Question about Ariston Technologies AWD120 13 lb. Washer / Dryer Combo
Ariston arxf125 on spin cycle door open alarm comes up
4 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Posted on Jul 24, 2009
  • 41 Answers
SOURCE: We have an Ariston A1636S Washing Machine. When
COULD BE SOMETHING IN THE DRUM UNDER THE CROME PIECE THAT THE CLOTHES GO ONE
Posted on Jan 09, 2010
SOURCE: Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Posted on Jan 23, 2010
Why are my clothes dripping wet after the spin cycle I have a ariston front loader avxl129
sounds like the pump could be unable to get the water out after the wash. check the door into the pump, at the bottom front of your machine
Aug 12, 2014 | Ariston Technologies Washing Machines
Constant clicking of door lock
Suggestion: Try a little WD40 spray on the door, not on the machine. Close and open 2 or 3 times while plug is off the wall mains.
Click if helped.
Apr 14, 2013 | Ariston Technologies Ariston AWD12 Front...
My arxf125 is displaying the word "door"
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 01, 2011 | Hotpoint Ariston AW125 Front Load Washer
Ariston LI 45 door will not remain closed and will
Strip the door and re-set the switch. Ensure the metal part of the catch on the machines main body is not distorted
Jan 31, 2010 | Ariston Technologies Dishwashers
Dec 30, 2009 | Ariston Technologies Washing Machines
Ariston front loading washing washing
Believe it or not.....its almost always the cloths ( heavy blankets) that one places inside.
TRY:: In the spin cycle if the load is unbalanced the TUB will rock and make that "loose drum out of alignment" noise. STOP the machine and open the door ( IF IT IS A TOP LOADER ) realign the cloths (heavy or more then one blanket) so that it is EVENLY spaced through out the tub.Start the machine again.If it does it again, stop the machine and REALIGN the cloths (blanket !!) again.
p.s. there is a simpler way of doing it but I don't want you to loose your hand in the process.
Aug 31, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Thanks.
Jul 24, 2009 | Ariston Technologies Ariston AWD12 Front...
Soon as i set cycle and swich on door light flashes open
hi,
The cycle doesn't advance
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Thanks for your question.
Jan 03, 2009 | Ariston Technologies AW129NA 16 Lbs Front...
Ariston AML125 won´t spin or empty water.
Dislodge the white covering infront (just located at the bottom). Once opened, unscrew the black button at the right hand side. Once open, check for blockages like coins, loose items, even lint. This worked for me and saved me $$$!!!! Now my Ariston is back to its superb performance. Do read the manula once in a while, it does help!
Dec 02, 2008 | Ariston Technologies AW125NA 13 lbs. Load...
Washing Machines Logo
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
