Question about Brinks 185-50051-4 Front 4 Dial Resettable Sports Lock, 2 Inch
Reset brass number lock - Brinks 185-50051-4 Front 4 Dial Resettable Sports Lock, 2 Inch
I forgot my combination to my brass ace 4# lock
Set all the numbers in a line. Gently apply tension to the hoop and turn the furthest away dial until you feel it give, move to the next one until you get to the last one.
If it has a rotary combination, impossible.
Ace Solid Brass Combination Padlocks Solid Brass Ace Hardware
Dec 09, 2015 | Locks & Locksmithing
How to reset digital cannon gun safe combination?
Go to cannonsafe.com and find their help line unless they have online instructions available. Be ready with any serial numbers etc receipt of purchase, where you bought it. They may not readily hand over the info.
Jul 03, 2014 | Yale Y150/30/125/1 Solid Brass Body...
How do you reset the combination to a Ace Solid Brass Combination Padlocks
Open the lock, rotate the shackle180 deg, and push down.enter new combo, and rotate shackle back to normal position.
Mar 27, 2014 | Ace Hardware Ace Solid Brass Combination...
I cant reset code it keeps beeping
To determine why your lock is beeping abnormally, please follow these steps:
Take out batteries and unplug powerstrip.
Let it sit for 1 minute, then put the batteries back in and wait another minute.
If it does not beep, the keypad needs to be replaced (17733-1).
If the unit continues to beep, the powerboard needs to be replaced (A17734-3,3 Powerboard 1470 brass finish; A17734-3,26D Powerboard 1470 satin chrome finish; A17734-3,5 Powerboard 1470 antique brass finish).
Navigate to the complete page that I cut this from can be found by cutting and pasting this link into your browser search bar:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Then go to: US & International/FAQ Categories/Keyless Entry/Powerbolt 1000/Search Results/ How do I troubleshoot my Powerbolt 1000?
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem, first of all to confirm that you need the part before you go through the expense. Secondly, your lock may be new enough for you to talk them into warrantying it, and thirdly, they will be able to get the correct part on order for you.
Good luck--and please provide feedback if this helps!
Sep 04, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
Weiser lock began to emit a single long beep at regular intervals of several minutes. Changed the batteries and reset the code and it works fine, however, still continues to emit a single long beep at...
Why is my Powerbolt 1000 unit beeping?
The complete page that I cut this from can be found by cutting and pasting this link into your browser search bar:
Since you've already gone through the battery change, this suggests that you need to replace the appropriate Powerboard for your lock.
So this is the link to Weiser Customer Support Page. Here you will find the appropriate contact numbers, US or Canada:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
Aug 04, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
I awoke last night to what I thought was someone trying to punch in a key to my lock. Instead the lock was making a noise like it does when you enter your code and then went into a long beep like it was...
Jan 16, 2011 | Kwikset Powerbolt/Electronic Deadbolt-...
How do i reset the password?
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will give you instructions for various models of Schlage locks:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
There's a video available on that page.
Dec 18, 2010 | Schlage BE365-CAM BE365CAM505 Lifetime...
.how to reset code push
There's a video that shows you how.
Nov 20, 2010 | Schlage BE365-CAM BE365CAM505 Lifetime...
How to reset keyless locks
There is a video on this page, showing how to change codes.
Nov 14, 2010 | Schlage BE365-CAM BE365CAM505 Lifetime...
Brinks 185-50051-4 Front 4 Dial Resettable Sports Lock, 2 Inch Logo
70 people viewed this question
Top Brinks Locks & Locksmithing Experts
 Angie Walden
Angie Walden
Level 1 Expert
andrewcahoon
Are you a Brinks Lock and Locksmithing Expert? Answer questions, earn points and help others
