Panel display para KDL-46BX450 - Televison & Video
Tcon BRAVIA 2010 sony kdl-32bx300
The T'Con is a built in part of the display panel, and cannot be replaced. The display panel should be replaced with a new one.
Dec 31, 2016 | Sony Bravia KDL-32BX300 32" 1366 x 768...
My tv flashed on and off and left with 6 blinking lights. Did a power reset and tv powers up with Sony on the screen then goes dark but the green light stays on. Screen is dark. Which panel is bad.
Probably the back light inverter is faulty . Before going to buy a new inverter board tey to check the power supply. Which the bellow added video to know how to check a power supply board. You have to check the 24V power sto the inverter board from the power supply. if its not there then the problem is with power board. If its ok then you have to go for a new inverter board. Also try to replace the electrolytic capacitors in the power supply board. some times bad electrolytic capacitors can lead to back light failure.
www.electro-medical.blogspot.com
Testing LCD TV Power Supply BoardsSTEP BY STEP
Oct 31, 2015 | Sony Bravia Kdl-46bx450 46" Class 1080p...
I have Sony LCD tv
Any other indications? It looks like it turns itself into 'stand-by' having no input signal.
May 29, 2015 | Sony BRAVIA KDL-46BX450 46 inch LCD HDTV...
Horizontal lines across screen of sony KDL-46BX450
Sounds like a T'Con fault itself. Re-seat all the incoming and outgoing flat cable wires to T'Con. If it do not help you, replace it with a new one of same part number. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 23, 2014 | Televison & Video
Hola. Cordial saludo. Tengo el siguiente problema con este modelo KDL-46V3000 el cual Al darle el pulso de encendido el led del stanby enciende verde y cambia en segundos a rojo y empieza a parpadear...
Mi espa?ol es s?lo un poco. Utilice traductor Google (translate.google.com) para obtener esta informaci?n:
http://www.techlore.com/article/15444/Understanding-Sony-Television-Blinking-Codes/
Resalte con el rat?n y pegar en el traductor Google, si es necesario.
Dos parpadeos parece ser un problema de alimentaci?n.
Mar 05, 2011 | Sony BRAVIA KDL-40V3000 Television
Broken display screen
Call sony and explain your situation, they will fix it for you.
Regards
Jul 21, 2009 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
SONY BRAVIA LCD SCREEN CRACKED NEED REPACEMENT COST
Please intimate exact model of Sony TV to look for its screen price info.
Jul 10, 2009 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sony KDL-40WL140 vs KDL-40Z4100
KDL40Z4100 Product Features
  • 16:9 Full HD 1080p Resolution (1920x1080p) LCD Panel
  • Motionflow 120Hz; improves TV & DVD viewing
  • DMeX compatible; allows seamless feature upgrades
  • DLNA® Compliant - view photos from another room
  • HDMI x4, HD Component x2, PC Input
Technical Details
  • Brand Name: Sony
  • Model: KDL-40Z4100/B
  • Display Technology: TFT active matrix
  • Display Size: 40 inches
  • Image Aspect Ratio: 16:9
  • is_hdtv_compatible: Y
  • speakers_included_description: 2 speakers
  • Height: 23.9 inches
  • Width: 37.2 inches
  • Depth: 2.8 inches
  • Weight: 39.7 pounds
  • Refresh Rate: 120
KDL-40WL140 Product Features
  • Motionflow™ 120Hz - clear, smooth motion for DVDs, TV
  • DMex ™ compatible; allows seamless feature upgrades
  • Enhanced XMB™ with 3D graphics incl. TV Guide
  • HDMI™ x4, HD Component x2, PC Input
Technical Details
  • Brand Name: Sony
  • Model: KDL-40W4100
  • Height: 25.4 inches
  • Width: 38.8 inches
  • Depth: 4.3 inches
  • Weight: 44.1 pounds
  • Refresh Rate: 120
Bottom line for the extra connectivity and DLNA certification i would go with the
Bravia Z-Series KDL-40Z4100/B 40-Inch 1080pBecause if you connect this to your in home network you can stream music videos and music off you PC onto your TV without the need for extra wired or memory cards etc.
Otherwise if you don't need this feature the other options are identical on the other TV so it is just as good a choice.
May 25, 2009 | Sony Bravia Z KDL40Z4100 TV
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
