Question about Hotpoint Washing Machines
Error 2 on scanfrost washing machine
The machine comes up but does not wash due to error 2. What does error 2 signify
  • Tosin Smile
    Tosin Smile Jan 03, 2018
    How were you able to resolve this please.
    Habit-Forming:
  • 157 Answers
The information is online, at Hotpoint.com.
Posted on Jan 03, 2018
  • 641 Answers
SOURCE: error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
Posted on Aug 16, 2007
  • 209 Answers
SOURCE: Indesit front loading washing machine error code
i am a recently retired engineer of 20 years, but this sounds like (based on the info given) a heater element fault, after the machine fills up and agitates a few times the heater should start, check the heater for open circuit, replace if needed, of course it just could be a wire off? if i have helped rate me please
Posted on Sep 09, 2007
SOURCE: samsung b1245s washing machine
The error code HE2= water heater error (The heater element did not getting hot)
Unplug the machine to reset this error.
Try different cycle let see you still getting the same error.
Posted on Jun 23, 2008
  • 17 Answers
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Posted on Dec 17, 2008
SOURCE: sharp washing-machine
check the machine's solenoid, most probably that is the problem
Posted on May 02, 2009
Lg washing machine ie fault
An IE error code signifies that the washing machine is filling with water slowly or not at all. This can occur when water supply taps are not fully open or the water pressure to the tap or house is too low. Other possible causes are kinked, pinched or bent water line hoses, or clogged water inlet filters
Dec 03, 2016 | LG Washing Machines
After replacing fuser upper roller machine shows error code 010-327.after resetting 3 to 4 times then the machine comes in ready
That error signifies that the fuser is not heating up, it could be the lamp or the thermistor, check your connections and lamp continuity.
Jan 19, 2016 | Xerox Workcentre 5225 / Copier, With...
What does error code CA on my calypso washer?
Ca - Average Current peak - happens if there is a 2 second average of current draw greater than 5.55 amps at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. Overloading the unit may cause this problem. Try washing smaller loads and see if the problem goes away. If it recurs when you wash bigger loads, decrease the size AND watch to see if you have to continue to decrease the size to keep the error from happening. If that were occurring, it could well be a sign of the electrical problems noted, requiring service.
CA Cl Average current limit Or Instantaneous current limit If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or Cl for instantaneous current limit trip. Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings. Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
I think CA means [C]ontrol [A]verage Error. It means you need to reset the control panel, and retry again.
Aug 22, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
P.c.b. not working
Washing machine is showing error "PE" it's not a big problem you are washing machine is just fine.PE means error signal due to low voltage .Machine resumes functioning after the voltage comes back to normal.
Oct 21, 2012 | Whirlpool Washing Machines
I am getting a CA error on my Whirlpool Calypso washing machine. It is leaking water out of different parts of the machine and there is water in that will not drain out. Before I spent a lot of money for a...
Hi
If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display "CA" for average current limit trip. Average current trip occurs if there is a 2 second average of current draw greater than 5.55 Amps at the motor windings. This may signify problems with the drive motor, thermal protector or motor controller, overloading the unit may cause this problem. Hope this helps...please post back for further assistance.
Daniel
Jul 05, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
An IE code comes on my washing machine and when this happens it does not go through the final rinse cycle
Error code of "IE" signifies a water inlet error.
This means that your machine is not filling to the proper water level, and may be fixed by ensuring that machine's water supply is properly connected and turned on. Also, this means that the washer has not filled with water in 8 minutes.
Hope helps.
Jun 14, 2011 | Washing Machines
My kenmore front load washing machine comes up with error sp ?
SR = Stuck Relay.
"Sr" signifies a failure of the relay in the closed position. With this failure, power to the motor controller cannot be turned off by the machine controller.
The machine control board may have a bad relay and may need to be replaced. Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller. This should have AC line voltage when the motor controller is powered.
Press STOP/CANCEL to clear the display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 23, 2010 | Kenmore 44102 Front Load Washer
Calypso kenmore washing machine faulty spin cycle ''CA'' code
This code signifies that there may be a problem with the motor, thermal protector or motor controller. Overloading the appliance may cause such an error code. Try using a smaller load. If the code reappears, contact an appliance service company.
Apr 13, 2010 | Kenmore Washing Machines
What does a fault F01 signify on a Hotpoint Ultima 7kg washing machine?
Error code F01 indicates a short circuit motor triac.
Thoroughly check all connections on the motor, the motor plug, and the electronic module board..
Look for a broken wire, or a bad connection.
Please rate my solution.
Thankyou.
Jan 22, 2010 | Hotpoint Ultima WF860 Front Load Washer
Washing machine pulls ca then c1 code. seems to be the calypso action problem. does it need a new motor
The C1 code signifies "Average current limit Or Instantaneous current limit."
display either CA for average current limit trip or C1 for
motor controller. Over-loading the unit may cause this problem. "
Please check down the drive motor to resolve the issue.
Have a blessed day!
Thanks!
mannu_rakesh
Sep 01, 2009 | Washing Machines
Washing Machines Logo
101 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
