Question about Brother MFC 7840W Printer
How can I stop a black vertical line on copying and faxing on Brother MFC 7460DN?
antiochpc
  • 1314 Answers
SOURCE: vertical black line in scan document not in copies through document feeder
Lift the lid and to the left of the main glass is a smaller glass; that is what scans during the feeding process. Make sure that it is completely clean; even a speck of dust can cause a line to appear. I took a lens wipe and cleaned mine and my line was gone.
Posted on Jun 01, 2009
  • 17 Answers
SOURCE: Black Vertical line on copies using MFC-8660DN
Vertical lines mean it is being caused by one of the rollers within the printer. This is usually either the toner cartridge or the fuser assembly. I would try changing out the toner cartridge first even if it is new as sometimes they are DOA and they are much cheaper than the fuser assemblies. If that doesn't work, probably the fuser assembly.
Posted on Jun 05, 2009
the kowalski
  • 86 Answers
SOURCE: Black lines in copies and fax's Brother MFC 7420
If the black lines comes when using the ADF (top feeder), try to see if you get the same problem when using the scanner glass or receiving faxes. If you don't, you simply have to clean the glass strip to the left of the a4 sized scanner glass. Wipe it with a dry cloth piece, no paper and no water/alcohol. If you see some dirt there that you're unable to simply wipe off, try to use a cotton wool to "rub" it off.
Posted on Jun 14, 2009
ryeisenman
  • 7 Answers
SOURCE: Brother MFC 8220 all-in-one fax prints with a vertical line
First guess is you have a bit of dirt (often white-out from people scanning corrected paper that's not quite dry) stuck on the fax scan window. This should be described pretty well in your user manual (which you can download online from brother.com).
Its also possible that there is dirt (typically loose toner) on the laser scan window (there's a laser that shines through it to get the image pattern on the drum). That window is often along the bottom of the unit under the drum/cartridge (take the cartridge out and look). The Brother manual I've seen seems to ignore this possibility.
Print streaks DO NOT mean cartridge drum replacement in many cases !! On brother Intellifax or MFC or other laser copier/printer/fax, keep in mind that either the fax/copy scan window OR the laser scan window can get dirty. If the fax scan window is dirty, you see streaks on outgoing faxes and copies (but NOT incoming faxes). If the laser scan window is dirty, you see streaks on all prints (copies, faxes, print-from-computer).
Note also that when transporting/moving some laser copier with the toner cartridge inside, the toner can get out and make a big mess inside (including getting the laser scan window dirty). An air compressor can be usefull to blow it out. And sometimes using alcohol to clean is a BAD idea (maybe incompatible with plastic and rubber parts). A damp rag is probably fine.
Posted on Nov 21, 2009
  • 1684 Answers
SOURCE: i get vertical lines on scans and copies when
Check out this page on our web site at:
http://www.ccl-la.com/dirty_scanner.htm This page shows you what to do to get rid of the lines on scans and copies.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jan 12, 2010
Reset a brother MFC 7460DN after replacing the fuser unit?
You need to press Menu-Mono Start-Up Arrow 4 times in less than 2 Seconds !!! and you will be in Maintenance mode. LEDs will be flashing. Press 88 then use the arrows to select Fuser and press ok. Then press 99
Oct 25, 2014 | Brother MFC 7460DN - Multifunction fax /...
How do I restore default copy settings Brother MFC-7460DN
Check in the users manual, which you can download from http://support.brother.com/g/b/manuallist.aspx?c=gb&lang=en&prod=mfc7460dn_all&flang=English&type3=440&type2=5
Aug 01, 2014 | Brother MFC-7460DN
Brother mfc 7460dn can't remove toner cartridge
Sometimes the press buttons do not release properly. It could be jammed with paper. try to cycle out paper and then try to push the release again. Keep trying until you get it. If it is jammed so tight that you cannot get the catch to release, I do not know what you would do. Mine only did that one time and I was able to get more paper out.
I hope that helps.
Jun 03, 2014 | Brother MFC-7460DN
Brother mfc 7460dn toner light stays on
This video has always worked a treat for me.
Hope this helps.
Oct 15, 2012 | Brother MFC-7460DN
Brother mfc-7460dn toner replace toner will not go away
Remove drum/cartridge, close front cover, Menu, 1. General, 8. Replace toner.
Replace drum/cartridge. Close front cover.
May 07, 2012 | Brother MFC-7460DN
Drum error
try this trick, open then the front cover and remove the drum&cartridge assembly then reinsert while the cover is open press clear/back key and will ask you 'replace a new drum' just answer yes by clicking an arrow up
May 31, 2011 | Brother MFC 7840W Printer
Brother MFC-6800 - Mysterious Vertical Lines
This unit has a brom tube unit and need to be replacement . By repair tec.
Oct 05, 2009 | Brother Multi-Function Center MFC-240C...
Jun 05, 2009 | Brother MFC-8860DN Printer
Black line while scanning and copying
Open up the document feeder and clean the scanner glass
Jan 25, 2009 | Brother Multi-Function Center MFC-240C...
My fax Machine has lines going each page that prints out
Get a can of air, open the unit and blow it out.
Also, clean the glass.
That should help solve the problem
Jan 08, 2009 | Brother MFC 4800 All-In-One Laser Printer
Brother MFC 7840W Printer Logo
21 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
