Question about Sanyo PLC XP46 Multimedia Projector
Installed new lamp, light flickers, sometimes turns on, somtimes not.
My father bought the wrong lamp for the projector and broke the molex lamp conector housing out of the projector trying to force it in. I supper glued it all back but the molex pins were striped of there support hooks and so when the male pin try's to go into the female, the female pin just pushes out the back of the lamp housing connector. So I tried using **** wire connectors bypassing the molex housing altogether. After this I got some response from the lamp, but it was just a faint flickering, and then the projector turned off. So then I soldered the wires of the lamp and ballast cables together, and wrapped them with electrical tape. The flickering became more aggressive and then the lamp would sometimes fire up, and sometimes the projector would give up and shut down. I used it for a few days like this but it wasn't long before the bulb exploded. Here are my questions. Is a molex connector really so much better then solder and electrical tape that the wires are shorting out? If so, how can i find out the size and model of the replacement molex pins. I have the housings, but my pins are broken. I tried cpu power supply molex pins from an old pc and they are just barely too small. Lastly, if it is not my conection to the lamp, what do you think it might be?
2 Suggested Answers
  • 4 Answers
SOURCE: sanyo plc xu115 new bulb wont fire. power light
Could be a burnt capacitor on the circuit board. Replace capacitor if you can determine which one it is. There are only a few.
Posted on May 04, 2011
Why is the light strobing ?
Lamps will sometimes flicker when they are near the end of their life. Look through the menus and check the lamp hours, if it is over 1000 hours I would try another lamp. This could also be caused by the lamp ballast, which is the power supply for the lamp. If the ballast is bad, repairs will cost almost as much as a new projector.
May 01, 2014 | Epson EMP-X3 LCD Projector
I bought a new Sony xl5100 lamp. Delicately and accurately replaced the old lamp with the new one. Installed the lamp and housing correctly. Closed the lamp access doors correctly. Turned on TV...red light...
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Jan 11, 2014 | Sony (XL-2400) Projector Lamp for...
Rollei 35A slide projector - halogen lamp problem
Most all projection lamps of 1970 vintage are still available on the internet. There should be a 3-letter code on the lamp. Try using Google to search that lamp code. There are multiple vendors in the USA that have an amazing inventory remaining. Good Luck !! Jim
Nov 19, 2013 | Office Equipment & Supplies
Does a lamp error message (6 blinking red status lights) mean the lamp needs to be replaced? or could something else be wrong.
According to NEC technical support, if the status light flashes red six times, this could indicate a defective lamp. If a new lamp is installed and the project still won't turn on, the projector will need service.
Jun 15, 2011 | NEC NP400 Projector
JUST PUT NEW BULB IN A TOSHIBA TDP-S20 ON 2/18/11 . BOUGHT PROJECTOR IN 2004 USED UNTIL THE BULB HRS RAN OUT . BULB NEVER BROKE / BURST. ON START UP WITH THE NEW BULB IN MACHINE BOTH FAN AND LAMP LIGHTS...
Your new bulb is not lighting.
Check the connections are correct.
Have you also tried putting back old bulb to see if it works.
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | Toshiba TDP-S20U Multimedia Projector
Projector won't turn on and LED Temp/Lamp flashes! has new lamp
I wish you had received a relevant answer to your question, as I'm experiencing exactly the same thing here. Not sure is this site notifies people when they get responses, but did you ever figure out what the problem was?
Apr 08, 2010 | Optoma MovieTime DV10 Multimedia Projector
I put a new lamp in it and the lamp light still, is there
Did you go into setup and tell the projector that you installed a new lamp?
Jan 19, 2010 | Dell 2300MP Multimedia Projector
No light. Bought a new bulb assembly and
There is a product leaflet for this model,
http://office.manualsonline.com/regman/exit/ct?url=aHR0cDovL21hcmtldGluZy5vcHRvbWF1c2EuY29tL1BERnMvYnJvY2h1cmVzL09wdG9tYV9UWDcwMF9Ccm9jaHVyZS5wZGY,&target=productDoc&idDeviceType=2726&idMfg=2278&idProduct=794832
to contact direct for help try Optoma Customer Service at 888-289-6786.
AndystUK
Nov 08, 2009 | Optoma TX700 Multimedia Projector
The light from the projector on my infocus lp70+ flickers kind of like a regular bulb that's going bad.somtimes the unit goes on for a few minutes and then it goes off by itself. any help is appreciated.
the colorwheel needs replacing. in order for the lamp to strike and stay on, the colorwheel has to stay at a certain speed to sync with the dlp. if the speed is off, the lamp won't stay on.
Feb 03, 2009 | InFocus LP70+ Multimedia Projector
Sanyo PLC XP46 Multimedia Projector Logo
43 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
