Question about Fenix Camping, Backpacking & Hiking
I cannot remove front-piece to replace H4 bulb
Fenix E21 bulb needs to be replaced
SOURCE: Tail light removal
There is also a screw on the bottom of the light housing. You access this screw by laying on your back and reaching up behind the bumper assembly. You may also need to take one screw off the bumper mount near the tail light. This makes it easier to remove the old light housing.
Posted on Jul 24, 2008
  • 4 Answers
SOURCE: trying to replace a front headlight bulb on 2001 acura 3.2 TL
Look for the end of the wire retainer clip. Unhook it and lift it up. Remember not to touch the bulb. But if you do, just clean it with a bit of alcohol.
btw - Here's a bit of info from a previous post of mine...
The low beams consist of three parts. The bulb, inverter/ballast and the ignitor. The bulbs usually start to loose their color long before they burn out. The inverters/ballasts either go out after a while or take a while to start up.
Before you spend money on a new bulb, try swapping it with the one on the other side. You'll need a security torx screwdriver to get the covers off of the back of the lights. Don't touch the glass bulbs. If you do, just clean them with a bit of alcohol.
If the problem stays on that side, try swapping the ignitors. They're mounted inside the black covers.
If the problem is still on that side you've got a bad inverter. They're mounted on the bottom of the headlight assembly. You'll need to remove the front bumper and remove the headlight assembly to get to it. (I recommend you take pictures as you remove things so can put them back together correctly.)
Posted on Jan 05, 2009
SOURCE: 2006 Buick Lucerne Headlight Bulb Replacement
I have read that the only way is to remove the plastic bumper. I hate my Lucerne...piece of junk.
Posted on Mar 25, 2009
  • 14036 Answers
SOURCE: need replace turn signal bulb
YOU HAVE TO THE FRONT HEADLIGHT HOUSING TO REPLACE THE TURN SIGNAL BULB.
Posted on Aug 24, 2009
Testimonial: "thanks"
iFixapples
  • 57 Answers
SOURCE: headlight replacement o5 trailblazern 200
Hi El, Since it's on the passenger side you'll need to remove the air filter housing & filter to get to the housing for the bulbs. Right behind that bulb housing there are two rubber coated caps (those caps are where the bulbs are located) that you'll need to remove. They can be tough to remove so it should be ok to use a flat head screwdriver to GENTLY pry the caps. Just make sure you are GENTLE with it and once it is loose use your hand to turn it counterclockwise about 1/4 turn. Gently pull it out then unplug the wire harness to it. **** IMPORTANT*** Like most headlight bulbs, DO NOT TOUCH THE NEW BULB WITH YOUR BARE HANDS. Halogens are ruined by our natural oils and it will make your new bulb burn out extra fast. Also: The outside bulb should be the LOW BEAM and the inside should be the HIGH BEAM. Let me know if you have any other questions and I'll be happy to help.
Posted on Apr 23, 2010
I have a Fenix TK15 that doesn' light up. I have changed batteries, still no light
Hi marlyn engaling...
Sounds like you need to replace your bulb, it may be burned out.
Also check the switch and also make sure the spring in the back of the flashlight is touching the battery tightly to make good contact.
Bud
Sep 18, 2012 | Fenix TK15
How do you open the front headlight housing to replace the bulb
Hi Johnnywtf59, for more information about your question please visit the websites below. Good luck and have nice day.
Replace an H4 Headlight Bulb on Harley Davidson by Cycles
Aug 11, 2012 | 2002 Harley Davidson FXSTD - FXSTDI Deuce
Saab 9-3 99 dipped bulb is fine
their are two fuses for the headlights one for each side if i remember rightly so check the fuses if its not marked pull all the 10 and 15 amp fuses and check them
Jan 31, 2012 | 1999 Saab 9-3
How to change a headlight bulb, do i have to take off the front fairing?
hi, it is not normaly nessasary to remove the fairing on this model for bulb replacment, the bulb holder is in the middle of the headlight behind a rubber cover, pull off the 3 way plug from the bulb, remove the cover, unclip the wire clip from the bulb and remove the H4 type bulb, some later fuel injection models are more difficult, hope this helps. paul
Jan 04, 2011 | 1999 Honda CBR 600 F(4)X
Is it possible to put a xenon headlight conversion kit in a 1990 toyota pick up?
yes hella makes a h4 bulb retrofit kit. It includes new housings the use a replaceable h4 bulb. then purchace a hid h4 kit and install. I got th hella kit from summit for around $50 and used xtratights kit its a direct plug in no cuttting needed
Nov 02, 2009 | 1990 Toyota Pickup
Headlight bulb replacement
It's easy to change the bulbs. You don't have to remove the bumper.
To start at the left front, jack up the left front of the car, turn the wheel to the right, remove the plastic plugs and two screws holding the plastic fender liner in place (there are two pieces - loosen the front most piece) and pull it down. You will see the back of the headlight housing. Unscrew the caps and install the new bulbs. Reassemble and repeat on the other side.
Oct 24, 2008 | Street Glow Streetglow Streetglow H894...
Replacing headlamp
Hi jlamsmiley,
You may find it easier to remove the battery...or you may get chaffed hands....Reach down and remove the connector...it has snap clips on the sides.... Remove the plastic dust cover and then reach inside the housing and you'll find a spring wire clip which locks into a hook, release that and the bulb comes out.... Fit the new H4 bulb and make sure that the tabs fit the housing.... You'll notice that two are smaller than the third....This is how the bulb is pre-focused....
Regards Johngee10
Jul 30, 2008 | 1998 Toyota Corolla
Peugeot 206 headlight bulb problem
are you fitting the correct bulb?
i have a 2001 206 & that takes H4 bulbs
regards
Sep 19, 2007 | Baby Gear
Camping, Backpacking & Hiking Logo
56 people viewed this question
Top Fenix Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Fenix Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
