Question about MotorGuide Standard Motor Replacement Parts - Type: Switches And Compone
Motor runs fine but won't steer
Motor runs fine turns on off speeds up and down plenty of charge in battery motor make's sound like want's to turn but will not move
SOURCE: i got a new 70 pound motorguide trolling motor.
Well if it goes in reverse, to me that would suggest that the batteries are wired in reverse? Either that or the controller has gone faulty?
Posted on Mar 03, 2010
wentlanv
  • 710 Answers
SOURCE: motorguide wireless 24volt trolling motor,
Hi thommo5473,
Do you have your owner's manual? If not, here is a website with the document: http://www.motorguide.com/userfiles/file/Support/OwnersManuals/2011%20Wireless%20Manual.pdf
From what you've said, I'm not sure exactly what is going on. The instructions state that the control will beep when it's on and a button is pushed, then you'll get a longer beep when it goes off.
Now, the fact that you don't get a speed change... did you just push the button and let go or have you tried just holding the button down? Just pushing and letting go will give just a slight change, but holding the button down will give a greater speed change.
In the troubleshooting section, they give things to do if something doesn't work, such as reprogramming, the control doesn't have the serial number of the remote entered into its memory.
Other reasons for problems are weak batteries, etc.
Try the things in the troubleshooting section of the owner's manual, then if that doesn't work, call the service number in their. They should help you out. If something's wrong with the system, then they should replace it.
I hope this helps, if it does, I'd appreciate your vote. Thanks,
Handie Andie
Posted on Apr 14, 2011
SOURCE: I have a Motor Guide
I believe you may have a bad low voltage circuit board problem. I do not think they make the board any longer but you may be able to convert it to work by bypassing the circuit board. I am working on one now.
Posted on Jun 20, 2011
canwoodjc
  • 3301 Answers
SOURCE: i have a brute 567
check the power switch for voltage,, short it across the pins and see if the motor runs, if it does, replace the switch
Posted on Jul 05, 2011
jsbenson
  • 166 Answers
You will need to check the 12/24 switch, constant/momentary switch, momentary push button. This is after you have made sure you have electricty to the trollong motor.
Posted on Jan 01, 2015
Is it the alternator?
Sounds like a charging system problem. The engine runs off of the alternator but if it is not charging the battery properly the battery will be drained until I engine will no longer run. You need to get the vehicle to a repair shop to have the battery and charging system check for defects
Jul 15, 2014 | 2004 Nissan Maxima
Wipers won't turn off
The wiper motor is defective and needs to be replaced. Inside the wiper motor is a "Park Switch". When you turn the wipers off, the park switch sends a signal to shut the wipers off. If the park switch fails to operate then the wipers will continue to run, unless the ignition key is turned off. You will also need to inspect and test the charging system. Where you had no issue before the rain, you may only need to charge the battery. After the battery is charged it should be load tested, to be sure that it is fine. Also test the alternator and make sure that it is charging correctly (@14volts). If you need more information please write back. Good luck.
Mar 21, 2014 | 1993 Chrysler Lebaron
Replace fuel pump 2008 nissan altima
iv never known a fuel pump to make lots of clicks when starting. sounds to me like the clicking could be the starter motor either faulty or not having enough power, or a power shortage causing relays to click. check your battery connections if all looks good either charge the battery or try jump leads linked to a good battery.
Nov 27, 2013 | 2008 Nissan Altima
MY PLYMOUTH GRAND VOYAGER 'S HEADLIGHT'S AND DASH LIGHTS WORK, BUT THE ENGINE WON'T TURN OVER. THERE IS NO SPARK COMING FROM THE ELECTRICAL WIRES.
When you say no spark, are you talking about the spark plugs, or just the general wiring?
If the engine won't turn over, then it isn't moving, and if it isn't moving then you need to check the following in this order:
1) Does the battery have power i.e. around 12.4 volts or over?No? Charge, test or replace battery.
2) Do the car's head lights dim considerably if turned on when attempting to crank? Yes? Possible lack of battery charge or faulty battery.
3) Assuming the battery is fine, can you turn the dash warning lights on and off with the key? No? Faulty ignition switch.
4) Is there a click sound when you turn the key, but no starter motor spin? Check starter motor connections or replace starter motor.
If none of the above prove to be of help, then please report.
Oct 31, 2012 | Plymouth Cars & Trucks
Motor won't engage. I turn the throttle and get a clicking sound, but nothing happens. We've charged the battery for about 4-6 hours, but the light stays red, never turns green. Help?!!
sounds like the battery is bad and not taking charge.replace battery attemp again if not then check for fuel, spark and compression.then c wat happens or wats not working any motor no matter how small or big has to hv those three things to run. hope this helps.
Jul 08, 2012 | Electric Razor Pocket Rocket Ride-on...
2004 toyota corolla charging light on in the dash won't go out battery and alternator are fine what is the problem
How old is the belt that turns the alternator? Any whining sounds as motor revs up and down? If your belt is old and frayed, it might not be fully turning the alternator pulley...Hope this helps.
Mar 16, 2012 | 1993 Toyota Corolla
Nortic track c2155 will not propel. computer portion turns on fine but when hitting start nothing happens. i hear no motor sounds or anything. however, the track will move if pushed manually.
Unplug the unit and remove the motor shroud insert plug back in the outlet.The single most cause of no motor output is failure of the DC motor control. Look for any test lights on the power boards beneath the motor hood.If it operates on an open-loop system, the computer will run normally and not give and error code, but the motor will not turn. If you have a multimeter, you can test to make sure you have DC output from the controller spades if not replace the control board. If you have DC output, but motor is not turning the test the motor itself.
Cordless drill battery- get a fully-charged, 18 volt (preferred) cordless drill battery and on most treadmills connect the red and black motor leads to the battery (some have different colors but if you have two wires and get it hooked up backwards, the motor will just run backwards and won’t be harmed). If good, the motor should operate at about 1 MPH.
Car battery- these are 12VDC high amp batteries so the motor will turn slowly but you can walk on the belt. Always be careful with battery acid on these things so we don’t recommend bringing them in the house…take the treadmill to the battery.
Lantern battery- a fully charged lantern battery should operate your motor at a slow speed but lacks the amperage to have someone walk on the belt. If it does not rotate replace motor
May 28, 2010 | Exercise & Fitness
Error message E21
E21 means the treadmill is not picking up a speed signal once the start key is pressed. First, determine if the motor is turning before you get the E21 or not. If the motor turns, the speed sensor is the most likely problem. If it does not, you can manually turn the belt with your feet before you get the E21 and you should get a speed reading but eventually you will get an error code because it is almost impossible to keep the speed constant enough for the computer. Try running it through calibration with the motor shroud off.
Press the Stop and the Speed Up keys down while inserting the safety key.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
Press either incline key and the incline will calibrate automatically.
On this next step do not step on the treadmill when you press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window).
If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled.
The max speed potentiometer is a small black square with a white center and is located near the three small speed wire connections labeled H, W, & L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments.
It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure.
After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing, press the Stop key once and remove the safety key.
If the motor does not run, test the motor but first unplug unit then unplug the two leads ( Red and Black ) that is connected to the Motor Control Board.Cordless drill battery- get a fully-charged, 18 volt (preferred) cordless drill battery and on most treadmills connect the red and black motor leads to the battery (some have different colors but if you have two wires and get it hooked up backwards, the motor will just run backwards and won’t be harmed). If good, the motor should operate at about 1 MPH. Then Motor Control Motor will need to replaced
May 21, 2010 | Proform 785 Treadmill
MotorGuide Standard Motor Replacement Parts  - Type: Switches And Compone Logo
Top MotorGuide Electrical Supplies Experts
jdthefixer
Mike
Mike Marcotte
Mike Marcotte
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
