Question about Fedders AEY12F7F Wall/Window Air Conditioner
Fedders wall air conditioner
Compressor will turn back on after unit is shut down, and when it is in this mode you cannot put just the fan on as it will only blow cold air and continue to run.Problem is it does not do this all the time..
    Problem Solver:
  • 8 Answers
If the compressor only turns on after the units it's shut off then it is a control board problem (stuck relay)
Posted on Feb 03, 2010
My air conditioner delivers cold air only in spurts. It then goes into fan mode for a few minutes, then to cold air in a few more minutes. It is over 100 degrees outside and the inside of the house is 85...
The unit is probably low on freon and so it is running too cold....this trips the freeze stat and shuts down the compressor till it warms up
The unit will need to be recharged or replaced...
Here is a tip that I wrote about how to add refrigerant to a air conditioner or cooling system
How to add Freon to a Air Conditioner or Refrigeration System
heatman101
Sep 27, 2010 | Fedders AED24E7F Wall/Window Air...
Unit turns on,compressor kicks on but fan does not turn,motor makes humming noise
sounds like fan motor has gone bad or the capacitor to fan motor is bad...open up unit ,see if motor is frozen..does it turn freely..if so ,replace capacitor,or fan motor is bad...
Jun 09, 2010 | Fedders AED24E7F Wall/Window Air...
Maytag M6Y18F7A Air Conditioner troble light turns off
you have to open the unit up or atleast see if the fan is failing. The blower motor is usually a double shaft and cool the compressor and also blows the air across the evaporator. Look for the air to stop blowing then the compressor to shake from overheating.
Aug 12, 2009 | Fedders AEY08F2FCOM Wall/Window Air...
Constantly running
follow the wires from compressor to contactor or relay contacts stuck replace
May 24, 2009 | Fedders A6Q10F2B Q Chassis Room Air...
FEDDERS D CHASSIS A6D24E7A
Oh, the compressor motor's borked or overworked and overheating, or its capacitor failed short (perhaps the motor is shutting off from thermal shutdown...but you get to find out whether that's so. Be safe.) Alternately the temperature sensors have gone touchy on you. Once you gently vacuum it clean, try keeping incandecent bulbs in series with the compressor to get an idea of how loaded that thing is as it runs for those 5 minutes or so; the load might change more than you expect, just pay attention.
Hopefully you won't have to replace the compressor or motor; but it's doable if you're a certified technician with like equipment (so you can handle the refrigerant decently.) Most shops will streamline a bunch of similar jobs together to cut the waste and setup time.
Bigger conditioners are so much more efficient than little ones...syndicate the A/C?
May 30, 2008 | Fedders D Chassis A6D24E7A Air Conditioner
Compressor runs even when turned off
You could have a relay stuck closed, so every time the power is on it feeds electricity to the compressor.
Mar 10, 2008 | Fedders AEY08F2FCOM Wall/Window Air...
Fedders Window AC Unit
I would try to start the unit with only the fan running at first. If it stays running then cycle on the compressor and see how it does. If the unit does not operate when compressor is turne on then we have to dig deeper into that.
Aug 13, 2007 | Fedders J Chassis A6J12E7A Air Conditioner
Fedders AEY12F7F Wall/Window Air Conditioner Logo
163 people viewed this question
Top Fedders Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Mike
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
