Question about Traeger Industries BBQ070 All-in-One Grill / Smoker
Can't figure it out
Is there a traeger dealer or service rep that can fix my grill, in amarillo, tx.
    Novelist:
    Scholar:
  • 197 Answers
Contact Traeger customer service at http://www.traegergrills.com for a list of dealers in you area.
Posted on Dec 04, 2014
2 Suggested Answers
  • 34 Answers
SOURCE: I have an electric Traeger grill. I plug it in
Make sure your grill is unplugged. Them take the controler out and there is a fuse on the back side of the control. There is also a new fuse there to replace the old one. If the fuse is blown, you could have a bad hot rod or other component that is bad. Usually the hot rod is the problem and they should be under warrenty so call Treager and get a new one sent. If the fuse blows after it is replace, you can un hook the purple wire and replace the fuse and see if it will work them. If it does, it is the hotrod.
Posted on Apr 17, 2010
My Traeger takes 45 minutes or more to heat up and as za result uses a lot of pellets. Spoke to an agent at Costco Winnipeg and we were told to contact Traeger. Can you advise us pls.
It shouldn't take so long. Contact Traeger.
  • Phone:1-800-TRAEGER
  • Hours:5am - 7pm PST 7 days a week
  • Email:service@traegergrills.com
Sep 17, 2017 | Grilling
Burner not working
Traeger Industries burner not working Grills & Smokers ...
www.fixya.com > Forum > Tags > burner not working > Grills & Smokers
Traeger Industries grills & smokers burner not working related questions and answers. Ask your ... Question about BBQ075 All-in-One Grill / Smoker. 1 Answer ...
Traeger Industries water pump not working Grills & Smokers ...
www.fixya.com > ... > Tags > water pump not working > Grills & Smokers
Traeger Industries grills & smokers water pump not working related ... Question about BBQ075 All-in-One Grill / Smoker ... our auger stopped working how can we fixthis. it is not the electrical .when you put pellets in the burner it will light and ...
Support - Traeger Wood Pellet Grills
www.traegergrills.com/support.html
Traeger Pellet Grills, LLC. ... Why won't my grill light? ... Why is my grill running so hot on smoke? .... Large Commercial Trailer. Download manual. View All ...
FAQS - Traeger Wood Pellet Grills
Jan 01, 2016 | Traeger Industries BBQ075 All-in-One Grill...
Traeger grill get to hot on smoke
If you're cooking when it's hot outside, it's hard to maintain low temperatures. In the heat of summer, I have to tend my grill continually opening and closing the lid to keep the temperature down to my cooking temp of 180. That, of course, lets the smoke escape. If it gets too hot when the temperatures are moderate, i.e. 60s and 70s, the augur may be dumping too many pellets into the fire pot and need realigning. I suggest you contact Traeger customer service at http://www.traegergrills.com and see what they suggest.
Apr 20, 2014 | Traeger Industries BBQ100 All-in-One Grill...
Traejer pellet grill auger jammed up
Contact Traeger customer service at http://www.traegergrills.com for parts and installation instructions. Also check out the FAQs. There are instructions on replacing and aligning the augurs.
Mar 23, 2014 | Traeger Industries BBQ070 All-in-One Grill...
Grill only gets to about 200 degrees
reset the check valve -- we get a "grill will not get hot" call 5 - 6 times a week and 99 out of 100 need to reset the check valve. 3 minutes and it is fixed!
Jan 24, 2014 | Traeger Industries Grilling
How do I get my Traeger to grill again without turning all my food black?
Adjust the air-fuel mixture so the flame is blue with maybe a tinge of yellow at the tips...if I'm right, the flames are solid yellow at the moment. adjust the mixture by opening or sliding or twisting the adjuster that's located where the feed tube attaches to the dial. Usually behind the bezel (panel).
Jul 18, 2012 | Traeger Industries BBQ070 All-in-One Grill...
Err message on my Traeger smoker, first time using it
I had the same problem; I talked to Traeger talked to their rep and he walked me through fixing the problem. There are two wires leading from the temperature probe, these lead back to the thermostat digital controller. With the unit unplugged, unscrew the two screws holding the temperature controller in place. Slowly and carefully pull out, and check that both wires are running into the controller. If either is disconnected, strip a little more wire off the loosened wire, put back in hole and tighten the wire back down. That was the trick for my grill. Reassemble and reconnect power and test it out.
Dec 02, 2010 | Traeger Industries BBQ100 All-in-One Grill...
Traeger 075 tripping GFI continually
May be too much moisture on the hot rod.
From Traeger:
Why won't my Grill Ignite?
  1. If your grill is plugged into an electrical outlet with a GFI (ground fault interrupter) plug, chances are the hot rod has absorbed or been exposed to too much moisture and is leaking to ground causing the plug to trip.
  2. Open your cooking chamber lid, remove cooking grill, angled drip pan and U-shaped firepot cover. Is there ash build up in the firepot and/or around the firepot? If so, this needs to be cleaned out. The ash is choking out the fire.
  3. Check the fuse on the back of the control board. To do this, first UNPLUG the grill from the electrical outlet. Then, unscrew the control board and look at the fuse-is it blown or not?
  4. If the fuse is good, check for power by switching the colored plugs first. Unplug the purple plug and the orange plug. Plug the purple plug into the orange plug. Now plug the power cord back into the electrical outlet and turn the grill on. Does the induction fan operate? If so, you will need a new hot rod and fuse. If not, you will need a new control board. Unplug the purple from the orange and reconnect the plugs together to their correct color plug.
  5. Always start your grill on the SMOKE setting.
Jun 19, 2010 | Traeger Industries BBQ075 All-in-One Grill...
Traeger Industries BBQ070 All-in-One Grill / Smoker Logo
109 people viewed this question
Top Traeger Industries Grilling Experts
Gary Kenady
Gary Kenady
Craig Butler
Craig Butler
Paul Carew
Are you a Traeger Industries Grilling Expert? Answer questions, earn points and help others
