Question about Quartet gbc CC55 (Cross-Cut) Shredder
Taking the top off a Shredmaster cc55
I'm trying to take the top off a Shredmaster cc55 to take a look at the blades that seem to be bent (there is a really high whining noise and there is no paper pull). I have already removed all visible screws, but there seems to be something else holding the cover on the left back side. It is NOT the left handle screw as I have already removed it. I am afraid of breaking the plastic cover if there is really something else I shoud try before applying any force...
Please help.
  • 328 Answers
They hide some screws pretty good. Also, try with a putty knife to gently pry arouond the cover seam. Their is always a puzzel to keep end users from DIY.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Jun 22, 2009
A sears dozer blade will not sit level.one side is an inch higher then the other on a level surface. was originally like this but has gotten worse
It does sound like you have a bent frame. It can also be soft tires on one side of the tractor. You can try putting a block under the lower end of the blade (while still attached) and push down on the the higher end of the blade to spring things back in shape.
Feb 17, 2015 | Sears Garden
When engaging blades engine dies after mowing over 2in sawn off tree stump
take deck belt of and check that blades stiil turn by hand most likley bent or broken
Feb 23, 2013 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Blade falls off when started. cant seem to tighten blade enough to keep it on
could be quite a few things, first try another blade and try and notice which pulley it rools off of first. If the back pulley look for a loose axle. If the front also look for a loose axle, bent housing ( from hitting work) or the shaft that tightens the blade might have a bent tang. If the front seems to be a problem you can loosen the axle and shim the backside, Also look at the condition of the tires for excess wear.
Sep 22, 2011 | Milwaukee Electric Tool 6230 Electric Band...
My 42 inch Toro seems to be cutting unevenly. The blades seem to be on correctly and I hope I haven't hit something to set the angle wrong
First thing to check is that the deck is level by the adjustments on wheels. Then check the bearings in the spindle housings and there is no play in the shaft when you try to move blade up and down. You then can measure from the blade tip bottom of deck on both sides (3 o'clock and 9 o'clock, and then 12 o'clock and 6'o clock They should all be the same. If not then either the shaft is bent, or the deck is bent slightly causing the blade not being parallel to the deck. If you have someone rotate the shaft you should be able to tell if the shaft is bent or not. If the deck is bent, then you will have to straighten it out till the spindle shaft is perpendicular to deck.
Oct 14, 2010 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
I ran over a cable-wire with my Craftsman 7 hp ohv front drive mower and it stalled out.\r\nI removed the cable and now the blade seems as though it seized, can turn the blade to a point and no futher....
Bent blade, bent mower deck or bent crank shaft.
Unbolt the blade, check under the spacer plate , and set blade on a flat surface to see if warped or bent.
Remove spark plug wire and pull start cord to see if motor will rotate. don't need to start. If pulls free then look for obstruction or dent.
Jun 11, 2010 | Craftsman Garden
I have a MTD garden tractor with 3 bag catcher and the shute constantly plugs up. I mow once a week but it's like there isn't enough vaccum to blow the grass into the bags. I have my blades with the bent...
bent part of the blades need to be facing up towards your deck which creates a vacuum and allows a better lift to throw the grass in the bag When bagging blades should be labeled as high lift blades which are designed for bagging . Also which you probably already know its better to bag when the grass is NOT damp.
Hope this helps your issue
Jun 04, 2009 | Mtd Garden
How to fix a stuck shredder
get a pair of needle nose pliers and pull the jammed paper out. (you may need to figure out how to pop off the top cover to get better access to the blades)
May 27, 2009 | Quartet gbc ShredMaster 950S Strip-Cut...
Tremendous machine vibration
Make sure the "connect buckle" is connect to the correct side, and not bent in the middle, it should be straight. If this doesn't help, new blades are sometimes different weights try to matching the weight of opposing blades you may even need to sticky tape a small weight underneath the blade to get them balance. Don't stick anything on to the top of the blade.
May 25, 2009 | Apache 3 Channel Micro Indoor Helicopter...
Shredmaster 1656 makes extreme noise when turned on. Sounds like motor. Please help!
Sounds like shred blades are bent down into each other.
UNPLUG.
If you can get the top off, you may be able to use a large screw driver to straighten out the blades.
Sep 03, 2008 | Office Equipment & Supplies
Quartet gbc CC55 (Cross-Cut) Shredder Logo
229 people viewed this question
Top Quartet gbc Office Equipment & Supplies Experts
Pie-man
Level 1 Expert
pantomac nv
pantomac nv
Level 1 Expert
Bill Boyd
Are you a Quartet gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
