Question about HP Photosmart 2575 All-In-One InkJet Printer
Black line down the middle of scanned documents with HP 2575
Please, any help?
I do not know why I get a thick black line down the middle of any scanned document with my HP Photosmart 2575......
I would appreciate any help.
Thanks.
  • rfranco1964 Jun 19, 2009
    Well, I really appreciate your help, although my machine still does not work, and it is a new HP 2575, bought in Canada but brought to my working place in LatinAmerica.
    But I accept that I will have to take it to a technician here somewhere, because I did everything you suggested, but without success. I still have that horrible THICK BLACK STRIP or LINE in the middle of my scanned and copied images.
    Thank you anyway! I am glad I got to know this service!
    Excellent!
    I will surely use it again!
    I will follow your advise: I need technical service now.
    I am writing to you from the jungles of South America!
    Chao!
    All the best!
    Ricardo Franco
Hello rfranco1964
I'd like to assist with this issue.
I understand the problem may have appeared like this?
This problem is quite a common one I have come across and the first step I take is usually to power cycle the all-in-one. This works in most cases. I understand you are seeing a black line such as this after scanning? If so, power cycling the unit may seem too simple, but in most cases it does help.
  1. Unplug the USB cable from the all-in-one
  2. Unplug its power cord
  3. Plug the unit back into a wall socket without a power strip if possible
  4. Connect the USB cable back in
  5. Try to copy a document. Is the problem now solved?
If not, you may need to try cleaning the glass. Turn off the all-in-one, raise the lid and clean the glass with a soft cloth or sponge slightly moistened with a non-abrasive glass cleaner or water. Dry the glass with a lint-free cloth.
Now close the lid, turn on the unit, and try to do a blank copy without inserting any paper. Is the problem now gone? If so, it may have been any residue on the glass which prevented the light from passing through to the page, and thus creating a black smear down the center.
If the issue persists, it may be an internal problem with the scanning unit, and in that case would need to be serviced.
With regards
nLinked
Posted on Jun 19, 2009
On my Photosmart 2575 all in one printer when I scan documents there is a large black line down the center. I can't figure out what's wrong. Help?
if you scan so many documents the inside of the glass or the printer is full of dirt from the inks.So you have to open it and clean it very well especially the glass.Maybe you have and a strange sound...
Jul 04, 2010 | HP Photosmart 2575 All-In-One Printer,...
Black lines on scan
Dear all
I have the same problem Please Help
Mark
Jun 04, 2010 | HP ScanJet 2300C Flatbed Scanner
Black line down middle of scanned documents
if you have the same problem when printing any thing,t may be have a problem in your cartridges
or you have a problem in your scanner assembly (replace it)
Mar 22, 2010 | HP Photosmart 2575 All-In-One Printer,...
Black bar printed in the center of copied document
try copying the document to your computer and then from computer take a print out.
Aug 23, 2009 | HP Photosmart 2575 All-In-One InkJet...
Thick black line
clean the roller and the catridge reel
Jun 11, 2009 | HP Photosmart 2575 All-In-One InkJet...
Black line down the middle of scanned documents.
Try leaving the cover open and run a test scan, once with a fresh sheet as the item to be scanned and then a second time without anything on the table.  You may see what is blocking the light source or possibly a defect in it.
Scanning is done left-right, left-right across the width of the page and the vertical stripe indicates that the blockage is present during each scanned line.
In servicing copiers and multifunction machines, I have found a number of curious contaminents, one of the most annoying was a moth, still alive, that would randomly sit on the lamp, causing some pages to come out OK, others not.
If your copies and printouts are coming out fine, then only the scanner can be at fault.
Jan 13, 2009 | HP Photosmart 2575 All-In-One InkJet...
Hp deskjet f380 print and scan function copys with a wide black
clean the print heads and run clean cartridge utility from printer properties window.after that
disconnect the power and usb cable from the back of the printer and press and hold down the
power button for 30 sec and then reconnect the cables and try again...open the backdoor and
try to move the rollers in upward direction.
Nov 26, 2008 | HP DeskJet F380 All-In-One Printer
Black lines through documents
Try cleaning the cartridges to see if that helps..... mine did the same thing and after I cleaned it, it worked like new.
Feb 18, 2008 | HP Photosmart 2575 All-In-One Printer,...
Black lines when scan and copy documents
It is because coping is not the best way to get a perfect copy on the printer, Try scanning with computer using black and white photo it will come out much better if you are doing a pic. then use color picture.
Feb 17, 2008 | HP Photosmart 2575 All-In-One InkJet...
HP Photosmart 2575 All-In-One InkJet Printer Logo
83 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
