Intel D101GGC Motherboard Logo
Anonymous Posted on Jun 19, 2009
Motherboard bits I have intel D101GGc Pentium(R) 4 motherBoard with 3.07 Ghz Processor.What I want to know is 32 or 64 bits?
Nalin DSouza
Level 2:
Guru:
  • Expert 224 Answers
  • Posted on Jun 19, 2009
Nalin DSouza
Expert
Level 2:
Guru:
Answers
224
Questions
0
Helped
154884
Points
675
Its a 64 bit
Testimonial: "Thank many many..."
1helpful
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
3helpful
I just need to figure out what the socket type this motherboard has for the processor so that I can find what processors I can upgrade my computer with. It's a g45t/g43t AM 3 V: 1.1 motherboard made by...
The socket type of ACER G45T/G43T - AM3 V1.1 motherboard is LGA 775. Here are the compatible processors you can use for this motherboard :
Intel Pentium 4 (2.60 - 3.80 GHz)
Intel Celeron D (2.53 - 3.60 GHz )
Intel Pentium 4 Extreme Edition
(3.20 - 3.73 GHz)
Intel Pentium D (2.66 - 3.60 GHz)
Pentium Extreme Edition
(3.20 - 3.73 GHz)
Pentium Dual-Core (1.40 - 3.33 GHz)
Intel Core 2 Duo (1.60 - 3.33 GHz)
Intel Core 2 Extreme (2.66 - 3.20 GHz)
Intel Core 2 Quad (2.33 - 3.00 GHz)
Intel Xeon (1.86-3.40 GHz)
Intel Celeron (1.60 - 2.40 GHz)
2helpful
3answers
Does Intel Pentium 4, 2 GHz Processor support 2GB DDR1 RAM..?
Type of RAM supported has nothing to do with the processor make & type in most cases. It is more important to verify that the motherboard supports this kind of RAM.
In general, most motherboards supporting the Intel Pentium 4 2.0 GHz processor support also DDR1 RAM.
3answers
My motherboard model is D101GGC Is this support CORE 2 DUO E4600 processor
This motherboard model will not support Core 2 Duo E4600.
It will support only.
1.Intel Pentium D Processor.
2.Intel Pentium 4 Processor.
3.Intel Celeron D Processor.
Thanks for using FixYa.
1helpful
2answers
Sir, In my system motherboard model is D101GGC. my question is can i replace porcessor pentium 4 with the Core 2 Duo
Sorry but you can't. It is not compatible. You can install Pentium D processor instead, if you want to.
For the list of compatible processors for your motherboard, you can check it here:
http://www.intel.com/support/motherboards/desktop/d101ggc/sb/CS-025906.htm
Thanks for using Fixya!
2helpful
4answers
Can i up grade my single core cpu pen4 550 3,4GHz to a Quad core or dual core either one would help
Depends on the socket type.. Socket 423 and 478 do not support core duo or quad core processor types. However, if you have LGA 775 (aka socket T) your motherboard will support the following:
Intel Pentium 4 Extreme Edition (3.20 - 3.73 GHz)
Pentium Extreme Edition (3.20 - 3.73 GHz)
2answers
I am havimg a p4 processor.iwaan replace it by core 2 duo.will it be possible with D101GGC
This motherboard only supports the folloing processors.
  • Intel® Pentium® D processor 820, Intel® Pentium® 4 and Celeron® D processors in the LGA775 package
  • Supports Intel® EM64Tφ
  • 0helpful
    What type of processor and graphic card are compatible with my motherboard
    Your motherboard supports has a Land Grid Array processor (LGA) socketso it supports, celeron D, pentium 4 and pentium D processors.
    Probably, it's the PCI x16 graphics card, you can find the motherboards features on http://www.intel.com/support/motherboards/desktop/d101ggc/sb/CS-021717.htm
    All the best
    1helpful
    2answers
    Need a prossesor for motherboard
    You can also use any other intel 775 socket processor as well. The dual cores are at the top of the list for performance that are compatible with that board, but if you're looking for a cheaper solution, I have that board with a 3GHz pentium 4 and it runs great. Here's a list of all the processors you can use.
    Intel Pentium 4 (2.66 - 3.80 GHz)
    (3.20 - 3.73 GHz)
    Intel Pentium Extreme Edition
    (3.20 - 3.73 GHz)
    Pentium Dual-Core (1.40 - 2.80 GHz)
    Intel 'Core' Celeron (1.60 - 2.40 GHz)
    3helpful
    Intel d101ggc original motherboard
    If it has a Pentium 4, 3 GHz CPU installed on the motherboard, than it is a 32 Bit Motherboard, and you can only use and run 32 Bit based hardware, and software on the computer.
    Top Intel Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    SmartAviator
    SmartAviator
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
