When you put power on and OPENPLi appears and booting begins and keeps booting.Box does not show any TV programmes.It just stays on booting mode
Box was working perfectly and then I installed TSMedia and ran Enigma2.When I turned TV off And turn it back on the problem started
SOURCE: Flatron LG monitor safe mode
Your monitor goes to Power Saving Mode when the signal it is receiving is not correct. In all probability this is not a problem of the monitor itself, rather you should check the connections and the computer the monitor it's connected to. For example you could try a different RGB cable and try it in a different computer.
Posted on Jul 27, 2007
  • 17 Answers
SOURCE: Green box keeps popping up in upper right corner
You should be watching your dvd's on an input and not on tv analog 3. Every time the tv "senses" a signal change in the audio that screen will pop up. Connect the DVD player to the tv by using either the red, white and yellow (composite) connections or using the green, blue, red, white and red (component). Once you are on an actual input that box will stop popping up.
Posted on Dec 31, 2007
electronick
  • 505 Answers
SOURCE: Turns on and off green LED flashes until TV turns back on.
this is a symptom of a bad lamp. for some reason it won't spit out a lamp error. shaking up the lamp will sometimes fix temporarily but you will find replacing to be the answer. if your tv has a fan error, you will get 4 red blinks.
Posted on Dec 09, 2008
  • 108 Answers
SOURCE: Black box showing up in center of tv
your closed caption feature is turn on and in the text mode. either turn off the closed captions or change it from text to cc1
Posted on Jan 08, 2009
toolkits
  • 1099 Answers
SOURCE: My LG 42"tv shuts off by it self
hello, The best way to fix this is by opening the back cover of the television set.
The power light may be flashing or if you are runing with a series light bulb it may be cycling on and off continuously. There may be a chirping or clicking sound from inside the set. (Note: using too small a series light bulb load during testing for the size of the TV may also result in this condition.)
If there is a low voltage regulator or separate switching supply, it could be cycling on and off if the horizontal output, flyback, or one of its secondary loads were defective.
Does this TV have a separate low voltage regulator and/or switching power supply or is it all part of the flyback circuit? For the following, I assume it is all in one (most common).
Some simple things to try first:
Verify that the main filter capacitor is doing its job. Excessive ripple on the rectified line voltage bus can cause various forms of shutdown behavior. An easy test is to jumper across the capacitor with one of at least equal voltage rating and similar capacitance (make connections with power off!).
Use a Variac, if possible, to bring up the input voltage slowly and see if the TV works at any point without shutting down. If it does, this could be an indication of X-ray protection circuit kicking in, though this will usually latch and keep the set shut off if excessive HV were detected.
Posted on May 20, 2010
Tip
How to boot up in safe mode from Windows XP
Showing the steps to boot up in safe mode from Windows XP.
If Windows XP is the only operating system installed on your computer, booting into Safe Mode with these instructions.
1.If the computer is running, shut down Windows, and then turn off the power.
2.Wait 30 seconds, and then turn the computer on.
3.Start tapping the F8 key. The Windows Advanced Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. 4.To resolve this, restart the computer and try again.
5.Ensure that the Safe mode option is selected.
6.Press Enter. The computer then begins to start in Safe mode.
7.When you are finished with all troubleshooting, close all programs and restart the computer as you normally would.
To use the System Configuration Utility method
1.Close all open programs.
2.Click Start, Run and type MSCONFIG in the box and click OK
3.The System Configuration Utility appears, On the BOOT.INI tab, Check the "/SAFEBOOT" option, and then click OK and Restart your computer when prompted.
4.The computer restarts in Safe mode.
5.Perform the troubleshooting steps for which you are using Safe Mode.
6.When you are finished with troubleshooting in Safe mode, open MSCONFIG again, on the BOOT.INI tab, uncheck "/SAFEBOOT" and click OK to restart your computer.
Select your steps to boot up into safe mode to your Windows XP System.
Other relative articles: Crack windows password from system SAM files
How to reset Windows administrator password if forgot Windows Xp/2000/2003/2008/Vista/7
on Apr 16, 2010 | Computers & Internet
How to master reset LG Optimus Fuel LGL34C
reboot the phone. Once you see the LG screen during boot start tapping ONLY THE VOLUME UP BUTTON repeatedly until the phone reboots. This should get you into the recovery. From there you should be able to click the factory reset button.
Sep 28, 2014 | Cell Phones
I ve Sony Bravia KDL55EX713 55" TV, it keep showing me input banner showing(Bravia,LED,presence sensor,Motion flow,Full HD, BE3, WIFI HDMI etc.) I have tried display button, and all settings on...
Your TV is in store demo mode.
To fix this, access the TV's menu and find the option to run initial setup. At the beginning of initial set-up, you'll be asked whether or not the TV should be put into Home or Retail mode. Choose Home.
Mar 15, 2011 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Hangs on startup
Try booting in safe mode then run a chkdisk scan to see if it shows errors. To boot in safe mode power the computer completely down...wait a few seconds...when you power it back up keep tapping the F8 key on your keyboard. If done correctly a black advanced boot screen will appear with a choice to boot in safe mode. If you are able to boot in safe mode, it's likely that your hdd isn't the problem. It has to do with something in your startup programs. To disable some unwanted startup items Click Start--> RUN-> in the box type msconfig then click on the tab that says startup and uncheck any unwanted items. Reboot the machine and see if it boots regular.
Aug 13, 2010 | Compaq Evo D500 PC Desktop
The thompson DV3 250 has deleted all my saved recording as 'invalid programme removed' it states the recording became corrupt on boot. the box has not been re-booted. and now it does not allow any...
No thank you.
This appears to have been a corruption caused by Top-up TV. The set box has been re-set to factory mode and re-booted
Thanks
Jan 19, 2010 | Televison & Video
Blank Screen
sounds like the mother board is failed..try one more thing..remove battery, run on power supply only, and see if that helps..otherwise, it's motherboard replacement time.
Nov 21, 2008 | Toshiba Satellite A135-S4527 Notebook
Thomson digital receiver
hi i think you might have the wrong software on the box,turn you tv on and put it on the sky channel take your viewing card out of the stb turn the box off then take the power lead out, wait till the stb powers down then put your finger on the backup button keeping it pressed put the power lead back in and holding the backup button wait till the on screen message comes on your tv, wait till the tv screen goes blank then put your card back in turn your box back on and try to record 2 channels at the same time this should solve the problem. if not it will be the cable or the quad lnb.
Jul 22, 2008 | Audio Players & Recorders
GATEWAY 310
I wonder if that is a computer virus.
Try putting the computer into safe mode by shutting the computer down, wait 30 seconds, turn if back on.
At the beginning of the boot press and hold down the f8 button. Use the up and down arrow keys to select safe mode and press enter.
After windows finishes starting up in safe mode, restart your computer the normal way.
If the login screen still appears that way and you can get into safe mode, I can tell you how to go into the control panel and change the login screen to the other mode. That should work then.
Jun 21, 2008 | Gateway 310S (2900621) PC Desktop
Black Box?
my tv was working fine. somebody hit the menu button on the tv or the remote and i get the black box appearing in the middle of the screen. and also the pip is staying on my tv it keeps showing "a snowy picture of pip sjpwomg channels 2 through 18 i cannot figure out how to get this off of my screen.
Feb 08, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Open Questions:
32 people viewed this question
 Grubhead
Grubhead
