Question about Konica Minolta Full Set For Bizhub C220 C280 220 280 Toner Tn216 4 Pack
Error Code C2152
The machine shows an error code C2152 what could be the problem.....
  • Konica Minolta Master
  • 6,161 Answers
Transfer belt code was it replaced properly?
Posted on May 14, 2017
3 Suggested Answers
  • 44 Answers
SOURCE: bizhub 250. error c2152
Check and make sure there are no jams by the fuser ie: bits of paper in the paper path.
Posted on Nov 29, 2009
SOURCE: Error code c2152
good to
Imax Konica Minolta C451 Bizhub
I have a problem is the cod C2151 what to do Thanks
Posted on Apr 11, 2013
Wme8227s. What does code E18 indicate?
Beko Washing Machine ' WMA Series ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3623-beko-wma-...
Feb 6, 2013 - ... Fault Codes. Beko WMA Washing Machines With Display ... BekoWMA Series Washing Machine Fault Codes. These fault codes are ... E18 ...
UK Whitegoods • View topic - Beko WME7247W showing error code e18 ...
www.ukwhitegoods.co.uk/.../washing-machine.../beko-wme7247w-show...
Jun 19, 2011 - Hi, does anyone know what error code e18 is on a beko wme7247wwashing machine? thanks. User avatar louisebaxter: Whitegoods Newbie Beko wme7247w dc module burnt out
Apr 27, 2014
Bosch WAS24460GB showing error F:57
Sep 28, 2013
beko washer error code
Aug 18, 2012
Samsung B1415J showing error code EA ...
Jan 9, 2012
More results from www.ukwhitegoods.co.uk
Oct 30, 2015 | Beko Washing Machines
How do i Fix Error Code 2152 Konica Minolta Biz-hub
Code: C2152 Code C2152 Description Transfer belt pressure welding alienation
• During a retraction operation of the transfer belt, the transfer belt retraction sensor cannot detect the transfer belt at its retracted position within a predetermined period of time after the transfer belt retraction clutch is turned ON. • During a pressure operation of the transfer belt, the transfer belt retraction sensor cannot detect the transfer belt at its pressed position within a predetermined period of time after the transfer belt clutch is turned ON. Remedy 1 Check the M5 connector for proper connection and correct as necessary. 2 PS31 I/O check, sensor check. 3 CL7 operation check. 4 M5 operation check. 5 Change CL7. 6 Change M21. 7 Change PRCB.
Jan 29, 2015 | Konica Minolta bizhub Office Equipment &...
Can any one help m please, I have a Konica minolta bizhub C450 and i have a malfunction code C152, can any one tell me how to fix it please as soon as possibl thanks to all
i found this after a brief search
Straight from the service manual....just use the last 4 digits when doing a search, makes it easier to find the specific code as not all manuals are the same in how the code is displayed.
CC152 ROM contents error upon startup (Scanner)
• A fault is detected in a sequence of ROM contents check of the PWB-C during starting.
16.5.79 CC151: ROM contents error upon startup (MSC)
16.5.80 CC152: ROM contents error upon startup (Scanner)
16.5.81 CC153: ROM contents error upon startup (PRT)
16.5.82 CC154: ROM contents error upon startup (PH)
1 Check the ROM version. - -
2 Rewrite the firmware. - -
3 Replace the appropriate board.
TSB entry
Description
C-C152 at power up, the counters display as 0 and the operation panel display is in Japanese.
Solution
CAUSE: Main body firmware is corrupt.
SOLUTION: Flash or re-flash the firmware to the latest level.
As for the 2152 code,
16.5.6 C2152: Transfer belt pressure welding alienation
Dec 04, 2014 | Konica Minolta bizhub Office Equipment &...
Error c2152 on Minolta c252 removed transfer belt whilst putting it back after cleaning the blade the machine showed C2152 and cant clear tried everything please help.
I did a Google search on your problem and most of the information indicated a motor needed to be replaced. On answer said to re-install the program as the on that was originally running the machine worked fine until it got the same error code.
Sorry I don't have an exact answer but the machine must be old as there were no answers that I could find that were recent.
Nov 03, 2014 | Office Equipment & Supplies
Error code c2152
no such code in the service manual
Jan 31, 2014 | Konica Minolta Bizhub 362 Copier
I keep getting a error c2152
c2152 is door switch error for C203
may you reinstall the firmware first ?
Feb 08, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
C-2152 Malfunction
Yes there is a C2152 code for an error with the transfer belt separation. But this code does not appear in the C350 manual. It DOES however appear in the C250/C252 manual. There is a service bulletin from Konica/Minolta about this code that covers models C203/C253/C353. Since it is not covered in the C350 manual I can only assume that if you have a C350 and have this code then it must be a problem with the Transfer Belt Unit or the Sensor Plate. Here is a link to a forum which has the detail on both the bulletins and solutions for this error code. Keep in mind tho that this is not for your exact model. My experience tho (27 years on Minolta's) is that the code for series of machines don't change much. Have you tried resetting the code with the trouble reset procedure?
Good Luck and Thank You for using Fixya.
Apr 22, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Error code c2152
good to
Sep 24, 2009 | Konica Minolta bizhub C450P Laser Printer
Bizhub 250. error c2152
Sep 22, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta Full Set For Bizhub C220 C280 220 280 Toner Tn216 4 Pack Logo
115 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
