Question about Watches
Set time pod watch - Watches
Iv bought a pod watch. and I carnt set the time
Google (brand)(model)(manual) without parens for instructions.
Dec 07, 2017 | The Watches
How do I set my pod 535 watch after I have changed the batteries
Just tried this procedure to replace a watch battery in a POD 535 and did not work...my version of the watch might be different, all I am saying is it did not work with my watch.
The procedure that worked with my watch
When you have replaced the battery reset the watch by placing a small screw driver across the two recessed contact next to the lower battery clip. The digital display will reset and you will see four zero's flashing...if not press the winder button once, or reset the watch again. This process is to get all the hands at twelve O clock position...press and hold the top right hand button and the hands will start revolving...you can let go of the button once the hand are moving. Pressing the top button again will stop the hands and a short press will move the hands in small increments. Once the hands get close to 12 press then press the button once and then press the same button in short pulses to align all the hands on the 12 position. Wait a short time and the watch will find the time signal and both the digital display and hands will be aligned and showing the correct time.
Oct 29, 2011 | Garmin Forerunner 50
Could I use the Nike+ pod together with a Garmin forerunner 210?
Nope: Different types of signals.
That being said, there is a foot pod that Garmin makes if you want that type of data sensor. The GPS in the 210 is more accurate than the Nike+ pod, and the Garmin foot pod is about equally accurate with the 210, but allows you to use the watch when there is no GPS signal
Dec 18, 2010 | Watches
I have lost the instructions and cant set the time
Try Googling (pod)(548)(manual) without parens.
Aug 04, 2017 | Watches
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals.Rate me, please .
Mar 27, 2010 | Watches
I can't set the time on my pod radio controlled watch,the time is correct but the little and big hands show a different time.
Read the manual, or just mess around with it and press every button you can, then it is bound to do something. Let me know if it works!
Oct 15, 2009 | Bulova Watch
"LoBATT" stays on in TIME mode (doesn't flash) ?
"lobatt" display is the watch battery. The foot pod uses the LED to indicate low battery and the heart rate monitor wont give a reading.
Oct 05, 2009 | Garmin Forerunner 50
INSTRUCTIONS FOR SETTING UP A POD 510 WATER RESISTANT MENS TIME WATCH
my pod watch will not restart,it's frozen,also can't find instructions so I can set correct time.
Aug 26, 2008 | Watches
Watches Logo
14 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
