGING
With Dell you have to use Dell OEM chargers to keep all the functions. Like charging and use at the same time. Otherwise it wont do both. Look on Ebay for a genuine Dell charger or go to Dells website. Be advised that it might be the jack on the computer though.
Apr 28, 2014 | Dell Inspiron Computers & Internet
Charger
man you have to repair it
because the failure is in charging base
there is detector to detect if the charger is connect or not these one are damaged or faulty
go to any trusted repair shop
Jan 10, 2014 | Samsung Galaxy GT-S5570
One fine day after low battery indication i plugin phone for recharge, it was well connected and showing charger plugin indicator on phone. phone was also working but percentage of battery was not...
You can try with this procedure, Try to charge another battery in this phone with another charger, if the battery got charged then there is an issue with your charger and battery, if it gives the same problem, then you have to get fixed your phone from repairing shop or your cellphone service center, it seems that the charging IC of your phone is not working properly which needs to be replaced, they will check the whole motherboard of your phone, and will fix the problem, if the set is in warranty claim it as soon as possible .
If you require more assistance, feel free to reply to this post
Thanks for contacting FixYA! Regards, BA
Feb 11, 2011 | Cell Phones
My Dell Laptop syas that my battery is charged. But when I remove the ac power cord the computer immediately shuts down.
I repair laptops professionally and work on many Dells. Here are the possibilities.
1. The plugin connection where the battery meets the charging contacts in its bay where it seats are malfucntioning and the software is reading it incorrectly. To see if this is so, push the small round black button on the battery next to the 5 little dots at one end. If none of those dots light up green, the battery has no charge and the connection I spoke of above is damaged or malfunctioning beyond where you can see. If all the dots light up green, the battery is likely fine but the laptop can;t connect to its charge at the plugin.
2. The basic software (BIOS) is reading the charger/adapter incorrectly and although saying it is charging or charged, the actual charger is ruined inside in the compartment for charging the battery. Dell chargers can actually be incapable of charging the battery but still run the computer on direct current while plugged in.
3. The battery is no longer able to be charged, but is giving a false reading.
4. The DC Power Jack (into which you plug the charger) is only partially damaged and while able to power the laptop directky, cannot charge the battery. (Check to see if it is loose and woobly when you plug in the charger.
The easiest and least expensive way to troubleshoot and fix this yourself is to start with the charger. They can be had on eBay for about $20. Keep in mind that if no green lights show up on the battery, it might be your first choice and it's about the same price.
I hope I've given you enough info the help you determine your true problem.
Regards,
The Selkie
Aug 29, 2010 | Dell Inspiron 6000 Notebook
When i plugin chargar mobile show usb connect
Insert your charger pin completely into the phone. Then phone will show charging now.
After also if problem not clear then you have to reset the seetings and try it again.
Thanks,
Rokr_E6
Jan 12, 2009 | Motorola Mobility ROKR E6 Smartphone
Powershot g3
The battery is probably worn out, or the charger failed. More often it is the battery that is no longer able to charge and needs to be replaced.
The only way to absolutely know which is defective is to try the charger and a new battery, unless you have a DVM and a load tester to be able to test the charger.
Jerry G.
Jun 05, 2007 | Canon PowerShot G3 Digital Camera
Toshiba Satellite Pro L300 Notebook Logo
29 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
