Question about Fenix E21
Replace bulb in Fenix E21 flashlight - Fenix E21
I need someone to repair my Cree T6 flashlight?
If it is a good make there will be some type of warranty. The good ones like my Fenix Tactical are guaranteed for life. What make is yours? What is wrong with it? Click COMMENT under my post.
Apr 05, 2018 | Computers & Internet
Hi, I've founded one of the order,5318 52 LED Torch, there is no battery compartment exist in the case, please send me back as request. Thanks.
Not us, we are FIXYA, we are not who you think you are talking to!
contact the maker direct. That is not a good flashlight. Good ones just use one or maximum 2 Cree LEDs for up to 1000 lumens. Look up Fenix Tactical.
http://www.easylifegroup.com/docs/5318_52_led_torch_instructions.pdf
Mar 30, 2018 | The Computers & Internet
Can you open the switch end of fenix hl21?
the plastic will break and even if you do get access to that, the issue with the corrosion will still cause problems.
Nov 24, 2013 | Fenix Flashlights Black HL21 Fenix HL21...
I have a Fenix TK15 that doesn' light up. I have changed batteries, still no light
Hi marlyn engaling...
Sounds like you need to replace your bulb, it may be burned out.
Also check the switch and also make sure the spring in the back of the flashlight is touching the battery tightly to make good contact.
Bud
Sep 18, 2012 | Fenix TK15
Fenix hp11 headlight
Hi, I have some experience with this unbekievable good headlight(when it works).
I had a hp10 what started to stop more and more.
After a while it wasn't going on.
5 years warrenty, so i got a new one, the new model.hp11
The main problem is the wire from battery case and the head led.
When there a litte damage inside this wire, light goes of not going on it selfs when it connecting again. After a while it will not work any more.
(if you have a welding station you fix it your self (battery case,can go open by unscrew the wire entrance.)
Chack battery case if the springs are all still connecting the battery.
If you put in one battery false on there is short cut and al sprigs get so hot they will shrink. And stay in that position..fix that your self or ring/ contact the shop you bought it.
There 5 year of garrantie.
wonderfull
Jul 25, 2012 | Fenix Camping, Backpacking & Hiking
How do i replace the bulb
Julio, the black bezel will unscrew from the main housing. The bulb is either a screw-in or friction fit (pushes in) type. Most hardware stores will carry a replacement bulb that works for this flashlight. Be sure to take the burned out bulb with you to match it correctly.
Hope this helps.
Apr 25, 2011 | Makita 18V Lxt Lithium Ion Rechargeable...
Put new batteries in it,turned it on and still wont work,you think it might be the bulb
Before replace the bulb, check for rust or dirt inside the electrical contacts. clean it. if still wont work, replace the bulb.
sammyc47
Feb 22, 2011 | MagLite 4 Cell C Flashlight Black
How do you replace the bulb on a Coleman PML8020 Flashlight
If there are little pegs on the sides you have to push the bulb it and turn (usually turn left)
Jan 05, 2010 | Camping, Backpacking & Hiking
Fenix E21 Logo
Top Fenix Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Fenix Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
