Question about Mtd Garden
Grillo mower Climber 9.22 front left wheel will not come off. Seems to be stuck on the brake some how.
Initially, I could rotate the wheel now I can not. I have take off the Circ-clip and 3 spaces but the wheel seems to be stuck on something. It is only 6 months old.
EarthJam
  • 23 Answers
SOURCE: rear wheel/rim craftsman 16.5 model#917.271121 rear wheel
this is normal it take ALOT of force. I end up using a large hammer and a solid 2x4 to cusion the rim. Smacking it once good from the outside of the mower too. all this take place the the next morning after spraying in some pb blaster or similar anti seize spray into the axel.. and tilting the mower slightly. Dont use a torch it wont help. It only makes things hot and you will ruin the tranny seals.
I know its frustrating. expect that key way to be part of the problem in there to.
Posted on Feb 05, 2009
  • 57 Answers
SOURCE: My riding mower is stuck in gear. I can shift
If the wheels aren't facing straight forward you may have broken an axle.
Posted on May 18, 2009
panilling9
  • 284 Answers
SOURCE: Need to remove rear wheels to replace tires on MTD riding mower.
most likely rust has taken over
find some liquid wrench or pb blaster and spray the axles liberally and let it penetrate the axles and wheel hubs where the axle goes through.
use a 2x4 and a hammer to tap against the wheel hub to try to move it down the axle then tap in back on to try to free it up as the penetrating oil works in, spin the wheel and tap in different areas of it
the worst case cenario would be to use a torch and heat the axle and hub up and drive it off, but it sounds as though you are moving it some and with some patience they eventually should come off
when you put them back be sure to coat the axle with some grease and do not forget to reinstall the key stock in each wheel, if they have it
the bolt in the center of the axle is all you need to remove and note where the washers came from and where they go back.
hope this helps you some
Posted on Jun 14, 2009
  • 257 Answers
SOURCE: I have a 16 HP 42
try checking to see if it has a push pull out lock at the back of mower,,if not try checking the safety switch for the gear lever,,hope this help
Posted on Aug 30, 2009
  • 299 Answers
SOURCE: Craftsman riding mower won't move.
yes it is a bad belt unless it is a hydro-stat(no clutch) you need to look under the mower and see if the belt is on correctly
Posted on Sep 30, 2009
I have a 2000 ford expedition, when i drive it, it makes a grinding sound and bad vibration from front passenger side. It almost seems as if it is not completely out of 4wd.
Most likely you have a bad wheel bearing on the right front tire but at the same time you could have a stuck brake caliper on the front right as well you can tell if it's a bad brake caliper if the vehicle well rolling at about 5 miles an hour and shift it into neutral bad bearing if when you shift the vehicle turning the wheel hard to the right it kind of grinds you could also jack up the front right tire and turn the wheel rotating it to see if it is stiff
Mar 18, 2018 | 2000 Ford Expedition
Replace pto belts on grillo fd300
http://www.grilloagrigarden.co.uk/download.php?id=2733
If the link works , it will display the user's manual. It describes belt replacement. All the way at end end are the pictures. It's not super user-freindly, but it may help.
Apr 02, 2014 | Garden
Left front wheel sensor
wheel sensors determine the rate of wheel rotation send signals to the anti lock brake system to prevent wheel lock up during hard braking applications.
Jul 28, 2013 | 2002 Jaguar X-Type
Toyota corolla 1.6 gli suqeaks when slow cornering
Jack the car up on the left. Once clear of the ground hold the wheel top and bottom at the 12 o'clock and 6 o'clock and check for play by pulling out at the bottom and pushing in at the top and then the other way around. Any movement indicates a loose or worn wheel bearing. To make doubly sure remove the wheel and again check for play in the disc again in the north to south direction. Spin the disc and listen for complaint from the bearing. Hold the disc East/West (3 o'clock, 9 o'clock) and rock back and forward and check for movement against the track rod (steering end) arm. Tighten the central nut on the hub to the point at which resistance to the ability to rotate the disc is felt. Slacken off the nut just a fraction until to regain freedom of disc rotation. Any noises of complaint from the bearing or points of stiffness when the disc is rotating usually indicates that the bearing should be renewed. Now do the same procedure to the right wheel on the other side and make a mental comparison. It is rare for two wheel bearings to go at the same time and so the comparison will serve to highlight a faulty bearing by being markedly different.
Apr 21, 2010 | 2005 Toyota Corolla
Steering wheel pulls to left when brake is applied
This has to do with the front brake caliper on the left sticking or the front right is not activating. Remove the front wheels and check the caliper for proper movement and pad wear. Try to rotate the front left and note any heavy resistance. Also check all tires for proper pressure.
Mar 24, 2010 | 1990 Lexus LS 400
I have a 1998 ford expedition with 4wd and it pulls to the right. I had the tires rotated and the wheels aligned twice. The problem remains.
You could be having uneven tires; front-brake dragging; broken or sagging springs. Have your front brakes checked.
Nov 17, 2009 | 1998 Ford Expedition
1997 Mercury Sable thumping in front end
try to replace the wheel bearings.
Jun 17, 2009 | 1997 Mercury Sable
Tapping sound when brakes are applied
The only thing I can think of is something got stuck in the caliper , rock or some other goofy thing.Good luck
Nov 30, 2008 | 1992 Volvo 240
Garden Logo
78 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
